[PATCH 2/5] bsp/xen: Create empty template BSP for Xen
Jeff Kubascik
jeff.kubascik at dornerworks.com
Mon Dec 2 18:58:14 UTC 2019
Copied from no_cpu/no_bsp template
bsps/arm/xen/README | 66 ++++++++
bsps/arm/xen/config/no_bsp.cfg | 13 ++
bsps/arm/xen/console/console.c | 217 ++++++++++++++++++++++++++
bsps/arm/xen/headers.am | 10 ++
bsps/arm/xen/include/bsp.h | 57 +++++++
bsps/arm/xen/include/bsp/irq.h | 1 +
bsps/arm/xen/include/tm27.h | 1 +
bsps/arm/xen/start/bsp_specs | 7 +
bsps/arm/xen/start/bspstart.c | 27 ++++
bsps/arm/xen/start/linkcmds.in | 71 +++++++++
c/src/lib/libbsp/arm/xen/Makefile.am | 38 +++++
c/src/lib/libbsp/arm/xen/configure.ac | 19 +++
12 files changed, 527 insertions(+)
create mode 100644 bsps/arm/xen/README
create mode 100644 bsps/arm/xen/config/no_bsp.cfg
create mode 100644 bsps/arm/xen/console/console.c
create mode 100644 bsps/arm/xen/headers.am
create mode 100644 bsps/arm/xen/include/bsp.h
create mode 100644 bsps/arm/xen/include/bsp/irq.h
create mode 100644 bsps/arm/xen/include/tm27.h
create mode 100644 bsps/arm/xen/start/bsp_specs
create mode 100644 bsps/arm/xen/start/bspstart.c
create mode 100644 bsps/arm/xen/start/linkcmds.in
create mode 100644 c/src/lib/libbsp/arm/xen/Makefile.am
create mode 100644 c/src/lib/libbsp/arm/xen/configure.ac
diff --git a/bsps/arm/xen/README b/bsps/arm/xen/README
new file mode 100644
index 0000000000..1b24d84c9a
--- /dev/null
+++ b/bsps/arm/xen/README
@@ -0,0 +1,66 @@
+# This is a sample hardware description file for a BSP. This comment
+# block does not have to appear in a real one. The intention of this
+# file is to provide a central place to look when searching for
+# information about a board when starting a new BSP. For example,
+# you may want to find an existing timer driver for the chip you are
+# using on your board. It is easier to grep for the chip name in
+# all of the HARDWARE files than to peruse the source tree. Hopefully,
+# making the HARDDWARE files accurate will also alleviate the common
+# problem of not knowing anything about a board based on its BSP
+# name.
+# NOTE: If you have a class of peripheral chip on board which
+# is not in this list please add it to this file so
+# others will also use the same name.
+# Timer resolution is the way it is configured in this BSP.
+# On a counting timer, this is the length of time which
+# corresponds to 1 count.
+BSP NAME: fastsbc1
+BOARD: Fasssst Computers, Fast SBC-1
+BUS: SchoolBus
+CPU FAMILY: i386
+CPU: Intel Hexium
+COPROCESSORS: Witch Hex87
+MODE: 32 bit mode
+DEBUG MONITOR: HexBug
+PERIPHERALS
+TIMERS: Intel i8254
+ RESOLUTION: .0001 microseconds
+SERIAL PORTS: Zilog Z8530 (with 2 ports)
+REAL-TIME CLOCK: RTC-4
+DMA: Intel i8259
+VIDEO: none
+SCSI: none
+NETWORKING: none
+DRIVER INFORMATION
+CLOCK DRIVER: RTC-4
+IOSUPP DRIVER: Zilog Z8530 port A
+SHMSUPP: polled and interrupts
+TIMER DRIVER: Intel i8254
+TTY DRIVER: stub only
+STDIO
+PORT: Console port 0
+ELECTRICAL: RS-232
+BAUD: 9600
+BITS PER CHARACTER: 8
+PARITY: None
+STOP BITS: 1
+NOTES
+(1) 900 Mhz and 950 Mhz versions.
+(2) 1 Gb or 2 Gb RAM.
+(3) PC compatible if HexBug not enabled.
diff --git a/bsps/arm/xen/config/no_bsp.cfg b/bsps/arm/xen/config/no_bsp.cfg
index 0000000000..15e2f29bff
--- /dev/null
+++ b/bsps/arm/xen/config/no_bsp.cfg
@@ -0,0 +1,13 @@
+# Configuration file for the "no_bsp" board
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU=no_cpu
+# Miscellaneous additions go here. Typical options usually look like
+CFLAGS_OPTIMIZE_V += -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
diff --git a/bsps/arm/xen/console/console.c b/bsps/arm/xen/console/console.c
index 0000000000..41c17c29ef
--- /dev/null
+++ b/bsps/arm/xen/console/console.c
@@ -0,0 +1,217 @@
+ * This file contains the template for a console IO package.
+ * COPYRIGHT (c) 1989-1999.
+ * On-Line Applications Research Corporation (OAR).
