raspberry BSP: Maybe there is a bug in the linker file?
Sebastian Huber
Thu Dec 19 13:27:49 UTC 2019
On 19/12/2019 14:24, Christian Mauderer wrote:
> Hello,
> triggered by the discussion regarding RTEMS on raspberrypi 3 I did some
> tests. I haven't been able to start a RTEMS on my Pi 1 if I tried a
> version after commit c5fd79cd4704a4270ba0114a1009ab8556f997c9 from
> 29.07.2019. Right before it everything works as expected.
> The commit changes the memory locations. From what I understood, the
> bootloader on a raspberry always jumps to address 0x8000 after loading
> the application. So I'm not convinced that the change is correct.
Is the 0x8000 a fixed address or you configure this in a boot image header?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
