[PATCH] c-user: Document CONFIGURE_IMFS_ENABLE_MKFIFO
Sebastian Huber
Thu Dec 12 08:46:56 UTC 2019
Close #3840.
c-user/configuring_a_system.rst | 23 +++++++++++++++++++++++
1 file changed, 23 insertions(+)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index cdb86ec..17278c0 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -2583,6 +2583,29 @@ DESCRIPTION:
In case this configuration option is defined, then the support to remove
nodes is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_ENABLE_MKFIFO
+.. _CONFIGURE_IMFS_ENABLE_MKFIFO:
+CONFIGURE_IMFS_ENABLE_MKFIFO
+CONSTANT:
+ ``CONFIGURE_IMFS_ENABLE_MKFIFO``
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+ This is not defined by default.
+DESCRIPTION:
+ In case this configuration option is defined, then the support to make FIFOs
+ is enabled in the root IMFS.
Block Device Cache Configuration
2.16.4
