[PATCH 5/5] bsp/xen: Update README
Jeff Kubascik
jeff.kubascik at dornerworks.com
Mon Dec 2 18:59:29 UTC 2019
Add some background information on the BSP and instructions on how to
run the ticker application.
bsps/arm/xen/README | 130 ++++++++++++++++++++++----------------------
1 file changed, 64 insertions(+), 66 deletions(-)
diff --git a/bsps/arm/xen/README b/bsps/arm/xen/README
index 1b24d84c9a..2ae2f2170d 100644
--- a/bsps/arm/xen/README
+++ b/bsps/arm/xen/README
@@ -1,66 +1,64 @@
-# This is a sample hardware description file for a BSP. This comment
-# block does not have to appear in a real one. The intention of this
-# file is to provide a central place to look when searching for
-# information about a board when starting a new BSP. For example,
-# you may want to find an existing timer driver for the chip you are
-# using on your board. It is easier to grep for the chip name in
-# all of the HARDWARE files than to peruse the source tree. Hopefully,
-# making the HARDDWARE files accurate will also alleviate the common
-# problem of not knowing anything about a board based on its BSP
-# name.
-# NOTE: If you have a class of peripheral chip on board which
-# is not in this list please add it to this file so
-# others will also use the same name.
-# Timer resolution is the way it is configured in this BSP.
-# On a counting timer, this is the length of time which
-# corresponds to 1 count.
-BSP NAME: fastsbc1
-BOARD: Fasssst Computers, Fast SBC-1
-BUS: SchoolBus
-CPU FAMILY: i386
-CPU: Intel Hexium
-COPROCESSORS: Witch Hex87
-MODE: 32 bit mode
-DEBUG MONITOR: HexBug
-PERIPHERALS
-TIMERS: Intel i8254
- RESOLUTION: .0001 microseconds
-SERIAL PORTS: Zilog Z8530 (with 2 ports)
-REAL-TIME CLOCK: RTC-4
-DMA: Intel i8259
-VIDEO: none
-SCSI: none
-NETWORKING: none
-DRIVER INFORMATION
-CLOCK DRIVER: RTC-4
-IOSUPP DRIVER: Zilog Z8530 port A
-SHMSUPP: polled and interrupts
-TIMER DRIVER: Intel i8254
-TTY DRIVER: stub only
-STDIO
-PORT: Console port 0
-ELECTRICAL: RS-232
-BAUD: 9600
-BITS PER CHARACTER: 8
-PARITY: None
-STOP BITS: 1
-NOTES
-(1) 900 Mhz and 950 Mhz versions.
-(2) 1 Gb or 2 Gb RAM.
-(3) PC compatible if HexBug not enabled.
+BSP for Xen on ARM
+Overview
+This BSP enables RTEMS to run as a guest virtual machine in AArch32 mode on the
+Xen hypervisor for ARMv8 platforms.
+Drivers:
+- Clock: ARMv7-AR Generic Timer
+- Console: Virtual PL011 device
+- Interrupt: GICv2
+BSP variants:
+- xen_virtual: completely virtualized guest with no dependence on underlying
+ hardware
+The xen_virtual BSP variant relies on standard Xen features, so it should be
+able to run on any ARMv8 platform.
+Xen allows for the passthrough of hardware peripherals to guest virtual
+machines. BSPs could be added in the future targeting specific hardware
+platforms and include the appropriate drivers.
+This BSP was tested with Xen running on the Xilinx Zynq UltraScale+ MPSoC using
+the Virtuosity distribution maintained by DornerWorks.
+Execution
+This procedure describes how to run the ticker sample application that should
+already be built with the BSP.
+The `ticker.exe` file can be found in the BSP build tree at:
+ arm-rtems5/c/xen_virtual/testsuites/samples/ticker.exe
+The `ticker.exe` elf file must be translated to a binary format.
+ arm-rtems5-objcopy -O binary ticker.exe ticker.bin
+Then place the `ticker.bin` file on the dom0 filesystem.
+From the dom0 console, create a configuration file `ticker.cfg` with the
+following contents.
+ name = "ticker"
+ kernel = "ticker.bin"
+ memory = 8
+ vcpus = 1
+ gic_version = "v2"
+ vuart = "sbsa_uart"
+Create the virtual machine and attach to the virtual vpl011 console.
+ xl create ticker.cfg && xl console -t vuart ticker
+To return back to the dom0 console, press both `Ctrl` and `]` on your keyboard.
+Additional information
+The Virtuosity distribution can be found at
+ https://dornerworks.com/xen/virtuosity
2.17.1
