raspberry BSP: Maybe there is a bug in the linker file?
Niteesh
gsnb.gn at gmail.com
Fri Dec 20 07:02:15 UTC 2019
I will do it by either today or tomorrow.
On Fri, 20 Dec, 2019, 12:03 PM Sebastian Huber, <
> On 19/12/2019 15:28, Niteesh wrote:
> > As far as I know, 0x8000 is a fixed address where the bootloader jumps
> > to after loading the application assuming the CPU is in 32bit mode. For
> > 64bit mode, it jumps to 0x80000.
> Would you mind testing this patch:
> https://lists.rtems.org/pipermail/devel/2019-December/056551.html
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191220/630e2462/attachment.html>
