Raspberrypi3: Mini UART driver
Niteesh gsnb.gn at gmail.com
Wed Dec 25 14:32:15 UTC 2019
What about the framebuffer it still uses minor and major's?
On Wed, Dec 25, 2019 at 3:20 PM Niteesh <gsnb.gn at gmail.com> wrote:
> Just to make sure I am going in the right track.
> I moved the uart register definitions to bsp/usart.h into a struct of
> uint32_t called usart0_regs
> here is git diff of usart.c after changing it to the latest console
> interface.
> diff --git a/bsps/arm/raspberrypi/console/usart.c
> b/bsps/arm/raspberrypi/console/usart.c
> index 25fb523621..b12f375a1c 100644
> --- a/bsps/arm/raspberrypi/console/usart.c
> +++ b/bsps/arm/raspberrypi/console/usart.c
> @@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const console_tbl *ct)
>  #endif
> +typedef struct {
> +  rtems_termios_device_context base;
> +  const char *device_name;
> +  volatile usart0_regs *regs;
> +}uart0_context;
>  static void usart_set_baud(int minor, int baud)
> @@ -55,10 +61,17 @@ static void usart_set_baud(int minor, int baud)
>   return;
> -static void usart_initialize(int minor)
> +static volatile usart0_regs
> *rpi_uart_get_regs(rtems_termios_device_context *base)
> -  unsigned int gpio_reg;
> +  uart0_context *ctx;
> +  ctx = (usart0_regs *) base;
> +  return ctx->regs;
> +static void usart_initialize(rtems_termios_device_context *base)
> +  unsigned int gpio_reg;
>    ** Program GPIO pins for UART 0
> @@ -75,67 +88,81 @@ static void usart_initialize(int minor)
>    usart_delay(150);
>    BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> +  volatile uint32_t *uart_regs = rpi_uart_get_regs(base);
>    ** Init the PL011 UART
> -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
> -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
> -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
> -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
> -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
> -  usart_set_baud(minor, 115000);
> +  uart_regs->cr  = 0;
> +  uart_regs->icr = 0x7ff;
> +  uart_regs->imsc = 0;
> +  uart_regs->ibrd = 1;
> +  uart_regs->fbrd= 40;
> +  uart_regs->lcrh= 0x70;
> +  uart_regs->rsrecr= 0;
> +  uart_regs->cr = 0x301;
> +  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
> +  // usart_set_baud(minor, 115000);
> -static int usart_first_open(int major, int minor, void *arg)
> +static bool usart_first_open(
> +  rtems_termios_tty *tty,
> +  rtems_termios_device_context *base,
> +  struct termios *term,
> +  rtems_libio_open_close_args_t *args
> -  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *)
> arg;
> -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
> oc->iop->data1;
> -  const console_tbl *ct = Console_Port_Tbl [minor];
> -  console_data *cd = &Console_Port_Data [minor];
> +  rtems_status_code sc;
> +  bool ok;
> -  cd->termios_data = tty;
> -  rtems_termios_set_initial_baud(tty, ct->ulClock);
> +  ctx = (uart0_context *) base;
> -  return 0;
> +  usart_initialize(base);
> +  sc = rtems_termios_set_initial_baud(tty,  USART0_DEFAULT_BAUD);
> +  if ( sc != RTEMS_SUCCESSFUL ){
> +    printk("Error setting the baud for termios\n");
> +    return false;
> -static int usart_last_close(int major, int minor, void *arg)
> +static int usart_last_close(
> +  rtems_termios_open_close_args_t *arg)
>    return 0;
> -static int usart_read_polled(int minor)
> +static int usart_read_polled(rtems_termios_device_context *base)
> -  if (minor == 0) {
> -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) == 0) {
> -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
> -    } else {
> -      return -1;
> -  } else {
> -    printk("Unknown console minor number: %d\n", minor);
> -    return -1;
> +  regs = rpi_uart_get_regs(base);
> +  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
> +    return (regs->dr & 0xFF);
