raspberry BSP: Maybe there is a bug in the linker file?
Fri Dec 20 06:33:17 UTC 2019
On 19/12/2019 15:28, Niteesh wrote:
> As far as I know, 0x8000 is a fixed address where the bootloader jumps
> to after loading the application assuming the CPU is in 32bit mode. For
> 64bit mode, it jumps to 0x80000.
Would you mind testing this patch:
https://lists.rtems.org/pipermail/devel/2019-December/056551.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
