[PATCH] c-user: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
Sebastian Huber
Tue Dec 17 09:15:46 UTC 2019
Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS in
CONFIGURE_MAXIMUM_FILE_DESCRIPTORS.
Close #3753.
c-user/configuring_a_system.rst | 26 +++++++++++++++++---------
1 file changed, 17 insertions(+), 9 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 7eb472b..6e680c2 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -529,16 +529,16 @@ NOTES:
:ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE
<CONFIGURE_MINIMUM_TASK_STACK_SIZE>` instead of ``CPU_STACK_MINIMUM_SIZE``.
-.. index:: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+.. index:: CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
.. index:: maximum file descriptors
-.. _CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS:
+.. _CONFIGURE_MAXIMUM_FILE_DESCRIPTORS:
-CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
CONSTANT:
- ``CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS``
+ ``CONFIGURE_MAXIMUM_FILE_DESCRIPTORS``
DATA TYPE:
Unsigned integer (``uint32_t``).
@@ -4866,12 +4866,13 @@ CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
This configuration option is obsolete since RTEMS 5.1.
-.. index:: CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+.. index:: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-This configuration option is obsolete since RTEMS 5.1.
+This configuration option was present in all RTEMS versions since at 1998 and is
+obsolete since RTEMS 5.1. See also :ref:`CONFIGURE_MAXIMUM_FILE_DESCRIPTORS`.
.. index:: CONFIGURE_MAXIMUM_GO_CHANNELS
@@ -4894,6 +4895,13 @@ CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
+.. index:: CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+This configuration option is obsolete since RTEMS 5.1.
.. index:: CONFIGURE_MAXIMUM_POSIX_BARRIERS
2.16.4
