Raspberrypi3: Mini UART driver
Christian Mauderer
list at c-mauderer.de
Thu Dec 26 20:29:46 UTC 2019
On 25/12/2019 15:32, Niteesh wrote:
> What about the framebuffer it still uses minor and major's?
I'm not entirely sure but I don't think that it is a problem to mix
legacy and new style drivers.
> On Wed, Dec 25, 2019 at 3:20 PM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
> Just to make sure I am going in the right track.
> I moved the uart register definitions to bsp/usart.h into a struct
> of uint32_t called usart0_regs
> here is git diff of usart.c after changing it to the latest console
> interface.
> diff --git a/bsps/arm/raspberrypi/console/usart.c
> b/bsps/arm/raspberrypi/console/usart.c
> index 25fb523621..b12f375a1c 100644
> --- a/bsps/arm/raspberrypi/console/usart.c
> +++ b/bsps/arm/raspberrypi/console/usart.c
> @@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const console_tbl *ct)
> #endif
> +typedef struct {
> + rtems_termios_device_context base;
> + const char *device_name;
> + volatile usart0_regs *regs;
> +}uart0_context;
> static void usart_set_baud(int minor, int baud)
> @@ -55,10 +61,17 @@ static void usart_set_baud(int minor, int baud)
> return;
> -static void usart_initialize(int minor)
> +static volatile usart0_regs
> *rpi_uart_get_regs(rtems_termios_device_context *base)
> - unsigned int gpio_reg;
> + uart0_context *ctx;
> + ctx = (usart0_regs *) base;
> + return ctx->regs;
> +static void usart_initialize(rtems_termios_device_context *base)
> + unsigned int gpio_reg;
> ** Program GPIO pins for UART 0
> @@ -75,67 +88,81 @@ static void usart_initialize(int minor)
> usart_delay(150);
> BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> + volatile uint32_t *uart_regs = rpi_uart_get_regs(base);
> ** Init the PL011 UART
> - BCM2835_REG(BCM2835_UART0_CR) = 0;
> - BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
> - BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> - BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> - BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> - BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> - BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
> - BCM2835_REG(BCM2835_UART0_CR) = 0x301;
> - BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
> - usart_set_baud(minor, 115000);
> + uart_regs->cr = 0;
> + uart_regs->icr = 0x7ff;
> + uart_regs->imsc = 0;
> + uart_regs->ibrd = 1;
> + uart_regs->fbrd= 40;
> + uart_regs->lcrh= 0x70;
> + uart_regs->rsrecr= 0;
> + uart_regs->cr = 0x301;
> + uart_regs->imsc = BCM2835_UART0_IMSC_RX;
> + // usart_set_baud(minor, 115000);
> -static int usart_first_open(int major, int minor, void *arg)
> +static bool usart_first_open(
> + rtems_termios_tty *tty,
> + rtems_termios_device_context *base,
> + struct termios *term,
> + rtems_libio_open_close_args_t *args
> - rtems_libio_open_close_args_t *oc =
> (rtems_libio_open_close_args_t *) arg;
> - struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
> oc->iop->data1;
> - const console_tbl *ct = Console_Port_Tbl [minor];
> - console_data *cd = &Console_Port_Data [minor];
> + rtems_status_code sc;
> + bool ok;
> - cd->termios_data = tty;
> - rtems_termios_set_initial_baud(tty, ct->ulClock);
> + ctx = (uart0_context *) base;
> - return 0;
> + usart_initialize(base);
> + sc = rtems_termios_set_initial_baud(tty, USART0_DEFAULT_BAUD);
> + if ( sc != RTEMS_SUCCESSFUL ){
> + printk("Error setting the baud for termios\n");
> + return false;
> -static int usart_last_close(int major, int minor, void *arg)
> +static int usart_last_close(
> + rtems_termios_open_close_args_t *arg)
> return 0;
> -static int usart_read_polled(int minor)
> +static int usart_read_polled(rtems_termios_device_context *base)
> - if (minor == 0) {
> - if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
> == 0) {
> - return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
> - } else {
> - return -1;
> - } else {
> - printk("Unknown console minor number: %d\n", minor);
> - return -1;
> + regs = rpi_uart_get_regs(base);
> + if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
> + return (regs->dr & 0xFF);
> + return -1;
> -static void usart_write_polled(int minor, char c)
> +static void usart_write_polled(rtems_termios_device_context *base,
> char c)
> - while (1) {
> - if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
> - break;
> - BCM2835_REG(BCM2835_UART0_DR) = c;
> + while (1) {
> + if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
> + break;
> + regs->dr = c;
> static ssize_t usart_write_support_polled(
> - int minor,
> const char *s,
> size_t n
> @@ -143,7 +170,7 @@ static ssize_t usart_write_support_polled(
> ssize_t i = 0;
> for (i = 0; i < n; ++i) {
> - usart_write_polled(minor, s [i]);
> + usart_write_polled(base, s[i]);
> return n;
> @@ -154,14 +181,11 @@ static int usart_set_attributes(int minor,
> const struct termios *term)
> return -1;
> -const console_fns bcm2835_usart_fns = {
> - .deviceProbe = libchip_serial_default_probe,
> - .deviceFirstOpen = usart_first_open,
> - .deviceLastClose = usart_last_close,
> - .deviceRead = usart_read_polled,
> - .deviceWrite = usart_write_support_polled,
> - .deviceInitialize = usart_initialize,
> - .deviceWritePolled = usart_write_polled,
> - .deviceSetAttributes = usart_set_attributes,
> - .deviceOutputUsesInterrupts = false
> +const rtems_termios_device_handler bcm2835_uart0_handler_polled = {
> + .first_open = usart_first_open,
> + .last_close = usart_last_close,
> + .poll_read = usart_read_polled,
> + .set_attributes = usart_set_attributes,
> + .write = usart_write_support_polled,
> + .mode = TERMIOS_POLLED
> \ No newline at end of file
> On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
> On Tue, Dec 24, 2019, 12:19 PM Niteesh <gsnb.gn at gmail.com
> And also the register definitions are in raspberrpi.h file
> should I move them to usart.h.
