GSoC Project | Basic Support for Trace Compass
Fri Aug 9 13:40:38 UTC 2019
Coming in late but there isn't there a helper method to turn object names
into strings from either 32 bit values or strings? Shouldn't that be used?
On Fri, Aug 9, 2019, 8:17 AM Sebastian Huber <
> On 09/08/2019 15:06, Ravindra Kumar Meena wrote:
> > rtems-main.c cleanup:
> https://github.com/rmeena840/rtems-tools/commit/61d5dc45e43f0998ad9305d565926090215a5bdc
> > Switch_event per CPU added:
> https://github.com/rmeena840/rtems-tools/commit/8ffe8bd2adea27772a9ab0e578539dd99fa0174b
> > Have a look.
> Ok, good. Please always check if the babeltrace and Trace Compass give
> the right results after the changes.
> If you use cctx->switch_event[ item->cpu ] and similar a couple of times
> in a function, then please assign it to a local pointer and use it, e.g.
> switch_event *se = &cctx->switch_event[ item->cpu ];
> Please check all structure names and make the similar to the names used
> in the metadata, e.g. swich_event -> event_sched_switch;
> Please check the style of the if again, it should be:
> if ( condition ) {
> } else {
> Check the white space and position of the { }.
> When you have a function like get_api_of_id() you return the api, so the
> variable should be named "api":
>    size_t api_id = get_api_of_id( cctx->thread_id_name[ item->cpu
> ].thread_id );
>    size_t api = get_api_of_id( cctx->thread_id_name[ item->cpu
> ].thread_id );
> Declare all variables at the top of the function, e.g.
> size_t api;
> api = get_api_of_id( cctx->thread_id_name[ item->cpu ].thread_id );
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190809/1cdc98ca/attachment-0002.html>
