raspberry BSP: Maybe there is a bug in the linker file?
Christian Mauderer
list at c-mauderer.de
Fri Dec 20 08:22:48 UTC 2019
On 20/12/2019 07:33, Sebastian Huber wrote:
> On 19/12/2019 15:28, Niteesh wrote:
>> As far as I know, 0x8000 is a fixed address where the bootloader jumps
>> to after loading the application assuming the CPU is in 32bit mode.
>> For 64bit mode, it jumps to 0x80000.
> Would you mind testing this patch:
> https://lists.rtems.org/pipermail/devel/2019-December/056551.html
On the Pi 1 now the binary has three time the size (with a lot of 0x00
in it) and at least RTEMS starts. But it runs into an exception quite
fast. I'll investigate that a bit.
@Niteesh: For the Pi 3 I would expect that it still doesn't print
anything on the console due to the different UART pins.
The output on the Pi 1 is:
executing�
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
R0 = 0xfc037f80 R8 = 0x00000000
R1 = 0xfc345980 R9 = 0x00000010
R2 = 0x00000001 R10 = 0xfc037f8a
R3 = 0x03fc8080 R11 = 0x0030da00
R4 = 0xfc037f80 R12 = 0xfc345988
R5 = 0x00000008 SP = 0x00300ba8
R6 = 0x0030d9fe LR = 0x00205a78
R7 = 0x00305218 PC = 0x00205ac8
CPSR = 0x600001d3 VEC = 0x00000004
RTEMS version: 5.0.0.254f38583fe68c3e17dfe274a2deeb00a5a538d6
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (6c65fc237b9e modified),
Newlib d14714c69)