> +  return -1;
> -static void usart_write_polled(int minor, char c)
> +static void usart_write_polled(rtems_termios_device_context *base, char c)
> -   while (1) {
> -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
> -       break;
> -   BCM2835_REG(BCM2835_UART0_DR) = c;
> +  while (1) {
> +    if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
> +      break;
> +  regs->dr = c;
>  static ssize_t usart_write_support_polled(
> -  int minor,
>    const char *s,
>    size_t n
> @@ -143,7 +170,7 @@ static ssize_t usart_write_support_polled(
>    ssize_t i = 0;
>    for (i = 0; i < n; ++i) {
> -    usart_write_polled(minor, s [i]);
> +    usart_write_polled(base, s[i]);
>    return n;
> @@ -154,14 +181,11 @@ static int usart_set_attributes(int minor, const
> struct termios *term)
>    return -1;
> -const console_fns bcm2835_usart_fns = {
> -  .deviceProbe = libchip_serial_default_probe,
> -  .deviceFirstOpen = usart_first_open,
> -  .deviceLastClose = usart_last_close,
> -  .deviceRead = usart_read_polled,
> -  .deviceWrite = usart_write_support_polled,
> -  .deviceInitialize = usart_initialize,
> -  .deviceWritePolled = usart_write_polled,
> -  .deviceSetAttributes = usart_set_attributes,
> -  .deviceOutputUsesInterrupts = false
> +const rtems_termios_device_handler bcm2835_uart0_handler_polled = {
> +  .first_open = usart_first_open,
> +  .last_close = usart_last_close,
> +  .poll_read = usart_read_polled,
> +  .set_attributes = usart_set_attributes,
> +  .write = usart_write_support_polled,
> +  .mode = TERMIOS_POLLED
> \ No newline at end of file
> On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Dec 24, 2019, 12:19 PM Niteesh <gsnb.gn at gmail.com> wrote:
>>> And also the register definitions are in raspberrpi.h file should I move
>>> them to usart.h.
>> Sounds right if you mean bsp/usart.h
>> I have a doubt we have a register field in device_context
>>> typedef struct {
>>> volatile some_chip_registers *regs;
>>> } my_driver_context;
>>> How does the reg field point to the correct memory location? for
>>> instance in IMX BSP,
>>> there is a struct with register field's but none of the define a memory
>>> location?
>> Make sure the structure has volatiles and proper alignment. :)
>>> On Tue, Dec 24, 2019 at 11:37 PM Niteesh <gsnb.gn at gmail.com> wrote:
>>>> How to handle different serial devices? In other BSPs the uart devices
>>>> are the same, so
>>>> they were able to put it under a single array? But here we have 2 uarts
>>>> and a FB?
>>>> On Tue, Dec 24, 2019 at 8:18 PM Christian Mauderer <list at c-mauderer.de>
>>>> wrote:
>>>>> On 24/12/2019 12:06, Niteesh wrote:
>>>>> > The current raspi console section is like this:
>>>>> > The bsp_console_select in console_select.c is responsible for
>>>>> selecting
>>>>> > between uart and the framebuffer. It does so
>>>>> > by setting the Console_port_minor.
>>>>> > The console_config is responsible for output_char function.
>>>>> > And other files are driver code.
>>>>> > If rewriting, this would be my approach,
>>>>> > Rewrite the bsp_console_select to set some kind of a variable like in
>>>>> > IMX, then in console_initialize function
>>>>> > link the right driver to /dev/console.
>>>>> > Replace the console_tbl with the device_context and console_fns with
>>>>> > termios_device_handlers and
>>>>> > finally add in the console_initialization function.
>>>>> I agree that this would be a clean solution. So if you want you can do
>>>>> that. But there might is a hurdle: As far as I understood you you only
>>>>> have a Pi3? So you might have a hard time testing the changes. Maybe
>>>>> the
>>>>> simulator could work.
>>>>> Another possibility could be to set the "Console_port_minor" to
>>>>> something unused (for example -1). In that case you can define another
>>>>> /dev/console.
