_TOD_Set lock release question
Joel Sherrill
joel at rtems.org
Mon Dec 9 15:34:07 UTC 2019
I think I have implemented what you suggested and my new test is passing on
positive and negative cases.
Hopefully this version is ready to merge so I can begin to test the new
build system. <hint>
Thanks.
--joel
On Wed, Dec 4, 2019 at 12:51 AM Sebastian Huber <
> On 04/12/2019 04:04, Joel Sherrill wrote:
> > Hi
> > _TOD_Set() currently can't fail. With the addition of the TOD hooks, if a
> > BSP hook returns false, then _TOD_Set will fail. This requires that the
> lock
> > acquired by _TOD_Acquire before _TOD_Set is invoked as in
> rtems_clock_set()
> > should be released on the failure path. I don't see a _TOD_Release
> method.
> > What method needs to be invoked on the hook error path?
> You have to move
> #define _Timecounter_Release(lock_context) \
> _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context)
> to <rtems/score/timecounter.h> and use it to add a _TOD_Release() to
> <rtems/score/todimpl.h>.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191209/3adacd4e/attachment.html>
