Raspberrypi3: Mini UART driver
Niteesh gsnb.gn at gmail.com
Wed Dec 25 09:50:04 UTC 2019
Just to make sure I am going in the right track.
I moved the uart register definitions to bsp/usart.h into a struct of
uint32_t called usart0_regs
here is git diff of usart.c after changing it to the latest console
interface.
diff --git a/bsps/arm/raspberrypi/console/usart.c
b/bsps/arm/raspberrypi/console/usart.c
index 25fb523621..b12f375a1c 100644
--- a/bsps/arm/raspberrypi/console/usart.c
+++ b/bsps/arm/raspberrypi/console/usart.c
@@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const console_tbl *ct)
 #endif
+typedef struct {
+  rtems_termios_device_context base;
+  const char *device_name;
+  volatile usart0_regs *regs;
+}uart0_context;
 static void usart_set_baud(int minor, int baud)
@@ -55,10 +61,17 @@ static void usart_set_baud(int minor, int baud)
  return;
-static void usart_initialize(int minor)
+static volatile usart0_regs
*rpi_uart_get_regs(rtems_termios_device_context *base)
-  unsigned int gpio_reg;
+  uart0_context *ctx;
+  ctx = (usart0_regs *) base;
+  return ctx->regs;
+static void usart_initialize(rtems_termios_device_context *base)
+  unsigned int gpio_reg;
   ** Program GPIO pins for UART 0
@@ -75,67 +88,81 @@ static void usart_initialize(int minor)
   usart_delay(150);
   BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
+  volatile uint32_t *uart_regs = rpi_uart_get_regs(base);
   ** Init the PL011 UART
-  BCM2835_REG(BCM2835_UART0_CR)   = 0;
-  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
-  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
-  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
-  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
-  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
-  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
-  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
-  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
-  usart_set_baud(minor, 115000);
+  uart_regs->cr  = 0;
+  uart_regs->icr = 0x7ff;
+  uart_regs->imsc = 0;
+  uart_regs->ibrd = 1;
+  uart_regs->fbrd= 40;
+  uart_regs->lcrh= 0x70;
+  uart_regs->rsrecr= 0;
+  uart_regs->cr = 0x301;
+  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
+  // usart_set_baud(minor, 115000);
-static int usart_first_open(int major, int minor, void *arg)
+static bool usart_first_open(
+  rtems_termios_tty *tty,
+  rtems_termios_device_context *base,
+  struct termios *term,
+  rtems_libio_open_close_args_t *args
-  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *)
arg;
-  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
oc->iop->data1;
-  const console_tbl *ct = Console_Port_Tbl [minor];
-  console_data *cd = &Console_Port_Data [minor];
+  rtems_status_code sc;
+  bool ok;
-  cd->termios_data = tty;
-  rtems_termios_set_initial_baud(tty, ct->ulClock);
+  ctx = (uart0_context *) base;
-  return 0;
+  usart_initialize(base);
+  sc = rtems_termios_set_initial_baud(tty,  USART0_DEFAULT_BAUD);
+  if ( sc != RTEMS_SUCCESSFUL ){
+    printk("Error setting the baud for termios\n");
+    return false;
-static int usart_last_close(int major, int minor, void *arg)
+static int usart_last_close(
+  rtems_termios_open_close_args_t *arg)
   return 0;
-static int usart_read_polled(int minor)
+static int usart_read_polled(rtems_termios_device_context *base)
-  if (minor == 0) {
-    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) == 0) {
-       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
-    } else {
-      return -1;
-  } else {
-    printk("Unknown console minor number: %d\n", minor);
-    return -1;
+  regs = rpi_uart_get_regs(base);
+  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
+    return (regs->dr & 0xFF);
+  return -1;
-static void usart_write_polled(int minor, char c)
+static void usart_write_polled(rtems_termios_device_context *base, char c)
-   while (1) {
-     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
-       break;
-   BCM2835_REG(BCM2835_UART0_DR) = c;
+  while (1) {
+    if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
+      break;
+  regs->dr = c;
 static ssize_t usart_write_support_polled(
-  int minor,
   const char *s,
   size_t n
@@ -143,7 +170,7 @@ static ssize_t usart_write_support_polled(
   ssize_t i = 0;
   for (i = 0; i < n; ++i) {
-    usart_write_polled(minor, s [i]);
+    usart_write_polled(base, s[i]);
   return n;
@@ -154,14 +181,11 @@ static int usart_set_attributes(int minor, const
struct termios *term)
   return -1;
-const console_fns bcm2835_usart_fns = {
-  .deviceProbe = libchip_serial_default_probe,
-  .deviceFirstOpen = usart_first_open,
-  .deviceLastClose = usart_last_close,
-  .deviceRead = usart_read_polled,
-  .deviceWrite = usart_write_support_polled,
-  .deviceInitialize = usart_initialize,
-  .deviceWritePolled = usart_write_polled,
-  .deviceSetAttributes = usart_set_attributes,
-  .deviceOutputUsesInterrupts = false
+const rtems_termios_device_handler bcm2835_uart0_handler_polled = {
+  .first_open = usart_first_open,
+  .last_close = usart_last_close,
+  .poll_read = usart_read_polled,
+  .set_attributes = usart_set_attributes,
+  .write = usart_write_support_polled,
+  .mode = TERMIOS_POLLED
\ No newline at end of file
On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Dec 24, 2019, 12:19 PM Niteesh <gsnb.gn at gmail.com> wrote:
>> And also the register definitions are in raspberrpi.h file should I move
>> them to usart.h.
