[PATCH v2] rtems-record: New program
    Sebastian Huber
    Thu Aug 15 07:33:07 UTC 2019
----- Am 15. Aug 2019 um 8:26 schrieb Chris Johns chrisj at rtems.org:
> On 15/8/19 4:05 pm, Sebastian Huber wrote:
>> ----- Am 15. Aug 2019 um 2:09 schrieb Chris Johns chrisj at rtems.org:
>>> On 14/8/19 3:19 pm, Sebastian Huber wrote:
>>>> On 14/08/2019 03:57, Chris Johns wrote:
>>>>> On 13/8/19 3:10 pm, Sebastian Huber wrote:
>>>>>> sorry for the rush,
>>>>> Sorry for the delay, I have a client demo this week I am helping with.
>>>>>> but what do you think of this patch?
>>>>> Why not C++? The rtems-tools repo has strong support for C++ and it brings a
>>>>> range of benefits, for example no need to code call handlers at a low level,
>>>>> containers so no need for us to include and maintain trace/record/tree.h, and
>>>>> more. When I see us adding code like `tree.h` I have in the back of my mind the
>>>>> long term support issues it brings while a `std::map` is maintained for us.
>>>> Originally, the program should be able to filter live traces with about 20MiB/s.
>>>> The std::map is simply too slow.
>>> It is difficult to comment without us heading into detail and I do not think
>>> there is any value in doing that.
>>>> Boost.Intrusive would be an option (it is
>>>> slower than tree.h in my tests too: https://github.com/sebhub/rb-bench). The
>>>> tree.h is a copy from Newlib, so it doesn't introduce new maintenance issues.
>>>> Anyway, for the CTF conversion the map is unnecessary and could be optimized
>>>> away. We didn't had the time to do this in the GSoC project.
>>> So performance is not an issue here and the code's presence is historical?
>> Ravindra needs this patch to integrate his work on top of it. I posted this
>> patch on January and at this time using C was not an issue:
>> https://lists.rtems.org/pipermail/devel/2019-January/024640.html
> Yes and I am sorry I did not raise this in that specific case.
>> His integration is now blocked because of something he didn't cause.
> Yes and I would to avoid there being a block.
>>>>> GNU projects like gdb and gcc have moved to C++ and of course llvm is C++ and
>>>>> this is for good reason. I provide these examples in the hope this does not
>>>>> start a C vs C++ debate.
>>>>>> I would like to
>>>>>> integrate the tracing work of the GSoC project and this patch is a blocking
>>>>>> point.
>>>>> I understand. I am excited by the work that has been done here and what you are
>>>>> doing. It is taking all my will power to not read the ARM debug trace section of
>>>>> an ARM TRM as I think that hardware is ripe for integration with this code base
>>>>> and set of tools. A C++ framework in rtemstoolkit would be really helpful if I
>>>>> do as it would grow what we have rather than us collecting isolated C programs.
>>>>> I also understand and appreciate the limited time we all have so I am happy to
>>>>> hear how you see the host side progressing over time and how it fits into our
>>>>> ecosystem. I would also like to hear what others think.
>>>> I don't have a problem with C++ in general. However, I don't think that the use
>>>> of C in this small program is a blocking point to integrate the GSoC work.
>>>> This is work in progress anyway. This program only scratches the surface.
>>> What parts are to be added that depend on this tool? Maybe it would help if this
>>> is presented.
>>> Work in progress pieces are fine if there is a progression however I did state
>>> at the start of GSoC we currently use python and C++. I am weary of isolated
>>> tools that become unclear if we need to keep or we can remove after a period of
>>> time.
>> Sorry, but you should have stated that C++ is mandatory a bit earlier.
> I did ...
> https://lists.rtems.org/pipermail/devel/2019-May/025957.html
> There is C code in rtems-tools, ie elftools and bin2c and I am sure there will
> be others. In the case of trace there is a history of C++ and I think this work
> is important enough that we consider the long term use cases. I have attempted
> to avoid stating C++ is mandatory because that places us in a corner.
>> Now it is difficult to change. Ravindra did his work on top of a C program. We
>> can easily convert it to C++, but only after the integration of Ravindra's
>> work. The tool is already useful, it converts the RTEMS record stream into a
>> CTF stream which can be read by Trace Compass to display the thread switches on
>> multiple CPUs and the CPU utilization.
> Great. This is all I am asking for. I would prefer we resolve what happens
> before we merge and we avoid a misunderstanding.
My approach would be to merge it as is. I can then simplify it and remove the tree.h. Currently, the tool merges record items streams per-CPU into one ordered record stream, then this merged stream is again split up into one CTF event stream per-CPU. The record-client.c and record-text.c are shared with RTEMS and should not be converted to C++.
>>> Tools added to rtems-tools and installed are public facing user interfaces to
>>> our users. By installing the RTEMS project is agreeing to provide and support
>>> the interface provided. I am fine with tools being add if they serve other
>>> roles, for example as a means to test rtemstoolkit code, ie regression and
>>> development test tools. It is unclear to me where this tool fits.
>>> Maybe we need an option to rtems-tools's configure such as --experimental that
>>> builds and installs tools that are a work in progress but are not a public
>>> interface?
>> Ok, sorry, I should have started with the integration planning of the GSoC work
>> a bit earlier.
> Thanks, I am sure we can resolve this.
> Do you think --experimental is worth my time adding? This would mean we refactor
> the tool and then we remove the experimental status. It is a simple change, add
> the option and then add an if experimental to the install part of the waf
> script.
I don't think it is worth to add this switch. I will work on this program in August and September.
