LibBSD is not linking for the BBB BSP
    Vijay Kumar Banerjee
    vijaykumar9597 at gmail.com
    Sat Aug 31 18:41:07 UTC 2019
Hello Chris,
The libcurl is now building for BBB with libbsd HEAD on master after the
following commit :
https://git.rtems.org/rtems-libbsd/commit/?id=951c4b92cf8082272f998c02d9b79e664d6f1599
Best regards,
Vijay
On Wed, Aug 28, 2019 at 1:44 AM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On Wed, Aug 28, 2019 at 1:42 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> On 27/08/2019 21:43, Vijay Kumar Banerjee wrote:
>> > Hello,
>> > I have sent a patch that fixes this issue:
>> > https://lists.rtems.org/pipermail/devel/2019-August/027540.html
>> > Please try it with this patch.
>> > Christian: I have tested it with the sample app on BBB, can you please
>> > review it? :)
>> > Best regards
>> Hello Vijay,
>> I agree that it still works. But it is a bit odd. I'm quite sure that it
>> was necessary at some point to pull in the fb module to get the
>> initialization. Now the fb_attach and fb_detach functions are not pulled
>> in. It seems that the whole sys/dev/fb/fb.c file isn't necessary any
>> more. Maybe it would be good to try to remove that too? Otherwise it's
>> only dead code in libbsd.
>> OK. I'll try that and report.
>> Best regards
>> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190901/25c50edf/attachment-0002.html>