+#define NO_BSP_INIT
+#include <bsp.h>
+#include <rtems/libio.h>
+/* console_initialize
+ * This routine initializes the console IO driver.
+ * Input parameters: NONE
+ * Output parameters: NONE
+ * Return values:
+rtems_device_driver console_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ rtems_status_code status;
+ status = rtems_io_register_name(
+ "/dev/console",
+ major,
+ (rtems_device_minor_number) 0
+ if (status != RTEMS_SUCCESSFUL)
+ rtems_fatal_error_occurred(status);
+ return RTEMS_SUCCESSFUL;
+/* is_character_ready
+ * This routine returns TRUE if a character is available.
+ * Return values:
+bool is_character_ready(
+ char *ch
+ *ch = '\0'; /* return NULL for no particular reason */
+ return true;
+/* inbyte
+ * This routine reads a character from the SOURCE.
+ * Return values:
+ * character read from SOURCE
+char inbyte( void )
+ * If polling, wait until a character is available.
+ return '\0';
+/* outbyte
+ * This routine transmits a character out the SOURCE. It may support
+ * XON/XOFF flow control.
+ * ch - character to be transmitted
+void outbyte(
+ char ch
+ * If polling, wait for the transmitter to be ready.
+ * Check for flow control requests and process.
+ * Then output the character.
+ * Carriage Return/New line translation.
+ if ( ch == '\n' )
+ outbyte( '\r' );
+ * Open entry point
+rtems_device_driver console_open(
+ void * arg
+ * Close entry point
+rtems_device_driver console_close(
+ void * arg
+ * read bytes from the serial port. We only have stdin.
+rtems_device_driver console_read(
+ void * arg
+ rtems_libio_rw_args_t *rw_args;
+ char *buffer;
+ int maximum;
+ int count = 0;
+ rw_args = (rtems_libio_rw_args_t *) arg;
+ buffer = rw_args->buffer;
+ maximum = rw_args->count;
+ for (count = 0; count < maximum; count++) {
+ buffer[ count ] = inbyte();
+ if (buffer[ count ] == '\n' || buffer[ count ] == '\r') {
+ buffer[ count++ ] = '\n';
+ break;
+ rw_args->bytes_moved = count;
+ return (count >= 0) ? RTEMS_SUCCESSFUL : RTEMS_UNSATISFIED;
+ * write bytes to the serial port. Stdout and stderr are the same.
+rtems_device_driver console_write(
+ void * arg
+ int count;
+ int maximum;
+ char *buffer;
+ if ( buffer[ count ] == '\n') {
+ outbyte('\r');
+ outbyte( buffer[ count ] );
+ rw_args->bytes_moved = maximum;
+ return 0;
+ * IO Control entry point
+rtems_device_driver console_control(
+ void * arg
diff --git a/bsps/arm/xen/headers.am b/bsps/arm/xen/headers.am
index 0000000000..fe2f157349
--- /dev/null
+++ b/bsps/arm/xen/headers.am
@@ -0,0 +1,10 @@
+## This file was generated by "./boostrap -H".
+include_HEADERS =
+include_HEADERS += ../../../../../../bsps/no_cpu/no_bsp/include/bsp.h
+include_HEADERS += include/bspopts.h
+include_HEADERS += ../../../../../../bsps/no_cpu/no_bsp/include/tm27.h
+include_bspdir = $(includedir)/bsp
+include_bsp_HEADERS =
+include_bsp_HEADERS += ../../../../../../bsps/no_cpu/no_bsp/include/bsp/irq.h
diff --git a/bsps/arm/xen/include/bsp.h b/bsps/arm/xen/include/bsp.h
index 0000000000..46a20fc831
--- /dev/null
+++ b/bsps/arm/xen/include/bsp.h
@@ -0,0 +1,57 @@
+ * @file
+ * @ingroup RTEMSBSPsNoCPUNoBsp
+ * @brief Global BSP definitions.
+/* bsp.h
+ * This include file contains all board IO definitions.
+ * XXX : put yours in here
+#ifndef LIBBSP_NO_CPU_NO_BSP_BSP_H
+#define LIBBSP_NO_CPU_NO_BSP_BSP_H
+ * @addtogroup RTEMSBSPsNoCPU
+#include <bspopts.h>
+#include <bsp/default-initial-extension.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* functions */
+rtems_isr_entry set_vector( /* returns old vector */
+ rtems_isr_entry handler, /* isr routine */
+ rtems_vector_number vector, /* vector number */
+ int type /* RTEMS or RAW intr */
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/arm/xen/include/bsp/irq.h b/bsps/arm/xen/include/bsp/irq.h
index 0000000000..8a97d7a1b0
--- /dev/null
+++ b/bsps/arm/xen/include/bsp/irq.h
@@ -0,0 +1 @@
+#include <bsp/irq-default.h>
diff --git a/bsps/arm/xen/include/tm27.h b/bsps/arm/xen/include/tm27.h
index 0000000000..0dfa7bf628
--- /dev/null
+++ b/bsps/arm/xen/include/tm27.h
@@ -0,0 +1 @@
+#include <rtems/tm27-default.h>
diff --git a/bsps/arm/xen/start/bsp_specs b/bsps/arm/xen/start/bsp_specs
index 0000000000..140802f2c0
--- /dev/null
+++ b/bsps/arm/xen/start/bsp_specs
@@ -0,0 +1,7 @@
+%rename lib old_lib
+*lib:
+%{!qrtems: %(old_lib)} \
+%{!nostdlib: %{qrtems: --start-group -lrtemsbsp -lrtemscpu -lc -lgcc --end-group \
+%{!qnolinkcmds: -T linkcmds%s}}}
diff --git a/bsps/arm/xen/start/bspstart.c b/bsps/arm/xen/start/bspstart.c
index 0000000000..b77b971ca1
--- /dev/null
+++ b/bsps/arm/xen/start/bspstart.c
@@ -0,0 +1,27 @@
+ * This routine starts the application. It includes application,
+ * board, and monitor specific initialization and configuration.
