[PATCH v1] Add steps to test Newlib patch.
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Fri Aug 16 14:32:32 UTC 2019
Sure,
Actually made this patch on different branch so used -v1.
Sending a new one with -v2.
-Vaibhav
On Fri, Aug 16, 2019, 7:58 PM Gedare Bloom <gedare at rtems.org> wrote:
> Then this should be sent with -v2.
> On Thu, Aug 15, 2019 at 1:33 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > On Thu, Aug 15, 2019 at 8:51 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> Is this a duplicate of the other "patch v1 Add steps to test Newlib
> patch." or this one replaces it?
> > This one replaces it. Actually I replaced all the previous ones with
> mine.
> > The commands, steps I have written are based on what worked for me for
> number of times.
> > I build the toolchain twice when RSB got updated, but my changes were
> not pushed so had to
> > use patches in RSB. And these steps worked perfectly both times.
> > -Vaibhav
> >> On Wed, Aug 14, 2019 at 11:45 PM Vaibhav Gupta <
> vaibhavgupta40 at gmail.com> wrote:
> >>> Update the checksum to be used for the Newlib patches.
> >>> Earlier it was msd5, but it is depreciated for security
> >>> reasons. Now RSB accepts sha512.
> >>> user/rsb/project-sets.rst | 41 +++++++++++++++++++++++++++++++++------
> >>> 1 file changed, 35 insertions(+), 6 deletions(-)
> >>> diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
> >>> index 5ffce26..b01857e 100644
> >>> --- a/user/rsb/project-sets.rst
> >>> +++ b/user/rsb/project-sets.rst
> >>> @@ -261,17 +261,46 @@ in the ``source-builder/config`` template
> configuration files.
> >>> To test a patch simply copy it to your local ``patches`` directory.
> The RSB
> >>> will see the patch is present and will not attempt to download it.
> Once you are
> >>> happy with the patch submit it to the project and a core developer
> will review
> >>> -it and add it to the RTEMS Tools git repository. For example, to
> test a local
> >>> -patch for newlib, add the following two lines to the .cfg file in
> >>> -``rtems/config/tools/`` that is included by the bset you use:
> >>> +it and add it to the RTEMS Tools git repository.
> >>> +Testing a Newlib Patch
> >>> +To test a local patch for newlib, you need to add the following
> >>> +two lines to the ``.cfg`` file in ``rsb/rtems/config/tools/`` that is
> included
> >>> +by the bset you use:
> >>> +.. topic:: Steps:
> >>> + 1. Create patches for the changes you want to test. (Note: For RSB,
> before
> >>> + creating Newlib patch, you must run ``autoreconf -fvi`` in the
> required
> >>> + directory after you make changes to the code. This is not
> required when
> >>> + you create patch to send to ``newlib-devel``. But if you want
> RSB to
> >>> + address your changes, your patch should also include regenerated
> files.)
> >>> + 2. Calculate ``sha512`` of your patch.
> >>> + 3. Place the patches in ``rsb/rtems/patches`` directory.
> >>> + 4. Open the ``.bset`` file used by your BSP in ``rsb/rtems/config``.
> >>> + For example, for ``rtems5``, ``SPARC``, the file will be
> >>> + ``rsb/rtems/config/5/rtems-sparc.bset``.
> >>> + 5. Inside it you will find the name of ``.cfg`` file for Newlib,
> used by
> >>> + your BSP.
> >>> + For example, I found ``tools/rtems-gcc-7.4.0-newlib-1d35a003f``.
> >>> + 6. Edit your ``.cfg`` file. In my case it will be,
> >>> + ``rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg``.
> And
> >>> + add the information about your patch as mentioned below.
> >>> .. code-block:: spec
> >>> - %patch add newlib file://0001-this-is-a-newlib-patch.patch <1>
> >>> - %hash md5 0001-this-is-a-newlib-patch.diff
> 77d070878112783292461bd6e7db17fb <2>
> >>> + %patch add newlib -p1 file://0001-Port-ndbm.patch <1>
> >>> + %hash sha512 0001-Port-ndbm.patch
> 7d999ceeea4f3dc82e8e0aadc09d983a7a68b44470da8a3d61ab6fc558fdba6f2c2de3acc2f32c0b0b97fcc9ab799c27e87afe046544a69519881f947e7881d1
> <2>
> >>> .. topic:: Items:
> >>> 1. The diff file prepended with ``file://`` to tell RSB this is a
> local file.
> >>> - 2. The output from md5sum on the diff file.
> >>> + 2. The output from sha512sum on the patch file.
> >>> 2.21.0
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190816/f6be9c7e/attachment-0002.html>
