[PATCH 09/21] score: Add _Stack_Extend_size()
Mon Dec 16 14:28:14 UTC 2019
Update #3835.
 cpukit/include/rtems/score/stackimpl.h | 27 +++++++++++++++++++++++++++
 cpukit/score/src/threadinitialize.c    | 13 +++----------
 2 files changed, 30 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/score/stackimpl.h b/cpukit/include/rtems/score/stackimpl.h
index aafde5d1a0..305c4e4e51 100644
--- a/cpukit/include/rtems/score/stackimpl.h
+++ b/cpukit/include/rtems/score/stackimpl.h
@@ -120,6 +120,33 @@ RTEMS_INLINE_ROUTINE size_t _Stack_Ensure_minimum (
   return _Stack_Minimum();
+ * @brief Extend the stack size to account for additional data structures
+ *   allocated in the stack area of a thread.
+ * @param stack_size The stack size.
+ * @param is_fp Indicates if the stack is for a floating-point thread.
+ * @return The extended stack size.
+RTEMS_INLINE_ROUTINE size_t _Stack_Extend_size(
+  size_t stack_size,
+  bool   is_fp
+#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
+  if ( is_fp ) {
+    stack_size += CONTEXT_FP_SIZE;
+#else
+  (void) is_fp;
+#endif
+  stack_size += _TLS_Get_allocation_size();
+  return stack_size;
  * @brief Allocate the requested stack space.
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index cf21602ac0..a2bb09425d 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -76,21 +76,12 @@ bool _Thread_Initialize(
       (char *) the_thread + add_on->source_offset;
-  tls_size = _TLS_Get_allocation_size();
   /* Allocate the stack for this thread */
 #if defined(RTEMS_SCORE_THREAD_ENABLE_USER_PROVIDED_STACK_VIA_API)
   if ( config->stack_area == NULL ) {
 #endif
     stack_size = _Stack_Ensure_minimum( config->stack_size );
-#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
-    if ( config->is_fp ) {
-      stack_size += CONTEXT_FP_SIZE;
-#endif
-    stack_size += tls_size;
+    stack_size = _Stack_Extend_size( stack_size, config->is_fp );
     stack_area = _Stack_Allocate( stack_size );
     if ( stack_area == NULL ) {
@@ -115,6 +106,8 @@ bool _Thread_Initialize(
 #endif
+  tls_size = _TLS_Get_allocation_size();
   /* Allocate thread-local storage (TLS) area in stack area */
   if ( tls_size > 0 ) {
     uintptr_t tls_align;
2.16.4
