Not able to run riscv-rv32imac testsuites
Vaibhav Gupta vaibhavgupta40 at gmail.com
Sun Aug 11 15:10:59 UTC 2019
But I am not able to run:
qemu-system-riscv64 -no-reboot -nographic -machine virt -m 256M
-kernel hello.exe
On Fri, Aug 9, 2019 at 2:53 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> I was able to run rv32imac using
> qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M -kernel hello.exe
> When I configured rv32imac BSP with RISCV_ENABLE_HTIF_SUPPORT=1, This
command prevents qemu from quitting properly I guess.
As after showing output, cursor still blinks and I quit it using 'pkill -9
qemu'.
> On Tue, Aug 6, 2019 at 9:04 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> Awesome, thanks!
>> On Tue, Aug 6, 2019 at 8:50 PM Hesham Almatary <
>> hesham.almatary at cl.cam.ac.uk> wrote:
>>> Hi Vaibhav,
>>> * I recommend you use rv64* because of a potential 32-bit HTIF issue on
>>> Spike.
>>> * Make sure you install Spike correctly [1] and it's in your path or
>>> also qemu-system-riscv* instead.
>>> * If you're building RTEMS for Spike (i.e., rv*_spike), make sure to
>>> add RISCV_ENABLE_HTIF_SUPPORT to your configure line [2] when you
>>> build RTEMS.
>>> * It might be easier to try rv64* on QEMU (i.e., no Spike) instead.
>>> [1] https://github.com/riscv/riscv-isa-sim
>>> [2] https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
>>> On Tue, 6 Aug 2019 at 14:52, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>> > I am getting following error:
>>> > $ rtems-test --rtems-bsp=rv32imac_spike
>>> --rtems-tools=$HOME/development/rtems/5
>>> ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>>> > RTEMS Testing - Tester, 5.0.not_released
>>> >  Command Line: /home/varodek/development/rtems/5/bin/rtems-test
>>> --rtems-bsp=rv32imac_spike --rtems-tools=/home/varodek/development/rtems/5
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>>> >  Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20
>>> 15:00:46 UTC 2019 x86_64
>>> >  Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
>>> > Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
>>> 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
>>> > [ 2/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>> riscv32/rv32imac: capture.exe
>>> > [ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>> riscv32/rv32imac: cdtest.exe
>>> > [ 4/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>> riscv32/rv32imac: cxx_iostream.exe
>>> > [ 1/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>> riscv32/rv32imac: base_sp.exe
>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe:
>>> exit-code:2
>>> exit-code:2
>>> > warning: switched to dry run due to errors
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe:
>>> exit-code:2
>>> exit-code:2
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe:
>>> exit-code:2
>>> exit-code:2
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe:
>>> exit-code:2
>>> exit-code:2
>>> > Result: invalid    Time: 0:00:00.032377 base_sp.exe
>>> > =>  run: spike --isa=RV32IMAC
>>> > Result: invalid    Time: 0:00:00.037950 capture.exe
>>> > Result: invalid    Time: 0:00:00.038061 cdtest.exe
>>> > Result: invalid    Time: 0:00:00.034353 cxx_iostream.exe
>>> > [ 7/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>> riscv32/rv32imac: minimum.exe
>>> > [ 8/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>> riscv32/rv32imac: nsecs.exe
>>> > [ 5/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>> riscv32/rv32imac: fileio.exe
>>> > [ 6/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>>> riscv32/rv32imac: hello.exe
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/minimum.exe:
>>> exit-code:2
>>> exit-code:2
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe:
>>> exit-code:2
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe:
>>> exit-code:2
>>> exit-code:2
>>> exit-code:2
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe:
>>> exit-code:2
>>> exit-code:2
>>> > Result: invalid    Time: 0:00:00.009235 fileio.exe
>>> > Result: invalid    Time: 0:00:00.005886 hello.exe
>>> > Result: invalid    Time: 0:00:00.011045 nsecs.exe
>>> > [ 9/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
>>> riscv32/rv32imac: paranoia.exe
>>> > [10/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
>>> riscv32/rv32imac: ticker.exe
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe:
>>> exit-code:2
>>> exit-code:2
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe:
>>> exit-code:2
>>> exit-code:2
>>> > [11/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:8  W:0  |
>>> riscv32/rv32imac: unlimited.exe
>>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe:
>>> exit-code:2
>>> exit-code:2
>>> > Result: invalid    Time: 0:00:00.011650 paranoia.exe
>>> > Result: invalid    Time: 0:00:00.009872 ticker.exe
>>> > Result: invalid    Time: 0:00:00.002352 unlimited.exe
>>> > Passed:         1
>>> > Failed:         0
>>> > User Input:     0
>>> > Expected Fail:  0
>>> > Indeterminate:  0
>>> > Benchmark:      0
>>> > Timeout:        0
>>> > Invalid:       10
>>> > Wrong Version:  0
>>> > Wrong Build:    0
>>> > Wrong Tools:    0
>>> > Total:         11
>>> > Invalid:
>>> >  capture.exe
>>> >  cdtest.exe
>>> >  cxx_iostream.exe
>>> >  base_sp.exe
>>> >  nsecs.exe
>>> >  fileio.exe
>>> >  hello.exe
>>> >  paranoia.exe
>>> >  ticker.exe
>>> >  unlimited.exe
>>> > Average test time: 0:00:00.093749
>>> > Testing time     : 0:00:01.031239
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190811/e39ab8c0/attachment-0002.html>
