[PATCH 4/5] config: Statically allocate MP object controls
Sebastian Huber
Thu Dec 12 08:43:06 UTC 2019
Update #3735.
cpukit/include/rtems/confdefs.h | 20 ++++----------------
cpukit/include/rtems/score/objectdata.h | 7 +++++++
cpukit/score/src/mpcidefault.c | 3 +++
cpukit/score/src/objectmp.c | 7 ++-----
4 files changed, 16 insertions(+), 21 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 20ffd6e7ba..095c506c35 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1834,10 +1834,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 32
#endif
- #define _CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(_global_objects) \
- _Configure_From_workspace( \
- (_global_objects) * sizeof(Objects_MP_Control) \
#ifndef CONFIGURE_MP_MAXIMUM_PROXIES
#define CONFIGURE_MP_MAXIMUM_PROXIES 32
@@ -1857,6 +1853,10 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#error "CONFIGURE_MP_NODE_NUMBER must be less than or equal to CONFIGURE_MP_MAXIMUM_NODES"
#endif
+ Objects_MP_Control _Objects_MP_Controls[
+ CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
struct Thread_Configured_proxy_control {
Thread_Proxy_control Control;
Thread_queue_Configured_heads Heads;
@@ -2411,17 +2411,6 @@ struct _reent *__getreent(void)
(_Configure_Max_Objects(_number_FP_tasks) \
* _Configure_From_workspace(CONTEXT_FP_SIZE))
- * This defines the amount of memory configured for the multiprocessing
- * support required by this application.
-#ifdef CONFIGURE_MP_APPLICATION
- #define _CONFIGURE_MEMORY_FOR_MP \
- _CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS)
-#else
- #define _CONFIGURE_MEMORY_FOR_MP 0
-#endif
* The following macro is used to calculate the memory allocated by RTEMS
* for the message buffers associated with a particular message queue.
@@ -2500,7 +2489,6 @@ struct _reent *__getreent(void)
_CONFIGURE_MEMORY_FOR_POSIX_SHMS( \
CONFIGURE_MAXIMUM_POSIX_SHMS) + \
_CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS + \
- _CONFIGURE_MEMORY_FOR_MP + \
CONFIGURE_MESSAGE_BUFFER_MEMORY + \
(CONFIGURE_MEMORY_OVERHEAD * 1024) + \
_CONFIGURE_HEAP_HANDLER_OVERHEAD \
diff --git a/cpukit/include/rtems/score/objectdata.h b/cpukit/include/rtems/score/objectdata.h
index a33f9d497f..e44fb52d68 100644
--- a/cpukit/include/rtems/score/objectdata.h
+++ b/cpukit/include/rtems/score/objectdata.h
@@ -144,6 +144,13 @@ typedef struct {
uint32_t name;
} Objects_MP_Control;
+ * @brief The MP object controls.
+ * Provided by the application via <rtems/confdefs.h>.
+extern Objects_MP_Control _Objects_MP_Controls[];
* The following type defines the callout used when a local task
* is extracted from a remote thread queue (i.e. it's proxy must
diff --git a/cpukit/score/src/mpcidefault.c b/cpukit/score/src/mpcidefault.c
index 9957f782fd..191f458b38 100644
--- a/cpukit/score/src/mpcidefault.c
+++ b/cpukit/score/src/mpcidefault.c
@@ -19,9 +19,12 @@
#endif
#include <rtems/score/mpci.h>
+#include <rtems/score/objectdata.h>
#include <rtems/score/stack.h>
+Objects_MP_Control _Objects_MP_Controls[ 0 ];
int dummy;
diff --git a/cpukit/score/src/objectmp.c b/cpukit/score/src/objectmp.c
index 1910b8ccba..cad1413c33 100644
--- a/cpukit/score/src/objectmp.c
+++ b/cpukit/score/src/objectmp.c
@@ -21,7 +21,6 @@
#include <rtems/score/interr.h>
#include <rtems/score/isrlock.h>
-#include <rtems/score/wkspace.h>
#include <rtems/config.h>
#define OBJECTS_MP_CONTROL_OF_ID_LOOKUP_NODE( node ) \
@@ -185,11 +184,9 @@ void _Objects_MP_Handler_initialization( void )
_Chain_Initialize(
&_Objects_MP_Inactive_global_objects,
- _Workspace_Allocate_or_fatal_error(
- maximum_global_objects * sizeof( Objects_MP_Control )
+ &_Objects_MP_Controls[ 0 ],
maximum_global_objects,
- sizeof( Objects_MP_Control )
+ sizeof( _Objects_MP_Controls[ 0 ] )
2.16.4
