[PATCH 10/21] score: Move thread stack allocation
Sebastian Huber
Mon Dec 16 14:28:15 UTC 2019
Move thread stack allocation to caller side of _Thread_Initialize().
Update #3835.
cpukit/include/rtems/score/thread.h | 2 --
cpukit/include/rtems/score/threadimpl.h | 9 ++++--
cpukit/posix/src/pthreadcreate.c | 20 +++++++++----
cpukit/rtems/src/taskcreate.c | 16 ++++++++--
cpukit/score/src/mpci.c | 20 +++++++++----
cpukit/score/src/threadcreateidle.c | 17 ++++++++---
cpukit/score/src/threadinitialize.c | 53 ++++++++++++---------------------
7 files changed, 83 insertions(+), 54 deletions(-)
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 336be281bd..c70624f64a 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -83,8 +83,6 @@ extern "C" {
#define RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT
-#define RTEMS_SCORE_THREAD_ENABLE_USER_PROVIDED_STACK_VIA_API
#if defined(RTEMS_DEBUG)
#define RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT
#endif
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 2cde5d4fe0..b007055eeb 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -140,15 +140,20 @@ typedef struct {
const struct _Scheduler_Control *scheduler;
- * @brief The starting address of the thread area.
+ * @brief The starting address of the stack area.
void *stack_area;
- * @brief The size of the thread area in bytes.
+ * @brief The size of the stack area in bytes.
size_t stack_size;
+ * @brief The address of the allocated stack area or NULL.
+ void *allocated_stack;
* @brief The new thread's priority.
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 2a418c4b68..1960a4478b 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -120,6 +120,7 @@ int pthread_create(
config.stack_size = _POSIX_Threads_Ensure_minimum_stack(
the_attr->stacksize
+ config.stack_size = _Stack_Extend_size( config.stack_size, config.is_fp );
#if 0
@@ -215,14 +216,23 @@ int pthread_create(
return EAGAIN;
+ if ( config.stack_area == NULL ) {
+ config.stack_area = _Stack_Allocate( config.stack_size );
+ config.allocated_stack = config.stack_area;
+ status = ( config.stack_area != NULL );
* Initialize the core thread for this task.
- status = _Thread_Initialize(
- &_POSIX_Threads_Information,
- the_thread,
- &config
+ if ( status ) {
+ status = _Thread_Initialize(
+ &_POSIX_Threads_Information,
+ the_thread,
+ &config
if ( !status ) {
_POSIX_Threads_Free( the_thread );
_Objects_Allocator_unlock();
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index 9ca0047aa7..019da6588f 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -25,6 +25,7 @@
#include <rtems/score/apimutex.h>
+#include <rtems/score/stackimpl.h>
#include <rtems/score/sysstate.h>
#include <rtems/score/userextimpl.h>
@@ -78,7 +79,6 @@ rtems_status_code rtems_task_create(
_Attributes_Clear( the_attribute_set, ATTRIBUTES_NOT_SUPPORTED );
memset( &config, 0, sizeof( config ) );
- config.stack_size = stack_size;
config.budget_algorithm = _Modes_Is_timeslice( initial_modes ) ?
THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE
: THREAD_CPU_BUDGET_ALGORITHM_NONE,
@@ -86,6 +86,8 @@ rtems_status_code rtems_task_create(
config.name.name_u32 = name;
config.is_fp = _Attributes_Is_floating_point( the_attribute_set );
config.is_preemptible = _Modes_Is_preempt( initial_modes );
+ config.stack_size = _Stack_Ensure_minimum( stack_size );
* Validate the RTEMS API priority and convert it to the core priority range.
