[PATCH] libtest: Change expected fail state string
Wed Dec 4 06:43:26 UTC 2019
On 04/12/2019 05:14, Chris Johns wrote:
> On 3/12/19 9:59 pm, Sebastian Huber wrote:
>> On 02/12/2019 23:32, Chris Johns wrote:
>>> On 2/12/19 6:24 pm, Sebastian Huber wrote:
>>>> Use the value expected by the RTEMS Tester.  There are two separator
>>>> characters used ('-' and '_') for the states.  This is a bit
>>>> inconsistent.
>>> Sorry about this. I had not noticed.
>>>>    cpukit/libtest/testbeginend.c | 2 +-
>>>>    1 file changed, 1 insertion(+), 1 deletion(-)
>>>> diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
>>>> index b739e47b2e..9bdc86780c 100644
>>>> --- a/cpukit/libtest/testbeginend.c
>>>> +++ b/cpukit/libtest/testbeginend.c
>>>> @@ -29,7 +29,7 @@ rtems_printer rtems_test_printer = {
>>>>    static const char* const test_state_strings[] =
>>>>      "EXPECTED-PASS",
>>> Should this change or should `USER_INPUT` be changed and we update ...
>>> https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n159
>>> https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n161
>>> It would be a simpler change because this change means we move to having 2 with
>>> `_` and a bunch with `-`. There are internal states in the tester such as
>>> `WRONG-VERSION` and changing all of those is a bigger change in the tester.
>> If we update the tester, then it should accept '-' and '_' versions so that it
>> can be used for test runs before and after a change of
>> cpukit/libtest/testbeginend.c.
> Yes this is a good point. Shame it has to be this way but I cannot see an
> alternative.
I checked in the patch as is. Using only one separator character for all
states is just a beautification.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