>>>>> Best regards and merry Christmas (in case you celebrate)
>>>>> Christian
>>>>> > On Tue, Dec 24, 2019 at 2:13 PM Niteesh <gsnb.gn at gmail.com
>>>>> > <mailto:gsnb.gn at gmail.com>> wrote:
>>>>> >     Thank you so much, for such a detailed answer. Now things make
>>>>> >     really good sense to me,
>>>>> >     going through the code now is just a breeze. But I still have one
>>>>> >     question
>>>>> >     for the newer driver interface is console_initialize the function
>>>>> >     which RTEMS calls while initializing
>>>>> >     the console? Which means I can't mess with the name right? It is
>>>>> >     similar to the main function, right?
>>>>> >     The current driver is a legacy one, how do you want me to
>>>>> proceed,
>>>>> >     shall I rewrite the legacy to a
>>>>> >     the new one, this is will be a great learning experience for me
>>>>> also
>>>>> >     and we also get the BSP updated to the latest interface.
>>>>> >     On Tue, Dec 24, 2019 at 3:20 AM Christian Mauderer
>>>>> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>>>>> >         Hello Niteesh,
>>>>> >         quite a lot of questions. I'll try to answer them. Note that
>>>>> it
>>>>> >         has been
>>>>> >         some time since I had a detailed look at that code so if
>>>>> something I
>>>>> >         tell seems odd please don't hesitate to question it.
>>>>> >         Please note that in RTEMS their are more or less two
>>>>> "levels" of
>>>>> >         support
>>>>> >         for a serial console:
>>>>> >         1. A very basic polled system console (also known as
>>>>> >         "debug-console" in
>>>>> >         some BSPs). This one is used for printk and should work in
>>>>> basically
>>>>> >         every case. It is used for critical system messages like
>>>>> >         printing the
>>>>> >         exception frame. For that a BSP has to provide a
>>>>> >         "BSP_output_char" function.
>>>>> >         2. A full featured UART driver integrated into Termios. That
>>>>> one
>>>>> >         will be
>>>>> >         used for all normal I/O on the UARTs.
>>>>> >         As far as I know the "console_tbl
>>>>> Console_Configuration_Ports"
>>>>> >         belongs
>>>>> >         to a table based legacy interface. It is handled in the file
>>>>> >         bsps/shared/dev/serial/legacy-console.c. I'm not sure
>>>>> whether it is
>>>>> >         documented in the BSP guide because it shouldn't be used for
>>>>> new
>>>>> >         BSPs.
>>>>> >         Same is true for the "major" and "minor" stuff: It's not
>>>>> really
>>>>> >         used for
>>>>> >         new drivers.
>>>>> >         Newer drivers use the initialization that is described in
>>>>> the manual
>>>>> >         that you have already found. Basically they use
>>>>> >         "rtems_termios_device_install" to register a new UART as
>>>>> >         "/dev/ttySomething". Some recent (ARM) BSPs that do that are
>>>>> the
>>>>> >         imx or
>>>>> >         the atsam.
>>>>> >         The console that is used for stdin, stdout and stderr
>>>>> (printf,
>>>>> >         scanf,
>>>>> >         ...) is the one called "/dev/console" (defined in
>>>>> >         CONSOLE_DEVICE_NAME).
>>>>> >         For the legacy table based interface it's the one with the
>>>>> index of
>>>>> >         "Console_Port_Minor".
>>>>> >         If you want to access any UART other than the one for stdin
>>>>> and
>>>>> >         stdout
>>>>> >         you do that the same way like on Linux: Just use the "open"
>>>>> >         function on
>>>>> >         the "/dev/ttySomething" and use "read", "write" and simmilar
>>>>> or use
>>>>> >         "fopen" together with "fread", "fwrite", "fprintf", ...
>>>>> >         "printf" (and family) is a function belonging to the C
>>>>> library.
>>>>> >         In our
>>>>> >         case that's newlib. It will format your message and after
>>>>> some other
>>>>> >         preprocessing will call the "write" function of the file
>>>>> that is
>>>>> >         opened
>>>>> >         as stdout (which is "/dev/console" in the default case).