> Sounds right if you mean bsp/usart.h
> I have a doubt we have a register field in device_context
>> typedef struct {
>> volatile some_chip_registers *regs;
>> } my_driver_context;
>> How does the reg field point to the correct memory location? for instance
>> in IMX BSP,
>> there is a struct with register field's but none of the define a memory
>> location?
> Make sure the structure has volatiles and proper alignment. :)
>> On Tue, Dec 24, 2019 at 11:37 PM Niteesh <gsnb.gn at gmail.com> wrote:
>>> How to handle different serial devices? In other BSPs the uart devices
>>> are the same, so
>>> they were able to put it under a single array? But here we have 2 uarts
>>> and a FB?
>>> On Tue, Dec 24, 2019 at 8:18 PM Christian Mauderer <list at c-mauderer.de>
>>> wrote:
>>>> On 24/12/2019 12:06, Niteesh wrote:
>>>> > The current raspi console section is like this:
>>>> > The bsp_console_select in console_select.c is responsible for
>>>> selecting
>>>> > between uart and the framebuffer. It does so
>>>> > by setting the Console_port_minor.
>>>> > The console_config is responsible for output_char function.
>>>> > And other files are driver code.
>>>> > If rewriting, this would be my approach,
>>>> > Rewrite the bsp_console_select to set some kind of a variable like in
>>>> > IMX, then in console_initialize function
>>>> > link the right driver to /dev/console.
>>>> > Replace the console_tbl with the device_context and console_fns with
>>>> > termios_device_handlers and
>>>> > finally add in the console_initialization function.
>>>> I agree that this would be a clean solution. So if you want you can do
>>>> that. But there might is a hurdle: As far as I understood you you only
>>>> have a Pi3? So you might have a hard time testing the changes. Maybe the
>>>> simulator could work.
>>>> Another possibility could be to set the "Console_port_minor" to
>>>> something unused (for example -1). In that case you can define another
>>>> /dev/console.
>>>> Best regards and merry Christmas (in case you celebrate)
>>>> Christian
>>>> > On Tue, Dec 24, 2019 at 2:13 PM Niteesh <gsnb.gn at gmail.com
>>>> > <mailto:gsnb.gn at gmail.com>> wrote:
>>>> >     Thank you so much, for such a detailed answer. Now things make
>>>> >     really good sense to me,
>>>> >     going through the code now is just a breeze. But I still have one
>>>> >     question
>>>> >     for the newer driver interface is console_initialize the function
>>>> >     which RTEMS calls while initializing
>>>> >     the console? Which means I can't mess with the name right? It is
>>>> >     similar to the main function, right?
>>>> >     The current driver is a legacy one, how do you want me to proceed,
>>>> >     shall I rewrite the legacy to a
>>>> >     the new one, this is will be a great learning experience for me
>>>> also
>>>> >     and we also get the BSP updated to the latest interface.
>>>> >     On Tue, Dec 24, 2019 at 3:20 AM Christian Mauderer
>>>> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>>>> >         Hello Niteesh,
>>>> >         quite a lot of questions. I'll try to answer them. Note that
>>>> it
>>>> >         has been
>>>> >         some time since I had a detailed look at that code so if
>>>> something I
>>>> >         tell seems odd please don't hesitate to question it.
