Build FreeBSD: FAILED 6/rtems-sparc on x86_64-freebsd12.1 (sparc-rtems6-gdb-5085593976-x86_64-freebsd12.1-1)
Thu Dec 5 08:26:40 UTC 2019
On 05/12/2019 09:14, Jiri Gaisler wrote:
> On 12/5/19 8:38 AM, Sebastian Huber wrote:
>> On 04/12/2019 14:56,sebastian.huber at embedded-brains.de  wrote:
>>> ../../../sourceware-mirror-binutils-gdb-5085593976/sim/erc32/sis.c:36:10: fatal error: 'readline/readline.h' file not found
>>> #include "readline/readline.h"
>> This is the GDB build failure on FreeBSD 12.1. I have a readline.h in:
>> /usr/local/include/readline/readline.h
> gdb should not be built with the internal sis anymore, as a much newer sis version exists as a standalone package. If you are building gdb manually, configure with --disable-sim .
The RTEMS 6 RSB intends to build the head version of the tools. So, on
SPARC we should build GDB with --disable-sim and add your sis head
version to the build?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