>>>>> >         I hope that I helped you with that explanation. Please feel
>>>>> free
>>>>> >         to ask
>>>>> >         anything if it isn't clear.
>>>>> >         Best regards
>>>>> >         Christian
>>>>> >         On 23/12/2019 19:50, Niteesh wrote:
>>>>> >         > And finally, how does printf work? It is a macro? In that
>>>>> >         case, how does
>>>>> >         > any write to
>>>>> >         > a console work?
>>>>> >         > On Tue, Dec 24, 2019 at 12:18 AM Niteesh <
>>>>> >         > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>
>>>>> wrote:
>>>>> >         >     Is the correct port minor number set during the
>>>>> >         initialization? What
>>>>> >         >     is the application want's to
>>>>> >         >     access some other port?
>>>>> >         >     On Tue, Dec 24, 2019 at 12:16 AM Niteesh
>>>>> >         <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>>>>> wrote:
>>>>> >         >         I would like to clarify my doubts regarding the
>>>>> >         console driver.
>>>>> >         >         I went through the documentation
>>>>> >         >         for the console
>>>>> >          driver
>>>>> https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction
>>>>> >         >         But it is quite different from how some BSPs
>>>>> initialize.
>>>>> >         >         Correct me if I am wrong
>>>>> >         >         The console_tbl contains the various entries of
>>>>> serial
>>>>> >         ports.
>>>>> >         >         The console_fns is a struct of function pointers,
>>>>> >         which point to
>>>>> >         >         the BSP uart functions.
>>>>> >         >         The BSP_output_char_function_type is what will be
>>>>> >         called for
>>>>> >         >         printing a char on to the console.
>>>>> >         >         How does RTEMS initialize the uart? It's seems not
>>>>> to
>>>>> >         be same
>>>>> >         >         for all BSPs.
>>>>> >         >         The doc says that the driver's initialization
>>>>> function
>>>>> >         is called
>>>>> >         >         once during the rtems initialization process.
>>>>> >         >         The console init function install the serial
>>>>> driver using
>>>>> >         >         rtems_termios_device_install but there seems to be
>>>>> >         >         no such function in the raspberry pi? But there is
>>>>> a
>>>>> >         entry in
>>>>> >         >         console_fns for init function, but then how does it
>>>>> >         >         gets called?
>>>>> >         >         And for BSP's with multiple serial's, the output
>>>>> function
>>>>> >         >         chooses the right serial using console_port_minor,
>>>>> >         >         Is it during initialization?
>>>>> >         >         What is the need for get and set register
>>>>> functions?
>>>>> >         >         On Mon, Dec 23, 2019 at 1:04 AM Christian Mauderer
>>>>> >         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>>>>> wrote:
>>>>> >         >             On 22/12/2019 19:45, Joel Sherrill wrote:
>>>>> >         >             > On Sun, Dec 22, 2019, 12:29 PM Niteesh
>>>>> >         <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
>>>>> >         <mailto:gsnb.gn at gmail.com>>>> wrote:
>>>>> >         >             >     On Sun, Dec 22, 2019 at 8:44 PM Christian
>>>>> >         Mauderer
>>>>> >         <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>>>>> >         <mailto:list at c-mauderer.de>>>> wrote:
>>>>> >         >             >         Hello Niteesh,
>>>>> >         >             >         thanks for doing that work.
>>>>> >         >             >         On 22/12/2019 12:10, Niteesh wrote:
>>>>> >         >             >         > The rpi1 and rpi2 use the PL011
>>>>> UART,
>>>>> >         whereas,
>>>>> >         >             with RPI's
>>>>> >         >             >         equipped with
>>>>> >         >             >         > wireless/Bluetooth module, the
>>>>> PL011 is
>>>>> >         >             connected to the Bluetooth
>>>>> >         >             >         > module, and the mini UART is used
>>>>> as
>>>>> >         the primary
>>>>> >         >             UART.
