[PATCH] libtest: Change expected fail state string
Wed Dec 4 04:14:35 UTC 2019
On 3/12/19 9:59 pm, Sebastian Huber wrote:
> On 02/12/2019 23:32, Chris Johns wrote:
>> On 2/12/19 6:24 pm, Sebastian Huber wrote:
>>> Use the value expected by the RTEMS Tester.  There are two separator
>>> characters used ('-' and '_') for the states.  This is a bit
>>> inconsistent.
>> Sorry about this. I had not noticed.
>>>   cpukit/libtest/testbeginend.c | 2 +-
>>>   1 file changed, 1 insertion(+), 1 deletion(-)
>>> diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
>>> index b739e47b2e..9bdc86780c 100644
>>> --- a/cpukit/libtest/testbeginend.c
>>> +++ b/cpukit/libtest/testbeginend.c
>>> @@ -29,7 +29,7 @@ rtems_printer rtems_test_printer = {
>>>   static const char* const test_state_strings[] =
>>>     "EXPECTED-PASS",
>> Should this change or should `USER_INPUT` be changed and we update ...
>> https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n159
>> https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n161
>> It would be a simpler change because this change means we move to having 2 with
>> `_` and a bunch with `-`. There are internal states in the tester such as
>> `WRONG-VERSION` and changing all of those is a bigger change in the tester.
> If we update the tester, then it should accept '-' and '_' versions so that it
> can be used for test runs before and after a change of
> cpukit/libtest/testbeginend.c.
Yes this is a good point. Shame it has to be this way but I cannot see an
alternative.
