LibBSD is not linking for the BBB BSP
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Aug 27 20:14:29 UTC 2019
On Wed, Aug 28, 2019 at 1:42 AM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 27/08/2019 21:43, Vijay Kumar Banerjee wrote:
> > Hello,
> > I have sent a patch that fixes this issue:
> > https://lists.rtems.org/pipermail/devel/2019-August/027540.html
> > Please try it with this patch.
> > Christian: I have tested it with the sample app on BBB, can you please
> > review it? :)
> > Best regards
> Hello Vijay,
> I agree that it still works. But it is a bit odd. I'm quite sure that it
> was necessary at some point to pull in the fb module to get the
> initialization. Now the fb_attach and fb_detach functions are not pulled
> in. It seems that the whole sys/dev/fb/fb.c file isn't necessary any
> more. Maybe it would be good to try to remove that too? Otherwise it's
> only dead code in libbsd.
> OK. I'll try that and report.
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190828/5b5faba0/attachment-0002.html>
