raspberry BSP: Maybe there is a bug in the linker file?
Christian Mauderer
list at c-mauderer.de
Thu Dec 19 13:24:11 UTC 2019
Hello,
triggered by the discussion regarding RTEMS on raspberrypi 3 I did some
tests. I haven't been able to start a RTEMS on my Pi 1 if I tried a
version after commit c5fd79cd4704a4270ba0114a1009ab8556f997c9 from
29.07.2019. Right before it everything works as expected.
The commit changes the memory locations. From what I understood, the
bootloader on a raspberry always jumps to address 0x8000 after loading
the application. So I'm not convinced that the change is correct.
Did someone successfully start RTEMS on a Pi after that commit?
Best regards
Christian
