Mounting/Accessing SD-Card on BBB
Nils Hölscher nilhoel1 at gmail.com
Fri Aug 16 08:55:52 UTC 2019
Hi,
It seems the problem was hardware related.
My SD-Card connector just died.
I hope I can get a new BBB oin a timely manner.
Best,
Nils
On Fri, 16 Aug 2019 at 10:48, Christian Mauderer <list at c-mauderer.de> wrote:
> Hello Nils,
> thanks for the file list. I can't reproduce your problem with it.
> On 16/08/2019 10:01, Nils Hölscher wrote:
> > Hi,
> > Short update.
> > It seems the device only hangs while I am connected with the debugger.
> Is that true for the original file system tree? You are debugging via
> Ethernet, right? In that case I would lean more toward a problem with
> the debugger support than the file system. Do you have enough file
> descriptors configured?
> Best regards
> Christian
> > looks like a Heisenberg bug.
> > Best,
> > Nils
> > On Fri, 16 Aug 2019 at 09:50, Nils Hölscher <nilhoel1 at gmail.com
> > <mailto:nilhoel1 at gmail.com>> wrote:
> >     On Thu, 15 Aug 2019 at 19:51, Christian Mauderer <list at c-mauderer.de
> >     <mailto:list at c-mauderer.de>> wrote:
> >         Hello Nils,
> >         maybe another bug in our FAT file system...
> >         Please do three things:
> >         1. Create an image of your current card (with dd or a similar
> >         tool). FAT
> >         bugs are sometimes hard to reproduce but it's really urgent that
> >         we fix
> >         them. So maybe I'll ask for that image later.
> >     I did that.
> >     Let me know if you need the image.
> >         2. Create a complete list of the files on your card (for example
> the
> >         Linux `tree -h` command), post it here and tell me what you
> >         tried to open.
> >     ├── [ 50K]  am335x-boneblack.dtb
> >     ├── [ 49K]  am335x-boneblack+pruss.dtb
> >     ├── [ 883]  AM335X-PRU-UIO-00A0.dtbo
> >     ├── [ 649]  AM335X-PRU-UIO-BSD-00A0.dtbo
> >     ├── [162K]  Linux-with-UIO.dtb
> >     ├── [  44]  loob.bin
> >     ├── [108K]  MLO
> >     ├── [2.1M]  pru.exe.img
> >     ├── [  12]  test.bin
> >     ├── [471K]  u-boot.img
> >     ├── [ 390]  uEnvLinuxfdt.txt
> >     └── [ 560]  uEnv.txt
> >          3. Try another name / folder for the file you wanted to open.\
> >     I moved the file in another folder and renamed it.
> >     It now works but I got en error, I am currently investigating if
> >     this is on the pru driver side or not.
> >     The tree while doing this was:
> >     ├── [  44]  loob.bin
> >     ├── [108K]  MLO
> >     ├── [2.0K]  test
> >     │   └── [  12]  test2.bin
> >     ├── [  12]  test2.bin
> >     └── [ 560]  uEnv.txt
> >     Thanks,
> >     Nils
> >         Best regards
> >         Christian
> >         On 15/08/2019 19:32, Nils Hölscher wrote:
> >         > Hi Christian,
> >         > The commands ls and cat work.
> >         > I just tested them, this seems kinda awkward.
> >         > Best,
> >         > Nils
> >         > On Thu, 15 Aug 2019 at 19:27, Christian Mauderer
> >         <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >         > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
> wrote:
> >         >     Hello Nils,
> >         >     does some other access to the file system work? Like a ls
> >         on the console
> >         >     or creating a file. Can you do a `cat` on some text file
> >         on the file
> >         >     system? If not: Does it work for a file in the root file
> >         system (should
> >         >     be a IMFS)?
> >         >     Best regards
> >         >     Christian
> >         >     On 15/08/2019 15:54, Nils Hölscher wrote:
> >         >     > Hi,
> >         >     > I when my app wants to open a file on the SD card
> >         dev=mmcsd-0-0 rtems
> >         >     > freezes.
> >         >     > Exact call is:
> >         >     > fd = open(file, O_RDONLY);
> >         >     > With file being the pru binary I want to upload.
> >         >     > Thanks,
> >         >     > Nils
> >         >     > On Tue, 13 Aug 2019 at 17:56, Christian Mauderer
> >         >     > <christian.mauderer at embedded-brains.de
> >         <mailto:christian.mauderer at embedded-brains.de>
> >         <mailto:christian.mauderer at embedded-brains.de>>
> >         <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
> >         >     >     Hello Nils,
> >         >     >     a third possibility: You could start a FTP server
> >         and push the
> >         >     file
> >         >     >     via network.
> >         >     >     Best regards
> >         >     >     Christian
> >         >     >     Am Dienstag, 13. August 2019 schrieb Nils Hölscher:
> >         >     >     > Hi,
> >         >     >     > Thanks for the input I will try the SD card first.
