[PATCH] config: CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
Sebastian Huber
Tue Dec 17 08:44:07 UTC 2019
Remove CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE.
Update #3844.
cpukit/include/rtems/confdefs.h | 58 ++++++++++++++++++++---------------------
1 file changed, 28 insertions(+), 30 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 05dfc3c91a..7c7b6fc601 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1557,8 +1557,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#include <libchip/ata.h>
#endif
-#ifndef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
* This specifies the maximum number of device drivers that
* can be installed in the system at one time. It must account
@@ -1622,8 +1620,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
RTEMS_ARRAY_SIZE( _IO_Driver_address_table );
#endif
-#endif /* CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE */
#ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
* configure the priority of the ATA driver task
@@ -2986,33 +2982,31 @@ struct _reent *__getreent(void)
#endif
#if !defined(RTEMS_SCHEDSIM)
- #if !defined(CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE)
- * You must either explicity include or exclude the clock driver.
- * It is such a common newbie error to leave it out. Maybe this
- * will put an end to it.
- * NOTE: If you are using the timer driver, it is considered
- * mutually exclusive with the clock driver because the
- * drivers are assumed to use the same "timer" hardware
- * on many boards.
- #if !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) && \
- !defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER) && \
- !defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER)
- #error "CONFIGURATION ERROR: Do you want the clock driver or not?!?"
- #endif
+ * You must either explicitly include or exclude the clock driver.
+ * It is such a common newbie error to leave it out. Maybe this
+ * will put an end to it.
+ * NOTE: If you are using the timer driver, it is considered
+ * mutually exclusive with the clock driver because the
+ * drivers are assumed to use the same "timer" hardware
+ * on many boards.
+#if !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) && \
+ !defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER) && \
+ !defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER)
+ #error "CONFIGURATION ERROR: Do you want the clock driver or not?!?"
+ #endif
- * Only one of the following three configuration parameters should be
- * defined at a time.
- #if ((defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) + \
- defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER) + \
- defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER)) > 1)
- #error "CONFIGURATION ERROR: More than one clock/timer driver configuration parameter specified?!?"
- #endif
- #endif /* !defined(CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE) */
+ * Only one of the following three configuration parameters should be
+ * defined at a time.
+#if ((defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) + \
+ defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER) + \
+ defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER)) > 1)
+ #error "CONFIGURATION ERROR: More than one clock/timer driver configuration parameter specified?!?"
+#endif
#endif /* !defined(RTEMS_SCHEDSIM) */
@@ -3047,6 +3041,10 @@ struct _reent *__getreent(void)
#warning "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1"
#endif
+#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
+ #warning "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
#warning "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
#endif
2.16.4
