[PATCH v2 0/3] bsp/xen: support for Xen hypervisor
Jeff Kubascik
jeff.kubascik at dornerworks.com
Thu Dec 5 13:42:18 UTC 2019
On 12/5/2019 2:16 AM, Sebastian Huber wrote:
> On 05/12/2019 07:36, Sebastian Huber wrote:
>> Thanks, I check in the patch set.
>> Should the BSP be renamed from "xen_virtual" to just "xen"?
> I changed the linker command file a bit and converted the BSP to the new
> build system. It would be good if you could test this:
> https://lists.rtems.org/pipermail/devel/2019-November/056267.html
Sure thing, I can give it a try.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Sincerely,
Jeff Kubascik
