[PATCH 13/21] score: Split up objects allocation
Sebastian Huber
Mon Dec 16 14:28:18 UTC 2019
Split up the different objects allocation methods into separate
functions. This helps to avoid a dependency on the workspace in case no
objects or a static set of objects is configured.
Change license to BSD-2-Clause according to file histories.
Update #3053.
Update #3835.
cpukit/Makefile.am | 3 +
cpukit/include/rtems/score/objectdata.h | 48 +++++++++++++-
cpukit/include/rtems/score/objectimpl.h | 61 +++++++++++------
cpukit/include/rtems/score/thread.h | 3 +
cpukit/score/src/objectallocate.c | 101 ++++++++---------------------
cpukit/score/src/objectallocatenone.c | 45 +++++++++++++
cpukit/score/src/objectallocatestatic.c | 44 +++++++++++++
cpukit/score/src/objectallocateunlimited.c | 79 ++++++++++++++++++++++
8 files changed, 289 insertions(+), 95 deletions(-)
create mode 100644 cpukit/score/src/objectallocatenone.c
create mode 100644 cpukit/score/src/objectallocatestatic.c
create mode 100644 cpukit/score/src/objectallocateunlimited.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 33b10be42a..aed67f3f13 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -855,6 +855,9 @@ librtemscpu_a_SOURCES += score/src/heapnoextend.c
librtemscpu_a_SOURCES += score/src/memoryallocate.c
librtemscpu_a_SOURCES += score/src/memorydirty.c
librtemscpu_a_SOURCES += score/src/objectallocate.c
+librtemscpu_a_SOURCES += score/src/objectallocatenone.c
+librtemscpu_a_SOURCES += score/src/objectallocatestatic.c
+librtemscpu_a_SOURCES += score/src/objectallocateunlimited.c
librtemscpu_a_SOURCES += score/src/objectclose.c
librtemscpu_a_SOURCES += score/src/objectextendinformation.c
librtemscpu_a_SOURCES += score/src/objectfree.c
diff --git a/cpukit/include/rtems/score/objectdata.h b/cpukit/include/rtems/score/objectdata.h
index e44fb52d68..b923c45d25 100644
--- a/cpukit/include/rtems/score/objectdata.h
+++ b/cpukit/include/rtems/score/objectdata.h
@@ -162,6 +162,8 @@ typedef void ( *Objects_Thread_queue_Extract_callout )(
#endif
+typedef struct Objects_Information Objects_Information;
* @brief The information structure used to manage each API class of objects.
@@ -171,7 +173,7 @@ typedef void ( *Objects_Thread_queue_Extract_callout )(
* allocated and pre-initialized instance for each API class providing zero
* objects, see OBJECTS_INFORMATION_DEFINE_ZERO().
-typedef struct {
+struct Objects_Information {
* @brief This is the maximum valid ID of this object API class.
@@ -192,6 +194,14 @@ typedef struct {
Objects_Control **local_table;
+ * @brief Allocate an object.
+ * @see _Objects_Allocate_none(), _Objects_Allocate_static(), and
+ * _Objects_Allocate_unlimited().
+ Objects_Control *( *allocate )( Objects_Information * );
* @brief This is the number of object control blocks on the inactive chain.
@@ -288,7 +298,38 @@ typedef struct {
RBTree_Control Global_by_name;
#endif
-} Objects_Information;
+ * @brief Always return NULL.
+ * @param information The objects information.
+ * @retval NULL Always.
+Objects_Control *_Objects_Allocate_none( Objects_Information *information );
+ * @brief Return an inactive object or NULL.
+ * @retval NULL No inactive object is available.
+ * @retval object An inactive object.
+Objects_Control *_Objects_Allocate_static( Objects_Information *information );
+ * Try to extend the objects information if necessary.
+Objects_Control *_Objects_Allocate_unlimited( Objects_Information *information );
#if defined(RTEMS_MULTIPROCESSING)
#define OBJECTS_INFORMATION_MP( name, extract ) \
@@ -315,6 +356,7 @@ typedef struct {
Objects_Information name##_Information = { \
_Objects_Build_id( api, cls, 1, 0 ), \
NULL, \
+ _Objects_Allocate_none, \
0, \
0, \
0, \
@@ -351,6 +393,8 @@ static type name##_Objects[ _Objects_Maximum_per_allocation( max ) ]; \
_Objects_Build_id( api, cls, 1, _Objects_Maximum_per_allocation( max ) ), \
name##_Local_table, \
+ _Objects_Is_unlimited( max ) ? \
+ _Objects_Allocate_unlimited : _Objects_Allocate_static, \
0, \
_Objects_Is_unlimited( max ) ? _Objects_Maximum_per_allocation( max ) : 0, \
sizeof( type ), \
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index 83e93a2b12..a2548dd980 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -23,7 +23,9 @@
#include <rtems/score/objectdata.h>
#include <rtems/score/apimutex.h>
+#include <rtems/score/assert.h>
#include <rtems/score/isrlock.h>
+#include <rtems/score/sysstate.h>
#ifdef __cplusplus
@@ -144,25 +146,6 @@ unsigned int _Objects_API_maximum_class(
uint32_t api
- * @brief Allocates an object without locking the allocator mutex.
- * This function can be called in two contexts
- * - the executing thread is the owner of the object allocator mutex, or
- * - in case the system state is not up, e.g. during sequential system
- * initialization.
- * @param[in, out] information The object information block.
- * @retval object The allocated object.
- * @retval NULL No object available.
- * @see _Objects_Allocate() and _Objects_Free().
-Objects_Control *_Objects_Allocate_unprotected(
- Objects_Information *information
* @brief Allocates an object.
@@ -702,6 +685,19 @@ RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_maximum_index(
return _Objects_Get_index( information->maximum_id );
+ * @brief Get an inactive object or NULL.
