[PATCH 4/5] bsps/arm: Unmask generic timer in interrupt handler
Jeff Kubascik
jeff.kubascik at dornerworks.com
Tue Dec 3 14:29:39 UTC 2019
On 12/3/2019 1:22 AM, Sebastian Huber wrote:
> On 02/12/2019 19:58, Jeff Kubascik wrote:
>> Xen will mask the virtual timer before injecting the interrupt to the
>> guest.
>> bsps/arm/shared/clock/clock-generic-timer.c | 1 +
>> 1 file changed, 1 insertion(+)
>> diff --git a/bsps/arm/shared/clock/clock-generic-timer.c b/bsps/arm/shared/clock/clock-generic-timer.c
>> index 1369a5d6f1..cedf1c40fd 100644
>> --- a/bsps/arm/shared/clock/clock-generic-timer.c
>> +++ b/bsps/arm/shared/clock/clock-generic-timer.c
>> @@ -90,6 +90,7 @@ static void arm_gt_clock_at_tick(void)
>> cval = arm_gt_clock_get_compare_value();
>> cval += interval;
>> arm_gt_clock_set_compare_value(cval);
>> + arm_gt_clock_set_control(0x1);
>> static void arm_gt_clock_handler_install(void)
> Please add an option like this
> * The BSP may optionally define ARM_GENERIC_TIMER_USE_VIRTUAL in
> <bsp.h> to
> * use the virtual timer instead of the physical timer.
> to set the control register in arm_gt_clock_at_tick().
Understood, I will create a new option for this Xen workaround. I'm thinking
something like ARM_GENERIC_TIMER_UNMASK_AT_TICK?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Sincerely,
Jeff Kubascik
