Mounting/Accessing SD-Card on BBB
Christian Mauderer
list at c-mauderer.de
Fri Aug 16 08:48:09 UTC 2019
Hello Nils,
thanks for the file list. I can't reproduce your problem with it.
On 16/08/2019 10:01, Nils Hölscher wrote:
> Hi,
> Short update.
> It seems the device only hangs while I am connected with the debugger.
Is that true for the original file system tree? You are debugging via
Ethernet, right? In that case I would lean more toward a problem with
the debugger support than the file system. Do you have enough file
descriptors configured?
Best regards
Christian
> looks like a Heisenberg bug.
> Best,
> Nils
> On Fri, 16 Aug 2019 at 09:50, Nils Hölscher <nilhoel1 at gmail.com
> <mailto:nilhoel1 at gmail.com>> wrote:
> On Thu, 15 Aug 2019 at 19:51, Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
> Hello Nils,
> maybe another bug in our FAT file system...
> Please do three things:
> 1. Create an image of your current card (with dd or a similar
> tool). FAT
> bugs are sometimes hard to reproduce but it's really urgent that
> we fix
> them. So maybe I'll ask for that image later.
> I did that.
> Let me know if you need the image.
> 2. Create a complete list of the files on your card (for example the
> Linux `tree -h` command), post it here and tell me what you
> tried to open.
> ├── [ 50K] am335x-boneblack.dtb
> ├── [ 49K] am335x-boneblack+pruss.dtb
> ├── [ 883] AM335X-PRU-UIO-00A0.dtbo
> ├── [ 649] AM335X-PRU-UIO-BSD-00A0.dtbo
> ├── [162K] Linux-with-UIO.dtb
> ├── [ 44] loob.bin
> ├── [108K] MLO
> ├── [2.1M] pru.exe.img
> ├── [ 12] test.bin
> ├── [471K] u-boot.img
> ├── [ 390] uEnvLinuxfdt.txt
> └── [ 560] uEnv.txt
> 3. Try another name / folder for the file you wanted to open.\
> I moved the file in another folder and renamed it.
> It now works but I got en error, I am currently investigating if
> this is on the pru driver side or not.
> The tree while doing this was:
> ├── [ 44] loob.bin
> ├── [108K] MLO
> ├── [2.0K] test
> │ └── [ 12] test2.bin
> ├── [ 12] test2.bin
> └── [ 560] uEnv.txt
> Thanks,
> Nils
> Best regards
> Christian
> On 15/08/2019 19:32, Nils Hölscher wrote:
> > Hi Christian,
> > The commands ls and cat work.
> > I just tested them, this seems kinda awkward.
> > Best,
> > Nils
> > On Thu, 15 Aug 2019 at 19:27, Christian Mauderer
> <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > Hello Nils,
> > does some other access to the file system work? Like a ls
> on the console
> > or creating a file. Can you do a `cat` on some text file
> on the file
> > system? If not: Does it work for a file in the root file
> system (should
> > be a IMFS)?
> > Best regards
> > Christian
> > On 15/08/2019 15:54, Nils Hölscher wrote:
> > > Hi,
> > > I when my app wants to open a file on the SD card
> dev=mmcsd-0-0 rtems
> > > freezes.
> > > Exact call is:
> > > fd = open(file, O_RDONLY);
> > > With file being the pru binary I want to upload.
> > > Thanks,
> > > Nils
> > > On Tue, 13 Aug 2019 at 17:56, Christian Mauderer
> > > <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>
> <mailto:christian.mauderer at embedded-brains.de>>
> <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
> > > Hello Nils,
> > > a third possibility: You could start a FTP server
> and push the
> > file
> > > via network.
> > > Best regards
> > > Christian
> > > Am Dienstag, 13. August 2019 schrieb Nils Hölscher:
> > > > Hi,
> > > > Thanks for the input I will try the SD card first.
> > > > That way I won't have to alter the code when I
> want to run other
> > > stuff on the pru.
