[PATCH] libtest: Change expected fail state string
Wed Dec 4 11:59:56 UTC 2019
On Wed, Dec 4, 2019, 3:57 AM Sebastian Huber <
> On 04/12/2019 09:49, Chris Johns wrote:
> > On 4/12/19 5:43 pm, Sebastian Huber wrote:
> >> On 04/12/2019 05:14, Chris Johns wrote:
> >>> On 3/12/19 9:59 pm, Sebastian Huber wrote:
> >>>> On 02/12/2019 23:32, Chris Johns wrote:
> >>>>> On 2/12/19 6:24 pm, Sebastian Huber wrote:
> >>>>>> Use the value expected by the RTEMS Tester.  There are two separator
> >>>>>> characters used ('-' and '_') for the states.  This is a bit
> >>>>>> inconsistent.
> >>>>> Sorry about this. I had not noticed.
> >>>>>>     cpukit/libtest/testbeginend.c | 2 +-
> >>>>>>     1 file changed, 1 insertion(+), 1 deletion(-)
> >>>>>> diff --git a/cpukit/libtest/testbeginend.c
> b/cpukit/libtest/testbeginend.c
> >>>>>> index b739e47b2e..9bdc86780c 100644
> >>>>>> --- a/cpukit/libtest/testbeginend.c
> >>>>>> +++ b/cpukit/libtest/testbeginend.c
> >>>>>> @@ -29,7 +29,7 @@ rtems_printer rtems_test_printer = {
> >>>>>>     static const char* const test_state_strings[] =
> >>>>>>       "EXPECTED-PASS",
> >>>>> Should this change or should `USER_INPUT` be changed and we update
> >>>>> https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n159
> >>>>> https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n161
> >>>>> It would be a simpler change because this change means we move to
> having 2 with
> >>>>> `_` and a bunch with `-`. There are internal states in the tester
> such as
> >>>>> `WRONG-VERSION` and changing all of those is a bigger change in the
> tester.
> >>>> If we update the tester, then it should accept '-' and '_' versions
> so that it
> >>>> can be used for test runs before and after a change of
> >>>> cpukit/libtest/testbeginend.c.
> >>> Yes this is a good point. Shame it has to be this way but I cannot see
> an
> >>> alternative.
> >> I checked in the patch as is. Using only one separator character for
> all states
> >> is just a beautification.
> > That is not what I was meaning. I would like RTEMS master to use only
> '-' and
> > the tester has backward compatibility.
> I would change everything to '_' separators since we have also the RTEMS
> options:
Dashes are often used as separators so can be questionable to use in
strings intended to be a single token.
> *** BEGIN OF TEST SMPMIGRATION 2 ***
> *** TEST VERSION: 5.0.0.a6879a418dee37c31728af0d2491cb8924f23de3
> *** TEST STATE: EXPECTED-PASS
> *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB
> f3b44b25d1353253d1454abc695621aafb8c4a97, Newlib d14714c69)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191204/5d8607f7/attachment.html>
