Build FreeBSD: FAILED 6/rtems-sparc on x86_64-freebsd12.1 (sparc-rtems6-gdb-5085593976-x86_64-freebsd12.1-1)
Jiri Gaisler jiri at gaisler.se
Thu Dec 5 08:14:46 UTC 2019
On 12/5/19 8:38 AM, Sebastian Huber wrote:
> On 04/12/2019 14:56, sebastian.huber at embedded-brains.de wrote:
>> ../../../sourceware-mirror-binutils-gdb-5085593976/sim/erc32/sis.c:36:10: fatal error: 'readline/readline.h' file not found
>> #include "readline/readline.h"
> This is the GDB build failure on FreeBSD 12.1. I have a readline.h in:
> /usr/local/include/readline/readline.h
gdb should not be built with the internal sis anymore, as a much newer sis version exists as a standalone package. If you are building gdb manually, configure with --disable-sim .