@@ -148,11 +150,21 @@ rtems_status_code rtems_task_create(
#endif
- status = _Thread_Initialize( &_RTEMS_tasks_Information, the_thread, &config );
+ if ( status ) {
+ &_RTEMS_tasks_Information,
+ the_thread,
+ &config
if ( !status ) {
#if defined(RTEMS_MULTIPROCESSING)
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 32489ac0cf..1f9b838796 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -114,6 +114,7 @@ static void _MPCI_Create_server( void )
Thread_Configuration config;
+ bool ok;
ISR_lock_Context lock_context;
@@ -129,15 +130,24 @@ static void _MPCI_Create_server( void )
config.scheduler = &_Scheduler_Table[ 0 ];
- config.stack_size = _Stack_Minimum()
- + CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK
- + _MPCI_Configuration.extra_mpci_receive_server_stack;
config.name.name_u32 = _Objects_Build_name( 'M', 'P', 'C', 'I' );
config.priority = PRIORITY_PSEUDO_ISR;
config.budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_NONE;
config.is_fp = CPU_ALL_TASKS_ARE_FP;
- _Thread_Initialize( &_Thread_Information, _MPCI_Receive_server_tcb, &config );
+ config.stack_size = _Stack_Minimum()
+ + CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK
+ + _MPCI_Configuration.extra_mpci_receive_server_stack;
+ _Assert( config.stack_area != NULL );
+ ok = _Thread_Initialize(
+ &_Thread_Information,
+ _MPCI_Receive_server_tcb,
+ &config
+ _Assert( ok );
+ (void) ok;
_ISR_lock_ISR_disable( &lock_context );
_Thread_Start( _MPCI_Receive_server_tcb, &entry, &lock_context );
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index e7243ae09c..c06f211a6b 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -21,6 +21,7 @@
#include <rtems/config.h>
@@ -29,8 +30,9 @@
static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
- Thread_Configuration config;
- Thread_Control *idle;
+ Thread_Configuration config;
+ Thread_Control *idle;
+ bool ok;
config.scheduler = _Scheduler_Get_by_CPU( cpu );
@@ -41,7 +43,6 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
#endif
- config.stack_size = rtems_configuration_get_idle_task_stack_size();
config.priority = _Scheduler_Map_priority(
config.scheduler,
config.scheduler->maximum_priority
@@ -50,6 +51,12 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
config.name.name_u32 = _Objects_Build_name( 'I', 'D', 'L', 'E' );
config.is_fp = CPU_IDLE_TASK_IS_FP;
config.is_preemptible = true;
+ rtems_configuration_get_idle_task_stack_size()
* The entire workspace is zeroed during its initialization. Thus, all
@@ -59,7 +66,9 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
idle = _Thread_Internal_allocate();
_Assert( idle != NULL );
- _Thread_Initialize( &_Thread_Information, idle, &config );
+ ok = _Thread_Initialize( &_Thread_Information, idle, &config );
+ _Assert( ok );
+ (void) ok;
* WARNING!!! This is necessary to "kick" start the system and
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index a2bb09425d..6b9b6bef21 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -46,23 +46,6 @@ bool _Thread_Initialize(
size_t scheduler_index;
Per_CPU_Control *cpu = _Per_CPU_Get_by_index( 0 );
-#if defined(RTEMS_SMP)
- if ( !config->is_preemptible && rtems_configuration_is_smp_enabled() ) {
- return false;
-#endif
-#if defined(RTEMS_SMP) || CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE
- if (
- config->isr_level != 0
-#if CPU_ENABLE_ROBUST_THREAD_DISPATCH == FALSE
- && rtems_configuration_is_smp_enabled()
-#endif
- return false;
-#endif
memset(
&the_thread->Join_queue,
0,
@@ -76,26 +59,30 @@ bool _Thread_Initialize(
(char *) the_thread + add_on->source_offset;
- /* Allocate the stack for this thread */
-#if defined(RTEMS_SCORE_THREAD_ENABLE_USER_PROVIDED_STACK_VIA_API)
- if ( config->stack_area == NULL ) {
-#endif
- stack_size = _Stack_Ensure_minimum( config->stack_size );
- stack_size = _Stack_Extend_size( stack_size, config->is_fp );
- stack_area = _Stack_Allocate( stack_size );
+ /* Set everything to perform the error case clean up */
+ scheduler_index = 0;
+ the_thread->Start.allocated_stack = config->allocated_stack;
- if ( stack_area == NULL ) {
- return false;
+#if defined(RTEMS_SMP)
+ if ( !config->is_preemptible && rtems_configuration_is_smp_enabled() ) {
+ goto failed;
+#endif
- the_thread->Start.allocated_stack = stack_area;
- } else {
- stack_area = config->stack_area;
- stack_size = config->stack_size;
+#if defined(RTEMS_SMP) || CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE
+ if (
+ config->isr_level != 0
+#if CPU_ENABLE_ROBUST_THREAD_DISPATCH == FALSE
+ && rtems_configuration_is_smp_enabled()
+#endif
+ goto failed;
#endif
+ stack_area = config->stack_area;
+ stack_size = config->stack_size;
/* Allocate floating-point context in stack area */
#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
if ( config->is_fp ) {
@@ -125,8 +112,6 @@ bool _Thread_Initialize(
stack_size
- scheduler_index = 0;
* Get thread queue heads
2.16.4
