Zynq driver development strategy
Mathew Benson
mbenson at windhoverlabs.com
Wed Dec 4 16:45:47 UTC 2019
Is there any technical or legal (licensing) reason why I can't just
integrate the driver code generated by the Xilinx XSDK tool when building a
standalone or FreeRTOS project? It's the same code for both. I did a
dependency check and, assuming I didn't miss any externs or implicit
declarations, the SPI driver code is highly coherent and loosely coupled
with the rest of the code. I only have to bring in a few files that were
not SPI specific. It looks like I just need to basically write a simple
interface layer between RTEMS and the Xilinx code and the functionality
seems fairly complementary. Over about 15 minutes, I added the SPI driver
code to my Zynq BSP build and it built with no errors or warnings. I
haven't got to actually integrating the RTEMS SPI driver API to the Xilinx
SPI driver API yet. This seems like a clear and concise strategy. Am I
going to run into a roadblock later? Either for my own project or as a
give back to the RTEMS base code.
*Mathew Benson*
CEO | Chief Engineer
Windhover Labs, LLC
832-640-4018
www.windhoverlabs.com
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191204/123db7eb/attachment.html>