+RTEMS_INLINE_ROUTINE Objects_Control *_Objects_Get_inactive(
+ Objects_Information *information
+ return (Objects_Control *) _Chain_Get_unprotected( &information->Inactive );
* @brief Checks if the automatic object extension (unlimited objects) is
* enabled.
@@ -902,6 +898,33 @@ RTEMS_INLINE_ROUTINE bool _Objects_Allocator_is_owner( void )
return _RTEMS_Allocator_is_owner();
+ * @brief Allocates an object without locking the allocator mutex.
+ * This function can be called in two contexts
+ * - the executing thread is the owner of the object allocator mutex, or
+ * - in case the system state is not up, e.g. during sequential system
+ * initialization.
+ * @param[in, out] information The object information block.
+ * @retval object The allocated object.
+ * @retval NULL No object available.
+ * @see _Objects_Allocate() and _Objects_Free().
+RTEMS_INLINE_ROUTINE Objects_Control *_Objects_Allocate_unprotected(
+ _Assert(
+ _Objects_Allocator_is_owner()
+ || !_System_state_Is_up( _System_state_Get() )
+ return ( *information->allocate )( information );
#ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index e438549ff8..3d977749ff 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -1023,6 +1023,7 @@ Thread_Information name##_Information = { \
NULL, \
0, \
0, \
0, \
@@ -1048,6 +1049,8 @@ Thread_Information name##_Information = { \
0, \
sizeof( Thread_Configured_control ), \
diff --git a/cpukit/score/src/objectallocate.c b/cpukit/score/src/objectallocate.c
index ac7579dc78..588c516b33 100644
--- a/cpukit/score/src/objectallocate.c
+++ b/cpukit/score/src/objectallocate.c
@@ -1,17 +1,36 @@
- * @file
+ * @file
- * @brief Allocate Object
- * @ingroup RTEMSScoreObject
+ * @ingroup RTEMSScoreObject
+ * @brief Allocate Object
- * COPYRIGHT (c) 1989-1999.
- * On-Line Applications Research Corporation (OAR).
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2014 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
#if HAVE_CONFIG_H
@@ -19,72 +38,6 @@
#endif
-#include <rtems/score/assert.h>
-#include <rtems/score/chainimpl.h>
-#include <rtems/score/sysstate.h>
-static Objects_Control *_Objects_Get_inactive(
- return (Objects_Control *) _Chain_Get_unprotected( &information->Inactive );
- Objects_Control *the_object;
- _Assert(
- _Objects_Allocator_is_owner()
- || !_System_state_Is_up( _System_state_Get() )
- * If the application is using the optional manager stubs and
- * still attempts to create the object, the information block
- * should be all zeroed out because it is in the BSS. So let's
- * check that code for this manager is even present.
- if ( information->object_size == 0 )
- return NULL;
- * OK. The manager should be initialized and configured to have objects.
- * With any luck, it is safe to attempt to allocate an object.
- the_object = _Objects_Get_inactive( information );
- if ( _Objects_Is_auto_extend( information ) ) {
- * If the list is empty then we are out of objects and need to
- * extend information base.
- if ( the_object == NULL ) {
- _Objects_Extend_information( information );
- if ( the_object != NULL ) {
- Objects_Maximum objects_per_block;
- Objects_Maximum block;
- objects_per_block = information->objects_per_block;
- block = _Objects_Get_index( the_object->id ) - OBJECTS_INDEX_MINIMUM;
- if ( block > objects_per_block ) {
- block /= objects_per_block;
- information->inactive_per_block[ block ]--;
- information->inactive--;
- return the_object;
Objects_Control *_Objects_Allocate( Objects_Information *information )
diff --git a/cpukit/score/src/objectallocatenone.c b/cpukit/score/src/objectallocatenone.c
new file mode 100644
index 0000000000..0669f99ba9
--- /dev/null
+++ b/cpukit/score/src/objectallocatenone.c
@@ -0,0 +1,45 @@
+ * @file
+ * Copyright (C) 2019 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/objectdata.h>
+ (void) information;
+ return NULL;
diff --git a/cpukit/score/src/objectallocatestatic.c b/cpukit/score/src/objectallocatestatic.c
index 0000000000..73790ba478
--- /dev/null
+++ b/cpukit/score/src/objectallocatestatic.c
@@ -0,0 +1,44 @@
+ * @file
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/objectimpl.h>
+ return _Objects_Get_inactive( information );
diff --git a/cpukit/score/src/objectallocateunlimited.c b/cpukit/score/src/objectallocateunlimited.c
index 0000000000..92727e1411
--- /dev/null
+++ b/cpukit/score/src/objectallocateunlimited.c
@@ -0,0 +1,79 @@
+ * @file
+ * Copyright (C) 1989, 2007 On-Line Applications Research Corporation (OAR)
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+ Objects_Control *the_object;
+ _Assert( _Objects_Is_auto_extend( information ) );
+ * OK. The manager should be initialized and configured to have objects.
+ * With any luck, it is safe to attempt to allocate an object.
+ the_object = _Objects_Get_inactive( information );
+ * If the list is empty then we are out of objects and need to
+ * extend information base.
+ if ( the_object == NULL ) {
+ _Objects_Extend_information( information );
+ if ( the_object != NULL ) {
+ Objects_Maximum objects_per_block;
+ Objects_Maximum block;
+ objects_per_block = information->objects_per_block;
+ block = _Objects_Get_index( the_object->id ) - OBJECTS_INDEX_MINIMUM;
+ if ( block > objects_per_block ) {
+ block /= objects_per_block;
+ information->inactive_per_block[ block ]--;
+ information->inactive--;
+ return the_object;
2.16.4
