Requirement Document generator tool
Jose Valdez Jose.Valdez at edisoft.pt
Fri Dec 13 16:09:09 UTC 2019
Hello,
In the scope of ESA's RTEMS SMP project, we are developing a tool which will allow to generate RTEMS software documentation (Requirements, Design, Test Specification and other software documents).
Our first task will be to develop and integrate the SRS Manager into RTEMS project. This SRS Manager reads requirements written in doorstop format (each topic is a doorstop document) and produces the SRS document according with ECSS format (the output of the tool are sphinx files, which then are compiled to pdf document).
Could you indicate how I can integrate our tool into RTEMS git repository? Should be in rtems-tools? If so, in which place?
Best regards
José
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191213/9c60e78d/attachment.html>
