[PATCH] c-user: CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
Sebastian Huber
Tue Dec 17 08:50:09 UTC 2019
Remove CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE.
Close #3844.
c-user/configuring_a_system.rst | 40 ++++++++--------------------------------
1 file changed, 8 insertions(+), 32 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 17278c0..7eb472b 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -4406,38 +4406,6 @@ DESCRIPTION:
NOTES:
This device driver is supported by all BSPs.
-.. index:: CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
-.. _CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE:
-CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
-CONSTANT:
- ``CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE``
-DATA TYPE:
- Boolean feature macro.
-RANGE:
- Defined or undefined.
-DEFAULT VALUE:
- This is not defined by default, indicating the ``<rtems/confdefs.h>`` is
- providing the device driver table.
-DESCRIPTION:
- ``CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE`` is defined if the application
- wishes to provide their own Device Driver Table.
- The table must be an array of ``rtems_driver_address_table`` entries
- named`` _IO_Driver_address_table``. The application must also provide a
- const variable ``_IO_Number_of_drivers`` of type ``size_t`` indicating the
- number of entries in the ``_IO_Driver_address_table``.
-NOTES:
- It is expected that there the application would only rarely need to do this.
Multiprocessing Configuration
@@ -4876,6 +4844,14 @@ CONFIGURE_HAS_OWN_BDBUF_TABLE
This configuration option was introduced in RTEMS 4.7.0 and is obsolete since
RTEMS 4.10.0.
+.. index:: CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
+CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
+This configuration option was present in all RTEMS versions since at least 1995
+and is obsolete since RTEMS 5.1.
.. index:: CONFIGURE_HAS_OWN_MOUNT_TABLE
2.16.4
