[PATCH 12/21] score: Add _Objects_Free_objects_block()
Mon Dec 16 14:28:17 UTC 2019
This is a preparation to allow a customization of the objects
information extend.
Update #3835.
 cpukit/include/rtems/score/objectimpl.h    | 11 ++++
 cpukit/score/src/objectshrinkinformation.c | 92 +++++++++++++++++-------------
 2 files changed, 64 insertions(+), 39 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index 9becb33e7d..83e93a2b12 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -94,6 +94,17 @@ void _Objects_Extend_information(
   Objects_Information *information
+ * @brief Free the objects block with the specified index.
+ * @param information The objects information.
+ * @param block The block index.
+void _Objects_Free_objects_block(
+  Objects_Information *information,
+  Objects_Maximum      block
  * @brief Shrinks an object class information record.
diff --git a/cpukit/score/src/objectshrinkinformation.c b/cpukit/score/src/objectshrinkinformation.c
index 9498ea2716..6f22d7bcdb 100644
--- a/cpukit/score/src/objectshrinkinformation.c
+++ b/cpukit/score/src/objectshrinkinformation.c
@@ -22,6 +22,58 @@
+  Objects_Maximum   objects_per_block;
+  Objects_Maximum   index_base;
+  Objects_Maximum   index_end;
+  Chain_Node       *node;
+  const Chain_Node *tail;
+  objects_per_block = information->objects_per_block;
+  _Assert( _Objects_Allocator_is_owner() );
+  _Assert( _Objects_Is_auto_extend( information ) );
+  _Assert( block >= 1 );
+  _Assert(
+    block < _Objects_Get_maximum_index( information ) / objects_per_block
+  index_base = block * objects_per_block;
+  index_end = index_base + objects_per_block;
+  node = _Chain_First( &information->Inactive );
+  tail = _Chain_Immutable_tail( &information->Inactive );
+  while ( node != tail ) {
+    Objects_Control *object;
+    uint32_t         index;
+    object = (Objects_Control *) node;
+    index = _Objects_Get_index( object->id ) - OBJECTS_INDEX_MINIMUM;
+     *  Get the next node before the node is extracted
+    node = _Chain_Next( node );
+    if ( index >= index_base && index < index_end ) {
+      _Chain_Extract_unprotected( &object->Node );
+   *  Free the memory and reset the structures in the object' information
+  _Workspace_Free( information->object_blocks[ block ] );
+  information->object_blocks[ block ] = NULL;
+  information->inactive_per_block[ block ] = 0;
+  information->inactive -= objects_per_block;
 void _Objects_Shrink_information(
@@ -29,7 +81,6 @@ void _Objects_Shrink_information(
   Objects_Maximum block_count;
   Objects_Maximum block;
-  Objects_Maximum index_base;
@@ -40,48 +91,11 @@ void _Objects_Shrink_information(
   block_count = _Objects_Get_maximum_index( information ) / objects_per_block;
-  index_base = objects_per_block;
   for ( block = 1; block < block_count; block++ ) {
     if ( information->inactive_per_block[ block ] == objects_per_block ) {
-      Chain_Node       *node;
-      const Chain_Node *tail;
-      Objects_Maximum   index_end;
-      node = _Chain_First( &information->Inactive );
-      tail = _Chain_Immutable_tail( &information->Inactive );
-      index_end = index_base + objects_per_block;
-      while ( node != tail ) {
-        Objects_Control *object;
-        uint32_t         index;
-        object = (Objects_Control *) node;
-        index = _Objects_Get_index( object->id ) - OBJECTS_INDEX_MINIMUM;
-         *  Get the next node before the node is extracted
-        node = _Chain_Next( node );
-        if ( index >= index_base && index < index_end ) {
-          _Chain_Extract_unprotected( &object->Node );
-       *  Free the memory and reset the structures in the object' information
-      _Workspace_Free( information->object_blocks[ block ] );
-      information->object_blocks[ block ] = NULL;
-      information->inactive_per_block[ block ] = 0;
-      information->inactive -= objects_per_block;
+      _Objects_Free_objects_block( information, block );
       return;
-    index_base += objects_per_block;
2.16.4
