[PATCH] c-user: Remove Ada configuration options
Sebastian Huber
Wed Dec 18 15:27:23 UTC 2019
Close #3845.
c-user/configuring_a_system.rst | 132 +++++++++++-----------------------------
1 file changed, 34 insertions(+), 98 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 6e680c2..18cbd32 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -4587,104 +4587,6 @@ NOTES:
Multiprocessor System assuming the BSP provides the proper set of
supporting methods.
-Ada Tasks
-This section defines the system configuration parameters supported by
-``<rtems/confdefs.h>`` related to configuring RTEMS to support a task using Ada
-tasking with GNAT/RTEMS.
-These configuration parameters are only available when RTEMS is built with the
-``--enable-ada`` configure option and the application specifies
-``CONFIGURE_GNAT_RTEMS``.
-Additionally RTEMS includes an Ada language binding to the Classic API which
-has a test suite. This test suite is enabled only when``--enable-tests`` and
-``--enable-expada`` are specified on the configure command.
-.. index:: CONFIGURE_GNAT_RTEMS
-.. _CONFIGURE_GNAT_RTEMS:
-CONFIGURE_GNAT_RTEMS
-CONSTANT:
- ``CONFIGURE_GNAT_RTEMS``
-DATA TYPE:
- Boolean feature macro.
-RANGE:
- Defined or undefined.
-DEFAULT VALUE:
- This is not defined by default.
-DESCRIPTION:
- ``CONFIGURE_GNAT_RTEMS`` is defined to inform RTEMS that the GNAT Ada
- run-time is to be used by the application.
-NOTES:
- This configuration parameter is critical as it makes``<rtems/confdefs.h>``
- configure the resources (POSIX API Threads, Mutexes, Condition Variables,
- and Keys) used implicitly by the GNAT run-time.
-.. index:: CONFIGURE_MAXIMUM_ADA_TASKS
-.. _CONFIGURE_MAXIMUM_ADA_TASKS:
-CONFIGURE_MAXIMUM_ADA_TASKS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_ADA_TASKS``
-DATA TYPE:
- Unsigned integer (``uint32_t``).
-RANGE:
- Undefined or positive.
-DEFAULT VALUE:
- If ``CONFIGURE_GNAT_RTEMS`` is defined, then the default value is 20,
- otherwise the default value is 0.
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_ADA_TASKS`` is the number of Ada tasks that can be
- concurrently active in the system.
-NOTES:
- None.
-.. index:: CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
-.. _CONFIGURE_MAXIMUM_FAKE_ADA_TASKS:
-CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_FAKE_ADA_TASKS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
- The default value is 0.
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_FAKE_ADA_TASKS`` is the number of *fake* Ada tasks that
- can be concurrently active in the system. A *fake* Ada task is a non-Ada
- task that makes calls back into Ada code and thus implicitly uses the Ada
- run-time.
-NOTES:
- None.
PCI Library
@@ -4795,6 +4697,16 @@ NOTES:
The record extensions capture thread create, start, restart, delete,
switch, begin, exitted and terminate events.
+Ada Configuration
+The GNU Ada runtime library (libgnarl) uses threads, mutexes, condition
+variables, and signals from the pthreads API. It uses also thread-local storage
+for the Ada Task Control Block (ATCB). From these resources only the threads
+need to be accounted for in the configuration. You should include the Ada tasks
+in your setting of the :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS` configuration
+option.
Obsolete Configuration Options
@@ -4829,6 +4741,14 @@ CONFIGURE_ENABLE_GO
This configuration option is obsolete since RTEMS 5.1.
+.. index:: CONFIGURE_GNAT_RTEMS
+CONFIGURE_GNAT_RTEMS
+This configuration option was present in all RTEMS versions since at 1997 and is
+obsolete since RTEMS 5.1. See also :ref:`ConfigAda`.
.. index:: CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
@@ -4874,6 +4794,22 @@ CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
This configuration option was present in all RTEMS versions since at 1998 and is
obsolete since RTEMS 5.1. See also :ref:`CONFIGURE_MAXIMUM_FILE_DESCRIPTORS`.
+.. index:: CONFIGURE_MAXIMUM_ADA_TASKS
+CONFIGURE_MAXIMUM_ADA_TASKS
+.. index:: CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
.. index:: CONFIGURE_MAXIMUM_GO_CHANNELS
2.16.4
