[PATCH] bsp/xen: Create README
Jeff Kubascik jeff.kubascik at dornerworks.com
Fri Dec 20 15:58:03 UTC 2019
On 12/20/2019 9:40 AM, Joel Sherrill wrote:
> I fixed a few things with this and pushed it.
> + Needed to be included in bsps-arm.rst to show up in the doc
> + Had some incorrect markup.
> Thanks. If it needs more, just send another patch.
> Happy holidays!
> --joel
> On Fri, Dec 20, 2019 at 7:34 AM Jeff Kubascik <jeff.kubascik at dornerworks.com
> <mailto:jeff.kubascik at dornerworks.com>> wrote:
>     Hello,
>     On 12/4/2019 10:43 AM, Hesham Almatary wrote:
>     > Thanks Jeff!
>     > On Wed, 4 Dec 2019 at 14:53, Jeff Kubascik
>     > <jeff.kubascik at dornerworks.com <mailto:jeff.kubascik at dornerworks.com>> wrote:
>     >> Add a README for the new xen bsp.
>     >>  user/bsps/arm/xen.rst | 79 +++++++++++++++++++++++++++++++++++++++++++
>     >>  1 file changed, 79 insertions(+)
>     >>  create mode 100644 user/bsps/arm/xen.rst
>     >> diff --git a/user/bsps/arm/xen.rst b/user/bsps/arm/xen.rst
>     >> new file mode 100644
>     >> index 0000000..e499f5d
>     >> --- /dev/null
>     >> +++ b/user/bsps/arm/xen.rst
>     >> @@ -0,0 +1,79 @@
>     >> +.. SPDX-License-Identifier: CC-BY-SA-4.0
>     >> +.. Copyright (C) 2019 DornerWorks
>     >> +.. Copyright (C) 2019 Jeff Kubascik <jeff.kubascik at dornerworks.com
>     >> +xen (Xen on ARM)
>     >> +This BSP enables RTEMS to run as a guest virtual machine in AArch32 mode
>     on the
>     >> +Xen hypervisor for ARMv8 platforms.
>     >> +Drivers:
>     >> +* Clock: ARMv7-AR Generic Timer
>     >> +* Console: Virtual PL011 device
>     >> +* Interrupt: GICv2
>     >> +BSP variants:
>     >> +* xen_virtual: completely virtualized guest with no dependence on underlying
>     >> +  hardware
>     >> +The xen_virtual BSP variant relies on standard Xen features, so it should be
>     >> +able to run on any ARMv8 platform.
>     >> +Xen allows for the passthrough of hardware peripherals to guest virtual
>     >> +machines. BSPs could be added in the future targeting specific hardware
>     >> +platforms and include the appropriate drivers.
>     > Does RTEMS itself get rescheduled by Xen/Dom0? If yes, how might that
>     > affect the realtime requirements?
>     Apologies, I missed this comment when I originally read your response.
>     The answer is it depends on how you configure Xen. For anything with hard
>     realtime requirements, you would either (a) use the null scheduler, so that Xen
>     will never switch the guest out of context or (b) use the ARINC653 scheduler to
>     set up deterministic time-slice scheduling of the guests.
>     >> +This BSP was tested with Xen running on the Xilinx Zynq UltraScale+
>     MPSoC using
>     >> +the Virtuosity distribution maintained by DornerWorks.
>     >> +Execution
>     >> +This procedure describes how to run the ticker sample application that
>     should
>     >> +already be built with the BSP.
>     >> +The ``ticker.exe`` file can be found in the BSP build tree at:
>     >> +.. code-block:: none
>     >> +    arm-rtems5/c/xen_virtual/testsuites/samples/ticker.exe
>     >> +The ``ticker.exe`` elf file must be translated to a binary format.
>     >> +    arm-rtems5-objcopy -O binary ticker.exe ticker.bin
>     >> +Then place the ``ticker.bin`` file on the dom0 filesystem.
>     >> +From the dom0 console, create a configuration file ``ticker.cfg`` with the
>     >> +following contents.
>     >> +..code-block:: none
>     >> +    name = "ticker"
>     >> +    kernel = "ticker.bin"
>     >> +    memory = 8
>     >> +    vcpus = 1
>     >> +    gic_version = "v2"
>     >> +    vuart = "sbsa_uart"
>     >> +Create the virtual machine and attach to the virtual vpl011 console.
>     >> +    xl create ticker.cfg && xl console -t vuart ticker
>     >> +To return back to the dom0 console, press both ``Ctrl`` and ``]`` on your
>     >> +keyboard.
>     >> +Additional Information
>     >> +* `Virtuosity distribution <https://dornerworks.com/xen/virtuosity>`_
>     >> 2.17.1
>     >> _______________________________________________
>     >> devel mailing list
>     >> devel at rtems.org <mailto:devel at rtems.org>
>     >> http://lists.rtems.org/mailman/listinfo/devel
>     I took a look at the rtems-docs repository today and didn't see this patch.
>     Other than the missed response above, is there anything else that needs to be
>     done here?
>     Sincerely,
>     Jeff Kubascik
>     devel mailing list
Thanks Joel!
Sincerely,
Jeff Kubascik
