[PATCH] libtest: Change expected fail state string
Wed Dec 4 08:57:20 UTC 2019
On 04/12/2019 09:49, Chris Johns wrote:
> On 4/12/19 5:43 pm, Sebastian Huber wrote:
>> On 04/12/2019 05:14, Chris Johns wrote:
>>> On 3/12/19 9:59 pm, Sebastian Huber wrote:
>>>> On 02/12/2019 23:32, Chris Johns wrote:
>>>>> On 2/12/19 6:24 pm, Sebastian Huber wrote:
>>>>>> Use the value expected by the RTEMS Tester.  There are two separator
>>>>>> characters used ('-' and '_') for the states.  This is a bit
>>>>>> inconsistent.
>>>>> Sorry about this. I had not noticed.
>>>>>>     cpukit/libtest/testbeginend.c | 2 +-
>>>>>>     1 file changed, 1 insertion(+), 1 deletion(-)
>>>>>> diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
>>>>>> index b739e47b2e..9bdc86780c 100644
>>>>>> --- a/cpukit/libtest/testbeginend.c
>>>>>> +++ b/cpukit/libtest/testbeginend.c
>>>>>> @@ -29,7 +29,7 @@ rtems_printer rtems_test_printer = {
>>>>>>     static const char* const test_state_strings[] =
>>>>>>       "EXPECTED-PASS",
>>>>> Should this change or should `USER_INPUT` be changed and we update ...
>>>>> https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n159
>>>>> https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n161
>>>>> It would be a simpler change because this change means we move to having 2 with
>>>>> `_` and a bunch with `-`. There are internal states in the tester such as
>>>>> `WRONG-VERSION` and changing all of those is a bigger change in the tester.
>>>> If we update the tester, then it should accept '-' and '_' versions so that it
>>>> can be used for test runs before and after a change of
>>>> cpukit/libtest/testbeginend.c.
>>> Yes this is a good point. Shame it has to be this way but I cannot see an
>>> alternative.
>> I checked in the patch as is. Using only one separator character for all states
>> is just a beautification.
> That is not what I was meaning. I would like RTEMS master to use only '-' and
> the tester has backward compatibility.
I would change everything to '_' separators since we have also the RTEMS
options:
*** BEGIN OF TEST SMPMIGRATION 2 ***
*** TEST VERSION: 5.0.0.a6879a418dee37c31728af0d2491cb8924f23de3
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB
f3b44b25d1353253d1454abc695621aafb8c4a97, Newlib d14714c69)
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