>>>> >         Please note that in RTEMS their are more or less two "levels"
>>>> of
>>>> >         support
>>>> >         for a serial console:
>>>> >         1. A very basic polled system console (also known as
>>>> >         "debug-console" in
>>>> >         some BSPs). This one is used for printk and should work in
>>>> basically
>>>> >         every case. It is used for critical system messages like
>>>> >         printing the
>>>> >         exception frame. For that a BSP has to provide a
>>>> >         "BSP_output_char" function.
>>>> >         2. A full featured UART driver integrated into Termios. That
>>>> one
>>>> >         will be
>>>> >         used for all normal I/O on the UARTs.
>>>> >         As far as I know the "console_tbl Console_Configuration_Ports"
>>>> >         belongs
>>>> >         to a table based legacy interface. It is handled in the file
>>>> >         bsps/shared/dev/serial/legacy-console.c. I'm not sure whether
>>>> it is
>>>> >         documented in the BSP guide because it shouldn't be used for
>>>> new
>>>> >         BSPs.
>>>> >         Same is true for the "major" and "minor" stuff: It's not
>>>> really
>>>> >         used for
>>>> >         new drivers.
>>>> >         Newer drivers use the initialization that is described in the
>>>> manual
>>>> >         that you have already found. Basically they use
>>>> >         "rtems_termios_device_install" to register a new UART as
>>>> >         "/dev/ttySomething". Some recent (ARM) BSPs that do that are
>>>> the
>>>> >         imx or
>>>> >         the atsam.
>>>> >         The console that is used for stdin, stdout and stderr (printf,
>>>> >         scanf,
>>>> >         ...) is the one called "/dev/console" (defined in
>>>> >         CONSOLE_DEVICE_NAME).
>>>> >         For the legacy table based interface it's the one with the
>>>> index of
>>>> >         "Console_Port_Minor".
>>>> >         If you want to access any UART other than the one for stdin
>>>> and
>>>> >         stdout
>>>> >         you do that the same way like on Linux: Just use the "open"
>>>> >         function on
>>>> >         the "/dev/ttySomething" and use "read", "write" and simmilar
>>>> or use
>>>> >         "fopen" together with "fread", "fwrite", "fprintf", ...
>>>> >         "printf" (and family) is a function belonging to the C
>>>> library.
>>>> >         In our
>>>> >         case that's newlib. It will format your message and after
>>>> some other
>>>> >         preprocessing will call the "write" function of the file that
>>>> is
>>>> >         opened
>>>> >         as stdout (which is "/dev/console" in the default case).
>>>> >         I hope that I helped you with that explanation. Please feel
>>>> free
>>>> >         to ask
>>>> >         anything if it isn't clear.
>>>> >         Best regards
>>>> >         Christian
>>>> >         On 23/12/2019 19:50, Niteesh wrote:
>>>> >         > And finally, how does printf work? It is a macro? In that
>>>> >         case, how does
>>>> >         > any write to
>>>> >         > a console work?
>>>> >         > On Tue, Dec 24, 2019 at 12:18 AM Niteesh <gsnb.gn at gmail.com
>>>> >         > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>
>>>> wrote:
>>>> >         >     Is the correct port minor number set during the
>>>> >         initialization? What
>>>> >         >     is the application want's to
>>>> >         >     access some other port?
>>>> >         >     On Tue, Dec 24, 2019 at 12:16 AM Niteesh
>>>> >         <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>>>> wrote:
>>>> >         >         I would like to clarify my doubts regarding the
>>>> >         console driver.
>>>> >         >         I went through the documentation
>>>> >         >         for the console
>>>> >          driver
>>>> https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction
>>>> >         >         But it is quite different from how some BSPs
>>>> initialize.
>>>> >         >         Correct me if I am wrong
>>>> >         >         The console_tbl contains the various entries of
>>>> serial
>>>> >         ports.
>>>> >         >         The console_fns is a struct of function pointers,
>>>> >         which point to
>>>> >         >         the BSP uart functions.
>>>> >         >         The BSP_output_char_function_type is what will be
>>>> >         called for
>>>> >         >         printing a char on to the console.
>>>> >         >         How does RTEMS initialize the uart? It's seems not
>>>> to
>>>> >         be same
>>>> >         >         for all BSPs.
>>>> >         >         The doc says that the driver's initialization
>>>> function
>>>> >         is called
>>>> >         >         once during the rtems initialization process.
>>>> >         >         The console init function install the serial driver
>>>> using
>>>> >         >         rtems_termios_device_install but there seems to be
>>>> >         >         no such function in the raspberry pi? But there is a
>>>> >         entry in
>>>> >         >         console_fns for init function, but then how does it
>>>> >         >         gets called?