>>>>> >         >             >         In my opinion it would be great if
>>>>> you
>>>>> >         could use
>>>>> >         >             the FDT to
>>>>> >         >             >         distinguish
>>>>> >         >             >         between the boards. That should
>>>>> allow to add
>>>>> >         >             raspberry 3 (and
>>>>> >         >             >         maybe 4)
>>>>> >         >             >         support without adding another BSP.
>>>>> More
>>>>> >         BSPs mean
>>>>> >         >             a bigger
>>>>> >         >             >         maintenance
>>>>> >         >             >         effort for the RTEMS community.
>>>>> >         >             >     Learning more about FDT is on my list
>>>>> for a long
>>>>> >         >             time.  I would love
>>>>> >         >             >     to work on that
>>>>> >         >             >     but I have almost no exp with FDT's.
>>>>> >         >             >     But another thing could also be done, in
>>>>> >         >             >     raspberrypi/start/bspstart.c we get the
>>>>> >         revision and
>>>>> >         >             >     model of the board using the mailbox.
>>>>> Every
>>>>> >         board has
>>>>> >         >             a unique id,
>>>>> >         >             >     which we could use to initialize
>>>>> >         >             >     the BSP. But using FDT seems to be a more
>>>>> >         elegant
>>>>> >         >             option, it is a
>>>>> >         >             >     lot of work I think, but we could take
>>>>> >         >             >     help from libbsd and linux I suppose.
>>>>> What
>>>>> >         do you think?
>>>>> >         >             > I think there are almost always two steps to
>>>>> a
>>>>> >         project
>>>>> >         >             like this: get it
>>>>> >         >             > to work and make it nice. :)
>>>>> >         >             > If you fix the startup code to read the board
>>>>> >         revision and
>>>>> >         >             memory size,
>>>>> >         >             > you can get a working BSP that dynamically
>>>>> >         adapts to the
>>>>> >         >             models and
>>>>> >         >             > memory variations with minimal
>>>>> modifications. If
>>>>> >         you want
>>>>> >         >             to then
>>>>> >         >             > convert the BSP to FDT, it will be a LOT
>>>>> easier
>>>>> >         to debug
>>>>> >         >             with a working BSP.
>>>>> >         >             > Plus you may be able to identify every
>>>>> variation
>>>>> >         point
>>>>> >         >             based on just the
>>>>> >         >             > model info. Then FDT is just a matter of
>>>>> >         switching the
>>>>> >         >             source of
>>>>> >         >             > some/all of the info.
>>>>> >         >             > That would be my work plan anyway.
>>>>> >         >             I agree with Joel that a secure development
>>>>> basis
>>>>> >         (also
>>>>> >         >             known as "hack")
>>>>> >         >             as a first step is a good idea. You maybe even
>>>>> >         just make the
>>>>> >         >             mini UART
>>>>> >         >             the default driver while you are developing.
>>>>> Then
>>>>> >         you can be
>>>>> >         >             sure that
>>>>> >         >             you have the right driver.
>>>>> >         >             As soon as that works you can either change to
>>>>> the
>>>>> >         revision
>>>>> >         >             method or
>>>>> >         >             (better) to the FDT one and after that the
>>>>> patches
>>>>> >         can be
>>>>> >         >             merged. Using
>>>>> >         >             the FDT isn't that complicated. Basically you
>>>>> >         search for a
>>>>> >         >             node based on
>>>>> >         >             different parameters. For an example you can
>>>>> take
>>>>> >         a look at
>>>>> >         >             the imx BSP.
>>>>> >         >             In imx_uart_probe
>>>>> >         (bsps/arm/imx/console/console-config.c) a
>>>>> >         >             fdt node is
>>>>> >         >             searched and based on that a UART driver is
>>>>> used.
>>>>> >         But again:
>>>>> >         >             Follow
>>>>> >         >             Joels suggestion to start simple and secure.
>>>>> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>>>>> >         >             >         > But from the above doc (PAGE 10),
>>>>> the
>>>>> >         mini uart
>>>>> >         >             has 16550 like
>>>>> >         >             >         registers
>>>>> >         >             >         > and RTEMS already has the driver
>>>>> for it
>>>>> >         >             >         > bsps/shared/dev/serial/ns16550.c.
