What should confdefs.h do if CONFIGURE_INIT is not defined?
Sebastian Huber
Wed Dec 18 15:55:52 UTC 2019
On 18/12/2019 05:57, Chris Johns wrote:
> On 18/12/19 1:28 am, Sebastian Huber wrote:
>> On 17/12/2019 15:13, Joel Sherrill wrote:
>>> Now I generally recommend putting RTEMS configuration and an init task
>>> to start RTEMS services in a dedicated file and invoking main() to start
>>> the application. There are some of the rtems-examples which follow this pattern.
>> Yes, this is in line with what I have seen in applications.
> +1
Ok, what is now the conclusion? Should I preserve the feature of
<rtems/confdefs.h> to expose the default values of some configuration
options? I tend to remove this feature. If an application wants to make
certain configuration settings globally visible it should to this with
its own defines.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
