[PATCH] c-user: Document rtems_object_get_local_node()
Thu Dec 19 10:06:55 UTC 2019
Close #3841.
 c-user/object_services.rst | 28 ++++++++++++++++++++++++++++
 1 file changed, 28 insertions(+)
diff --git a/c-user/object_services.rst b/c-user/object_services.rst
index 544ff02..860ce8c 100644
--- a/c-user/object_services.rst
+++ b/c-user/object_services.rst
@@ -49,6 +49,8 @@ them.  The object related services provided by RTEMS are:
 - rtems_object_get_class_information_ - obtain class information
+- rtems_object_get_local_node_ - obtain local node
 Background
@@ -785,3 +787,29 @@ DESCRIPTION:
 NOTES:
     This directive is strictly local and does not impact task scheduling.
+.. raw:: latex
+   \clearpage
+.. index:: obtain local node
+.. index:: rtems_object_get_local_node
+.. _rtems_object_get_local_node:
+OBJECT_GET_LOCAL_NODE - Obtain Local Node
+CALLING SEQUENCE:
+    .. code-block:: c
+        uint16_t rtems_object_get_local_node( void );
+DIRECTIVE STATUS CODES:
+    NONE
+DESCRIPTION:
+    This service returns the local MPCI node.
+NOTES:
+    This directive is strictly local and does not impact task scheduling.
2.16.4