> > > > Best,
> > > > Nils
> > > > On Tue, 13 Aug 2019 at 17:32, Gedare Bloom
> <gedare at rtems.org <mailto:gedare at rtems.org>
> > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>> wrote:
> > > > You can also build the PRU image into the RTEMS
> binary. See
> > > > examples-v2.git/file_io/crc/init.c
> > > > On Tue, Aug 13, 2019 at 8:46 AM Christian Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > > > Hello Nils,
> > > > > that's a bit odd. I attached an expected output
> below.
> > Some guesses:
> > > > > - Did you add FAT file system to your application?
> > > > > - Is there some odd formatting on the SD?
> Normally at
> > least the FAT
> > > > > partition used by U-Boot should be visible.
> > > > > - Is your BDBUF configuration OK?
> > > > > - Do you have enough file descriptors?
> > > > > Beneath that: If you only need something where
> you can put
> > some
> > > files,
> > > > > you can try to connect a USB stick instead.
> Maybe that
> > works better.
> > > > > Best regards
> > > > > Christian
> > > > > media listener: event = DISK ATTACH, state =
> INQUIRY, src
> > = mmcsd
> SUCCESS, src =
> > > mmcsd, dest
> > > > > = /dev/mmcsd-0
> > > > > media listener: event = MOUNT, state = INQUIRY,
> src =
> > /dev/mmcsd-0
> > > > > mmcsd0: 4GB <SDHC TO 15.15 SN 000002F6 MFG
> 02/2017 by 25
> > DY> at mmc0
> > > > > 24.0MHz/4bit/65535-block
> > > > > media listener: event = MOUNT, state = FAILED, src =
> > /dev/mmcsd-0
> > > > > media listener: event = PARTITION INQUIRY, state =
> > INQUIRY, src =
> > > > > /dev/mmcsd-0
> > SUCCESS, src =
> > > > > /dev/mmcsd-0
> > > > > media listener: event = PARTITION ATTACH, state
> = INQUIRY,
> > src =
> > > > > /dev/mmcsd-0
> = SUCCESS,
> > src =
> > > > > /dev/mmcsd-0, dest = /dev/mmcsd-0-0
> src =
> > /dev/mmcsd-0-0
> > > > > media listener: event = MOUNT, state = SUCCESS,
> src =
> > > /dev/mmcsd-0-0,
> > > > > dest = /media/mmcsd-0-0
> INQUIRY, src
> > = mmcsd
> SUCCESS, src =
> > > mmcsd, dest
> > > > > = /dev/mmcsd-1
> src =
> > /dev/mmcsd-1
> > > > > mmcsd1: 4GB <MMCHC MMC04G 5.8 SN 160D224B MFG
> 09/2014 by 112
> > > 0x0000> at
> > > > > mmc1 48.0MHz/8bit/65535-block
> > /dev/mmcsd-1
> > INQUIRY, src =
> > > > > /dev/mmcsd-1
> = FAILED,
> > src =
> > > > > /dev/mmcsd-1
> INQUIRY, src =
> > > mmcsd1boot
> > > > > mmcsd1boot0: 2MB partion 1 at mmcsd1
> > > > > mmcsd1boot1: 2MB partion 2 at mmcsd1
> > > > > mmcsd1rpmb: 131kB partion 3 at mmcsd1
> > > > > On 13/08/2019 13:30, Nils Hölscher wrote:
> > > > > > Hi,
> > > > > > Thanks for the help.
> > > > > > I tried to use your code, but I always get
> "ERROR: SD
> > could not be
> > > > > > mounted after timeout".
> > > > > > Even after raising the waiting time.
> > > > > > The sources I use start here:
> https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
> > > > > > And my uart output is:
> > > > > > waiting for SD...