> >         >     >     > That way I won't have to alter the code when I
> >         want to run other
> >         >     >     stuff on the pru.
> >         >     >     > Best,
> >         >     >     > Nils
> >         >     >     > On Tue, 13 Aug 2019 at 17:32, Gedare Bloom
> >         <gedare at rtems.org <mailto:gedare at rtems.org>
> >         >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
> >         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>> wrote:
> >         >     >     > You can also build the PRU image into the RTEMS
> >         binary. See
> >         >     >     > examples-v2.git/file_io/crc/init.c
> >         >     >     > On Tue, Aug 13, 2019 at 8:46 AM Christian Mauderer
> >         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> >         >     >     > > Hello Nils,
> >         >     >     > > that's a bit odd. I attached an expected output
> >         below.
> >         >     Some guesses:
> >         >     >     > > - Did you add FAT file system to your
> application?
> >         >     >     > > - Is there some odd formatting on the SD?
> >         Normally at
> >         >     least the FAT
> >         >     >     > > partition used by U-Boot should be visible.
> >         >     >     > > - Is your BDBUF configuration OK?
> >         >     >     > > - Do you have enough file descriptors?
> >         >     >     > > Beneath that: If you only need something where
> >         you can put
> >         >     some
> >         >     >     files,
> >         >     >     > > you can try to connect a USB stick instead.
> >         Maybe that
> >         >     works better.
> >         >     >     > > Best regards
> >         >     >     > > Christian
> >         >     >     > > media listener: event = DISK ATTACH, state =
> >         INQUIRY, src
> >         >     = mmcsd
> >         SUCCESS, src =
> >         >     >     mmcsd, dest
> >         >     >     > > = /dev/mmcsd-0
> >         >     >     > > media listener: event = MOUNT, state = INQUIRY,
> >         src =
> >         >     /dev/mmcsd-0
> >         >     >     > > mmcsd0: 4GB <SDHC TO 15.15 SN 000002F6 MFG
> >         02/2017 by 25
> >         >     DY> at mmc0
> >         >     >     > > 24.0MHz/4bit/65535-block
> >         >     >     > > media listener: event = MOUNT, state = FAILED,
> src =
> >         >     /dev/mmcsd-0
> >         >     >     > > media listener: event = PARTITION INQUIRY, state
> >         >     INQUIRY, src =
> >         >     >     > > /dev/mmcsd-0
> >         >     SUCCESS, src =
> >         >     >     > > /dev/mmcsd-0
> >         >     >     > > media listener: event = PARTITION ATTACH, state
> >         = INQUIRY,
> >         >     src =
> >         >     >     > > /dev/mmcsd-0
> >         = SUCCESS,
> >         >     src =
> >         >     >     > > /dev/mmcsd-0, dest = /dev/mmcsd-0-0
> >         src =
> >         >     /dev/mmcsd-0-0
> >         >     >     > > media listener: event = MOUNT, state = SUCCESS,
> >         src =
> >         >     >     /dev/mmcsd-0-0,
> >         >     >     > > dest = /media/mmcsd-0-0
> >         INQUIRY, src
> >         >     = mmcsd
> >         SUCCESS, src =
> >         >     >     mmcsd, dest
> >         >     >     > > = /dev/mmcsd-1
> >         src =
> >         >     /dev/mmcsd-1
> >         >     >     > > mmcsd1: 4GB <MMCHC MMC04G 5.8 SN 160D224B MFG
> >         09/2014 by 112
> >         >     >     0x0000> at
> >         >     >     > > mmc1 48.0MHz/8bit/65535-block
> src =
> >         >     /dev/mmcsd-1
> >         >     INQUIRY, src =
> >         >     >     > > /dev/mmcsd-1
> >         = FAILED,
> >         >     src =
> >         >     >     > > /dev/mmcsd-1
> >         INQUIRY, src =
> >         >     >     mmcsd1boot
> >         >     >     > > mmcsd1boot0: 2MB partion 1 at mmcsd1
> >         >     >     > > mmcsd1boot1: 2MB partion 2 at mmcsd1
> >         >     >     > > mmcsd1rpmb: 131kB partion 3 at mmcsd1
> >         >     >     > > On 13/08/2019 13:30, Nils Hölscher wrote:
> >         >     >     > > > Hi,
> >         >     >     > > > Thanks for the help.
> >         >     >     > > > I tried to use your code, but I always get
> >         "ERROR: SD
> >         >     could not be
> >         >     >     > > > mounted after timeout".
> >         >     >     > > > Even after raising the waiting time.
> >         >     >     > > > The sources I use start here:
> https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
> >         >     >     > > > And my uart output is:
> >         >     >     > > > waiting for SD...