>>>>> But
>>>>> >         I am not
>>>>> >         >             sure how
>>>>> >         >             >         compatible they
>>>>> >         >             >         > are? Should a new driver be
>>>>> >         implemented from
>>>>> >         >             scratch or use
>>>>> >         >             >         ns16550 if
>>>>> >         >             >         > possible?
>>>>> >         >             >         In general it's better to re-use
>>>>> >         existing code.
>>>>> >         >             That has multiple
>>>>> >         >             >         advantages:
>>>>> >         >             >         - It reduces the maintenance effort.
>>>>> >         Fewer code
>>>>> >         >             means fewer work.
>>>>> >         >             >         - If you have multiple driver for the
>>>>> >         same or
>>>>> >         >             similar hardware
>>>>> >         >             >         it can
>>>>> >         >             >         happen that a bug is fixed in one but
>>>>> >         not the other.
>>>>> >         >             >         - It's simpler to find a hardware to
>>>>> >         test changes.
>>>>> >         >             >         - The driver becomes more universal
>>>>> with
>>>>> >         every new
>>>>> >         >             supported
>>>>> >         >             >         hardware.
>>>>> >         >             >         That increases the chance that it
>>>>> fits
>>>>> >         the next
>>>>> >         >             new hardware.
>>>>> >         >             >         I'm sure there are some more if you
>>>>> ask
>>>>> >         someone else.
>>>>> >         >             >     I do understand the issues, I just spent
>>>>> >         some time
>>>>> >         >             reading the
>>>>> >         >             >     driver code.
>>>>> >         >             >     I think we could most probably use it. I
>>>>> >         will take a
>>>>> >         >             closer look and
>>>>> >         >             >     will update.
>>>>> >         >             Great.
>>>>> >         >             >         > Also, the core clock on which the
>>>>> >         PL011 is based
>>>>> >         >             on is changed
>>>>> >         >             >         in rpi3.
>>>>> >         >             >         > Rpi1 and 2 use 250Mhz as the
>>>>> default
>>>>> >         clock but
>>>>> >         >             it was changed
>>>>> >         >             >         to 400Mhz
>>>>> >         >             >         > in Rpi3 and newer
>>>>> >         >             >         Again: Would be great if that could
>>>>> be
>>>>> >         adapted
>>>>> >         >             based on FDT or by
>>>>> >         >             >         reading the right registers.
>>>>> >         >             >         > Few differences between PL011 and
>>>>> Mini
>>>>> >         uart
>>>>> >         >             >         > The mini UART has smaller FIFOs.
>>>>> >         Combined with
>>>>> >         >             the lack of
>>>>> >         >             >         flow control,
>>>>> >         >             >         > this makes it more prone to losing
>>>>> >         characters at
>>>>> >         >             higher baud
>>>>> >         >             >         rates. It
>>>>> >         >             >         > is also generally less capable than
>>>>> >         the PL011,
>>>>> >         >             mainly due to
>>>>> >         >             >         its baud
>>>>> >         >             >         > rate link to the VPU clock speed.
>>>>> >         >             >         That shouldn't really be a problem
>>>>> for
>>>>> >         the system
>>>>> >         >             console.
>>>>> >         >             >         > The particular deficiencies of the
>>>>> >         mini UART
>>>>> >         >             compared to the
>>>>> >         >             >         PL011 are :
>>>>> >         >             >         > No break detection
>>>>> >         >             >         > No framing errors detection
>>>>> >         >             >         > No parity bit
>>>>> >         >             >         > No receive timeout interrupt
>>>>> >         >             >         > No DCD, DSR, DTR or RI signals
>>>>>  _______________________________________________
>>>>> >         >             >     devel mailing list
>>>>> >         >             >     devel at rtems.org <mailto:devel at rtems.org>
>>>>> >         <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>>>>> devel at rtems.org>
>>>>> >         <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191225/f702fcd1/attachment-0001.html>