> > > > > > usbus0: 480Mbps High Speed USB v2.0
> > > > > > usbus1: 480Mbps High Speed USB v2.0
> INQUIRY,
> > src = mmcsd
> SUCCESS, src =
> > > mmcsd, dest
> > > > > > = /dev/mmcsd-0
> INQUIRY, src =
> > /dev/mmcsd-0
> > > > > > ugen0.1: <Mentor Graphics OTG Root HUB> at usbus0
> > > > > > ugen1.1: <Mentor Graphics OTG Root HUB> at usbus1
> > > > > > uhub0: <Mentor Graphics OTG Root HUB, class
> 9/0, rev
> > > 2.00/1.00, addr 1>
> > > > > > on usbus0
> > > > > > uhub1: <Mentor Graphics OTG Root HUB, class
> 9/0, rev
> > > 2.00/1.00, addr 1>
> > > > > > on usbus1
> src =
> > /dev/mmcsd-0
> > INQUIRY, src =
> > > > > > /dev/mmcsd-0
> > SUCCESS, src =
> > > > > > /dev/mmcsd-0
> > > > > > media listener: event = PARTITION ATTACH, state =
> > INQUIRY, src =
> > > > > > /dev/mmcsd-0
> > SUCCESS, src =
> INQUIRY, src =
> > > /dev/mmcsd-0-0
> src =
> > > /dev/mmcsd-0-0
> INQUIRY,
> > src = mmcsd
> SUCCESS, src =
> > > mmcsd, dest
> > > > > > = /dev/mmcsd-1
> INQUIRY, src =
> > /dev/mmcsd-1
> src =
> > /dev/mmcsd-1
> > INQUIRY, src =
> > > > > > /dev/mmcsd-1
> > SUCCESS, src =
> > > > > > /dev/mmcsd-1
> > INQUIRY, src =
> > > > > > /dev/mmcsd-1
> > SUCCESS, src =
> > > > > > /dev/mmcsd-1, dest = /dev/mmcsd-1-0
> INQUIRY, src =
> > > /dev/mmcsd-1-0
> src =
> > > /dev/mmcsd-1-0
> INQUIRY, src =
> > > mmcsd1boot
> > > > > > uhub0: 1 port with 1 removable, self powered
> > > > > > uhub1: 1 port with 1 removable, self powered
> > > > > > ERROR: SD could not be mounted after timeout
> > > > > > Thanks,
> > > > > > Nils
> > > > > > On Mon, 12 Aug 2019 at 18:01, Christian Mauderer
> <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
> > > > > > On 12/08/2019 07:28, Nils Hölscher wrote:
> > > > > > > Hi,
> > > > > > > Can anyone help me with this?
> > > > > > > I need to access the BBB's SD-Card, so
> that I can load
> > > my pru
> > > > > > example on
> > > > > > > the pru.
> > > > > > > Thanks,
> > > > > > > Nils
> > > > > > Hello Nils,
> > > > > > take a look at the following application:
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/init.c#L64
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/libbsdhelper.c#L122
> > > > > > You should mainly need the stuff from the
> > > libbsdhelper_init_sd_card()
> > > > > > and libbsdhelper_wait_for_sd().
> > > > > > Please note that the SD card needs quite
> some time to
> > > initialize on BBB.
> > > > > > I haven't had a look at it why that is the
> case.
> > > > > > Best regards
> > > > > > Christian
> > > > > > _______________________________________________
> > > > > > users mailing list
> > > > > > users at rtems.org <mailto:users at rtems.org>
> <mailto:users at rtems.org <mailto:users at rtems.org>>
> <mailto:users at rtems.org <mailto:users at rtems.org>>>
> > > > > > http://lists.rtems.org/mailman/listinfo/users
> > > > > users mailing list
> > > embedded brains GmbH
> > > Herr Christian Mauderer
> > > Dornierstr. 4
> > > D-82178 Puchheim
> > > Germany
> > > email: christian.mauderer at embedded-brains.de
> > > Phone: +49-89-18 94 741 - 18
> > > Fax: +49-89-18 94 741 - 08
> > > PGP: Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung
> im Sinne
> > des EHUG.
> > > users mailing list
