License and copyright of specification items
Wed Dec 4 11:58:41 UTC 2019
On Wed, Dec 4, 2019, 4:05 AM Sebastian Huber <
> On 22/11/2019 14:32, Sebastian Huber wrote:
> > Hello,
> > some specification items may contain copyrightable information. Doorstop
> > removes all comments from YAML files. So, my proposal is to add two
> > attributes to every specification item:
> > 1.
> > license: 'SPDX-License-Identifier: BSD-2-Clause OR CC-BY-SA-4.0'
> > This allows the use of content from specification items as source code
> > and documentation input.
> > 2.
> > copyrights:
> > - 'Copyright (C) 2019 John Doe'
> I think we have a consensus to use a dual-licensing for the
> specification items. Should we add this
> attribute to every item to make it self-contained, or should we just add a
> spec/COPYING
> file (see attached proposal).
> Each item should have individual "copyrights" attributes which list the
> copyright holders of this item.
I lean to repeated in each file because it makes it more explicit.
I also lean this way based on the assumption that tools which process SPDX
tags will produce better reports if every file has annotations. This may be
an incorrect assumption.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191204/673f549e/attachment.html>
