[PATCH v2 0/3] bsp/xen: support for Xen hypervisor
Sebastian Huber
Thu Dec 5 07:16:22 UTC 2019
On 05/12/2019 07:36, Sebastian Huber wrote:
> Thanks, I check in the patch set.
> Should the BSP be renamed from "xen_virtual" to just "xen"?
I changed the linker command file a bit and converted the BSP to the new
build system. It would be good if you could test this:
https://lists.rtems.org/pipermail/devel/2019-November/056267.html
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