> >         >     >     > > > usbus0: 480Mbps High Speed USB v2.0
> >         >     >     > > > usbus1: 480Mbps High Speed USB v2.0
> >         INQUIRY,
> >         >     src = mmcsd
> >         SUCCESS, src =
> >         >     >     mmcsd, dest
> >         >     >     > > > = /dev/mmcsd-0
> >         INQUIRY, src =
> >         >     /dev/mmcsd-0
> >         >     >     > > > ugen0.1: <Mentor Graphics OTG Root HUB> at
> usbus0
> >         >     >     > > > ugen1.1: <Mentor Graphics OTG Root HUB> at
> usbus1
> >         >     >     > > > uhub0: <Mentor Graphics OTG Root HUB, class
> >         9/0, rev
> >         >     >     2.00/1.00, addr 1>
> >         >     >     > > > on usbus0
> >         >     >     > > > uhub1: <Mentor Graphics OTG Root HUB, class
> >         9/0, rev
> >         >     >     2.00/1.00, addr 1>
> >         >     >     > > > on usbus1
> >         src =
> >         >     /dev/mmcsd-0
> state =
> >         >     INQUIRY, src =
> >         >     >     > > > /dev/mmcsd-0
> state =
> >         >     SUCCESS, src =
> >         >     >     > > > /dev/mmcsd-0
> state =
> >         >     INQUIRY, src =
> >         >     >     > > > /dev/mmcsd-0
> state =
> >         >     SUCCESS, src =
> >         INQUIRY, src =
> >         >     >     /dev/mmcsd-0-0
> >         src =
> >         >     >     /dev/mmcsd-0-0
> >         INQUIRY,
> >         >     src = mmcsd
> >         SUCCESS, src =
> >         >     >     mmcsd, dest
> >         >     >     > > > = /dev/mmcsd-1
> >         INQUIRY, src =
> >         >     /dev/mmcsd-1
> >         src =
> >         >     /dev/mmcsd-1
> state =
> >         >     INQUIRY, src =
> >         >     >     > > > /dev/mmcsd-1
> state =
> >         >     SUCCESS, src =
> >         >     >     > > > /dev/mmcsd-1
> state =
> >         >     INQUIRY, src =
> >         >     >     > > > /dev/mmcsd-1
> state =
> >         >     SUCCESS, src =
> >         >     >     > > > /dev/mmcsd-1, dest = /dev/mmcsd-1-0
> >         INQUIRY, src =
> >         >     >     /dev/mmcsd-1-0
> >         src =
> >         >     >     /dev/mmcsd-1-0
> >         INQUIRY, src =
> >         >     >     mmcsd1boot
> >         >     >     > > > uhub0: 1 port with 1 removable, self powered
> >         >     >     > > > uhub1: 1 port with 1 removable, self powered
> >         >     >     > > > ERROR: SD could not be mounted after timeout
> >         >     >     > > > Thanks,
> >         >     >     > > > Nils
> >         >     >     > > > On Mon, 12 Aug 2019 at 18:01, Christian
> Mauderer
> >         <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
> >         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>
> wrote:
> >         >     >     > > >     On 12/08/2019 07:28, Nils Hölscher wrote:
> >         >     >     > > >     > Hi,
> >         >     >     > > >     > Can anyone help me with this?
> >         >     >     > > >     > I need to access the BBB's SD-Card, so
> >         that I can load
> >         >     >     my pru
> >         >     >     > > >     example on
> >         >     >     > > >     > the pru.
> >         >     >     > > >     > Thanks,
> >         >     >     > > >     > Nils
> >         >     >     > > >     Hello Nils,
> >         >     >     > > >     take a look at the following application:
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/init.c#L64
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/libbsdhelper.c#L122
> >         >     >     > > >     You should mainly need the stuff from the
> >         >     >     libbsdhelper_init_sd_card()
> >         >     >     > > >     and libbsdhelper_wait_for_sd().
> >         >     >     > > >     Please note that the SD card needs quite
> >         some time to
> >         >     >     initialize on BBB.
> >         >     >     > > >     I haven't had a look at it why that is the
> >         case.
> >         >     >     > > >     Best regards
> >         >     >     > > >     Christian
> >         >     >     > > > _______________________________________________
> >         >     >     > > > users mailing list
> >         >     >     > > > users at rtems.org <mailto:users at rtems.org>
> >         <mailto:users at rtems.org <mailto:users at rtems.org>>
> >         <mailto:users at rtems.org <mailto:users at rtems.org>>>
> >         >     >     > > > http://lists.rtems.org/mailman/listinfo/users
> >         >     >     > > users mailing list
> >         >     >     embedded brains GmbH
> >         >     >     Herr Christian Mauderer
> >         >     >     Dornierstr. 4
> >         >     >     D-82178 Puchheim
> >         >     >     Germany
> >         >     >     email: christian.mauderer at embedded-brains.de
> >         >     >     Phone: +49-89-18 94 741 - 18
> >         >     >     Fax:   +49-89-18 94 741 - 08
> >         >     >     PGP: Public key available on request.
> >         >     >     Diese Nachricht ist keine geschäftliche Mitteilung
> >         im Sinne
> >         >     des EHUG.
> >         >     > users mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190816/773ef888/attachment-0002.html>