>>>> >         >         And for BSP's with multiple serial's, the output
>>>> function
>>>> >         >         chooses the right serial using console_port_minor,
>>>> >         >         Is it during initialization?
>>>> >         >         What is the need for get and set register
>>>> functions?
>>>> >         >         On Mon, Dec 23, 2019 at 1:04 AM Christian Mauderer
>>>> >         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>>>> wrote:
>>>> >         >             On 22/12/2019 19:45, Joel Sherrill wrote:
>>>> >         >             > On Sun, Dec 22, 2019, 12:29 PM Niteesh
>>>> >         <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
>>>> >         <mailto:gsnb.gn at gmail.com>>>> wrote:
>>>> >         >             >     On Sun, Dec 22, 2019 at 8:44 PM Christian
>>>> >         Mauderer
>>>> >         <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>>>> >         <mailto:list at c-mauderer.de>>>> wrote:
>>>> >         >             >         Hello Niteesh,
>>>> >         >             >         thanks for doing that work.
>>>> >         >             >         On 22/12/2019 12:10, Niteesh wrote:
>>>> >         >             >         > The rpi1 and rpi2 use the PL011
>>>> UART,
>>>> >         whereas,
>>>> >         >             with RPI's
>>>> >         >             >         equipped with
>>>> >         >             >         > wireless/Bluetooth module, the
>>>> PL011 is
>>>> >         >             connected to the Bluetooth
>>>> >         >             >         > module, and the mini UART is used as
>>>> >         the primary
>>>> >         >             UART.
>>>> >         >             >         In my opinion it would be great if you
>>>> >         could use
>>>> >         >             the FDT to
>>>> >         >             >         distinguish
>>>> >         >             >         between the boards. That should allow
>>>> to add
>>>> >         >             raspberry 3 (and
>>>> >         >             >         maybe 4)
>>>> >         >             >         support without adding another BSP.
>>>> More
>>>> >         BSPs mean
>>>> >         >             a bigger
>>>> >         >             >         maintenance
>>>> >         >             >         effort for the RTEMS community.
>>>> >         >             >     Learning more about FDT is on my list for
>>>> a long
>>>> >         >             time.  I would love
>>>> >         >             >     to work on that
>>>> >         >             >     but I have almost no exp with FDT's.
>>>> >         >             >     But another thing could also be done, in
>>>> >         >             >     raspberrypi/start/bspstart.c we get the
>>>> >         revision and
>>>> >         >             >     model of the board using the mailbox.
>>>> Every
>>>> >         board has
>>>> >         >             a unique id,
>>>> >         >             >     which we could use to initialize
>>>> >         >             >     the BSP. But using FDT seems to be a more
>>>> >         elegant
>>>> >         >             option, it is a
>>>> >         >             >     lot of work I think, but we could take
>>>> >         >             >     help from libbsd and linux I suppose. What
>>>> >         do you think?
>>>> >         >             > I think there are almost always two steps to a
>>>> >         project
>>>> >         >             like this: get it
>>>> >         >             > to work and make it nice. :)
>>>> >         >             > If you fix the startup code to read the board
>>>> >         revision and
>>>> >         >             memory size,
>>>> >         >             > you can get a working BSP that dynamically
>>>> >         adapts to the
>>>> >         >             models and
>>>> >         >             > memory variations with minimal modifications.
>>>> If
>>>> >         you want
>>>> >         >             to then
>>>> >         >             > convert the BSP to FDT, it will be a LOT
>>>> easier
>>>> >         to debug
>>>> >         >             with a working BSP.
>>>> >         >             > Plus you may be able to identify every
>>>> variation
>>>> >         point
>>>> >         >             based on just the
>>>> >         >             > model info. Then FDT is just a matter of
>>>> >         switching the
>>>> >         >             source of
>>>> >         >             > some/all of the info.
>>>> >         >             > That would be my work plan anyway.
>>>> >         >             I agree with Joel that a secure development
>>>> basis
>>>> >         (also
>>>> >         >             known as "hack")
>>>> >         >             as a first step is a good idea. You maybe even
>>>> >         just make the
>>>> >         >             mini UART
>>>> >         >             the default driver while you are developing.
>>>> Then
>>>> >         you can be
>>>> >         >             sure that
>>>> >         >             you have the right driver.