+ * The generic CPU dependent initialization has been performed
+ * before this routine is invoked.
+#include <string.h>
+#include <bsp.h>
+ * bsp_start
+ * This routine does the bulk of the system initialization.
+void bsp_start( void )
diff --git a/bsps/arm/xen/start/linkcmds.in b/bsps/arm/xen/start/linkcmds.in
index 0000000000..6f2fda7b41
--- /dev/null
+++ b/bsps/arm/xen/start/linkcmds.in
@@ -0,0 +1,71 @@
+ * This file contains directives for the GNU linker which are specific
+ * to the NO_CPU NO_BSP BOARD.
+MEMORY
+ ram : org = 0x0, l = 1M
+SECTIONS
+ .text 0x0 :
+ text_start = . ;
+ _text_start = . ;
+ *(.text)
+ . = ALIGN (16);
+ * Special FreeBSD sysctl sections.
+ . = ALIGN (16);
+ __start_set_sysctl_set = .;
+ *(set_sysctl_*);
+ __stop_set_sysctl_set = ABSOLUTE(.);
+ *(set_domain_*);
+ *(set_pseudo_*);
+ *(.eh_fram)
+ . = ALIGN (16);
+ * C++ constructors
+ __CTOR_LIST__ = .;
+ LONG((__CTOR_END__ - __CTOR_LIST__) / 4 - 2)
+ *(.ctors)
+ LONG(0)
+ __CTOR_END__ = .;
+ __DTOR_LIST__ = .;
+ LONG((__DTOR_END__ - __DTOR_LIST__) / 4 - 2)
+ *(.dtors)
+ LONG(0)
+ __DTOR_END__ = .;
+ _etext = ALIGN( 0x10 ) ;
+ .data ADDR( .text ) + SIZEOF( .text ):
+ data_start = . ;
+ _data_start = . ;
+ *(.data)
+ _edata = ALIGN( 0x10 ) ;
+ .bss ADDR( .data ) + SIZEOF( .data ):
+ bss_start = . ;
+ _bss_start = . ;
+ *(.bss)
+ *(COMMON)
+ end = . ;
+ __end = . ;
diff --git a/c/src/lib/libbsp/arm/xen/Makefile.am b/c/src/lib/libbsp/arm/xen/Makefile.am
index 0000000000..9f9b6426bd
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xen/Makefile.am
@@ -0,0 +1,38 @@
+ACLOCAL_AMFLAGS = -I ../../../../aclocal
+include $(top_srcdir)/../../../../automake/compile.am
+include $(top_srcdir)/../../bsp.am
+dist_project_lib_DATA = ../../../../../../bsps/no_cpu/no_bsp/start/bsp_specs
+noinst_PROGRAMS =
+project_lib_DATA = linkcmds
+project_lib_LIBRARIES = librtemsbsp.a
+librtemsbsp_a_SOURCES =
+# startup
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-default.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/start/bspstart.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/start/setvec.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
+# clock
+librtemsbsp_a_SOURCES +=../../../../../../bsps/no_cpu/no_bsp/clock/ckinit.c
+# console
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/console/console.c
+# timer
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/btimer/btimer.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/btimer/timerisr.c
+# shmsupp
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/mpci/addrconv.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/mpci/getcfg.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/mpci/lock.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/no_cpu/no_bsp/mpci/mpisr.c
+include $(srcdir)/../../../../../../bsps/shared/irq-default-sources.am
+include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
+include $(srcdir)/../../../../../../bsps/no_cpu/no_bsp/headers.am
diff --git a/c/src/lib/libbsp/arm/xen/configure.ac b/c/src/lib/libbsp/arm/xen/configure.ac
index 0000000000..3e54ec9f34
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xen/configure.ac
@@ -0,0 +1,19 @@
+## Process this file with autoconf to produce a configure script.
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-no_cpu-no_bsp],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
+RTEMS_TOP(../../../../../..)
+RTEMS_SOURCE_TOP
+RTEMS_BUILD_TOP
+RTEMS_BSP_LINKCMDS
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_BSP_CLEANUP_OPTIONS
+# Explicitly list all Makefiles here
+AC_CONFIG_FILES([Makefile])
+AC_OUTPUT
2.17.1