>>>> >         >             As soon as that works you can either change to
>>>> the
>>>> >         revision
>>>> >         >             method or
>>>> >         >             (better) to the FDT one and after that the
>>>> patches
>>>> >         can be
>>>> >         >             merged. Using
>>>> >         >             the FDT isn't that complicated. Basically you
>>>> >         search for a
>>>> >         >             node based on
>>>> >         >             different parameters. For an example you can
>>>> take
>>>> >         a look at
>>>> >         >             the imx BSP.
>>>> >         >             In imx_uart_probe
>>>> >         (bsps/arm/imx/console/console-config.c) a
>>>> >         >             fdt node is
>>>> >         >             searched and based on that a UART driver is
>>>> used.
>>>> >         But again:
>>>> >         >             Follow
>>>> >         >             Joels suggestion to start simple and secure.
>>>> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>>>> >         >             >         > But from the above doc (PAGE 10),
>>>> the
>>>> >         mini uart
>>>> >         >             has 16550 like
>>>> >         >             >         registers
>>>> >         >             >         > and RTEMS already has the driver
>>>> for it
>>>> >         >             >         > bsps/shared/dev/serial/ns16550.c.
>>>> But
>>>> >         I am not
>>>> >         >             sure how
>>>> >         >             >         compatible they
>>>> >         >             >         > are? Should a new driver be
>>>> >         implemented from
>>>> >         >             scratch or use
>>>> >         >             >         ns16550 if
>>>> >         >             >         > possible?
>>>> >         >             >         In general it's better to re-use
>>>> >         existing code.
>>>> >         >             That has multiple
>>>> >         >             >         advantages:
>>>> >         >             >         - It reduces the maintenance effort.
>>>> >         Fewer code
>>>> >         >             means fewer work.
>>>> >         >             >         - If you have multiple driver for the
>>>> >         same or
>>>> >         >             similar hardware
>>>> >         >             >         it can
>>>> >         >             >         happen that a bug is fixed in one but
>>>> >         not the other.
>>>> >         >             >         - It's simpler to find a hardware to
>>>> >         test changes.
>>>> >         >             >         - The driver becomes more universal
>>>> with
>>>> >         every new
>>>> >         >             supported
>>>> >         >             >         hardware.
>>>> >         >             >         That increases the chance that it fits
>>>> >         the next
>>>> >         >             new hardware.
>>>> >         >             >         I'm sure there are some more if you
>>>> ask
>>>> >         someone else.
>>>> >         >             >     I do understand the issues, I just spent
>>>> >         some time
>>>> >         >             reading the
>>>> >         >             >     driver code.
>>>> >         >             >     I think we could most probably use it. I
>>>> >         will take a
>>>> >         >             closer look and
>>>> >         >             >     will update.
>>>> >         >             Great.
>>>> >         >             >         > Also, the core clock on which the
>>>> >         PL011 is based
>>>> >         >             on is changed
>>>> >         >             >         in rpi3.
>>>> >         >             >         > Rpi1 and 2 use 250Mhz as the default
>>>> >         clock but
>>>> >         >             it was changed
>>>> >         >             >         to 400Mhz
>>>> >         >             >         > in Rpi3 and newer
>>>> >         >             >         Again: Would be great if that could be
>>>> >         adapted
>>>> >         >             based on FDT or by
>>>> >         >             >         reading the right registers.
>>>> >         >             >         > Few differences between PL011 and
>>>> Mini
>>>> >         uart
>>>> >         >             >         > The mini UART has smaller FIFOs.
>>>> >         Combined with
>>>> >         >             the lack of
>>>> >         >             >         flow control,
>>>> >         >             >         > this makes it more prone to losing
>>>> >         characters at
>>>> >         >             higher baud
>>>> >         >             >         rates. It
>>>> >         >             >         > is also generally less capable than
>>>> >         the PL011,
>>>> >         >             mainly due to
>>>> >         >             >         its baud
>>>> >         >             >         > rate link to the VPU clock speed.
>>>> >         >             >         That shouldn't really be a problem for
>>>> >         the system
>>>> >         >             console.
>>>> >         >             >         > The particular deficiencies of the
>>>> >         mini UART
>>>> >         >             compared to the
>>>> >         >             >         PL011 are :
>>>> >         >             >         > No break detection
>>>> >         >             >         > No framing errors detection
>>>> >         >             >         > No parity bit
>>>> >         >             >         > No receive timeout interrupt
>>>> >         >             >         > No DCD, DSR, DTR or RI signals
>>>>  _______________________________________________
>>>> >         >             >     devel mailing list
>>>> >         >             >     devel at rtems.org <mailto:devel at rtems.org>
>>>> >         <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>>>> >         <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191225/60354d2a/attachment-0001.html>