> Sounds right if you mean bsp/usart.h
> I have a doubt we have a register field in device_context
> typedef struct {
> volatile some_chip_registers *regs;
> } my_driver_context;
> How does the reg field point to the correct memory location?
> for instance in IMX BSP,
> there is a struct with register field's but none of the
> define a memory location?
> Make sure the structure has volatiles and proper alignment. :)
> On Tue, Dec 24, 2019 at 11:37 PM Niteesh <gsnb.gn at gmail.com
> How to handle different serial devices? In other BSPs
> the uart devices are the same, so
> they were able to put it under a single array? But here
> we have 2 uarts and a FB?
> On Tue, Dec 24, 2019 at 8:18 PM Christian Mauderer
> <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
> On 24/12/2019 12:06, Niteesh wrote:
> > The current raspi console section is like this:
> > The bsp_console_select in console_select.c is
> responsible for selecting
> > between uart and the framebuffer. It does so
> > by setting the Console_port_minor.
> > The console_config is responsible for output_char
> function.
> > And other files are driver code.
> > If rewriting, this would be my approach,
> > Rewrite the bsp_console_select to set some kind of
> a variable like in
> > IMX, then in console_initialize function
> > link the right driver to /dev/console.
> > Replace the console_tbl with the device_context
> and console_fns with
> > termios_device_handlers and
> > finally add in the console_initialization function.
> I agree that this would be a clean solution. So if
> you want you can do
> that. But there might is a hurdle: As far as I
> understood you you only
> have a Pi3? So you might have a hard time testing
> the changes. Maybe the
> simulator could work.
> Another possibility could be to set the
> "Console_port_minor" to
> something unused (for example -1). In that case you
> can define another
> /dev/console.
> Best regards and merry Christmas (in case you celebrate)
> Christian
> > On Tue, Dec 24, 2019 at 2:13 PM Niteesh
> <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
> <mailto:gsnb.gn at gmail.com>>> wrote:
> > Thank you so much, for such a detailed answer.
> Now things make
> > really good sense to me,
> > going through the code now is just a breeze.
> But I still have one
> > question
> > for the newer driver interface is
> console_initialize the function
> > which RTEMS calls while initializing
> > the console? Which means I can't mess with the
> name right? It is
> > similar to the main function, right?
> > The current driver is a legacy one, how do you
> want me to proceed,
> > shall I rewrite the legacy to a
> > the new one, this is will be a great
> learning experience for me also
> > and we also get the BSP updated to the latest
> interface.
> > On Tue, Dec 24, 2019 at 3:20 AM Christian Mauderer
> <mailto:list at c-mauderer.de>>> wrote:
> > Hello Niteesh,
> > quite a lot of questions. I'll try to
> answer them. Note that it
> > has been
> > some time since I had a detailed look at
> that code so if something I
> > tell seems odd please don't hesitate to
> question it.
> > Please note that in RTEMS their are more
> or less two "levels" of
> > support
> > for a serial console:
> > 1. A very basic polled system console
> (also known as
> > "debug-console" in
> > some BSPs). This one is used for printk
> and should work in basically
> > every case. It is used for critical system
> messages like
> > printing the
> > exception frame. For that a BSP has to
> provide a
> > "BSP_output_char" function.
> > 2. A full featured UART driver integrated
> into Termios. That one
> > will be
> > used for all normal I/O on the UARTs.
> > As far as I know the "console_tbl
> Console_Configuration_Ports"
> > belongs
> > to a table based legacy interface. It is
> handled in the file
> > bsps/shared/dev/serial/legacy-console.c.
> I'm not sure whether it is
> > documented in the BSP guide because it
> shouldn't be used for new
> > BSPs.
> > Same is true for the "major" and "minor"
> stuff: It's not really
> > used for
> > new drivers.
> > Newer drivers use the initialization that
> is described in the manual
> > that you have already found. Basically
> they use
> > "rtems_termios_device_install" to register
> a new UART as
> > "/dev/ttySomething". Some recent (ARM)
> BSPs that do that are the
> > imx or
> > the atsam.
> > The console that is used for stdin, stdout
> and stderr (printf,
> > scanf,
> > ...) is the one called "/dev/console"
> (defined in
> > CONSOLE_DEVICE_NAME).
> > For the legacy table based interface it's
> the one with the index of
> > "Console_Port_Minor".
> > If you want to access any UART other than
> the one for stdin and
> > stdout
> > you do that the same way like on Linux:
> Just use the "open"
> > function on
> > the "/dev/ttySomething" and use "read",
> "write" and simmilar or use
> > "fopen" together with "fread", "fwrite",
> "fprintf", ...
> > "printf" (and family) is a function
> belonging to the C library.
> > In our
> > case that's newlib. It will format your
> message and after some other
> > preprocessing will call the "write"
> function of the file that is
> > opened
> > as stdout (which is "/dev/console" in the
> default case).
> > I hope that I helped you with that
> explanation. Please feel free
> > to ask
> > anything if it isn't clear.
> > Best regards
> > Christian
> > On 23/12/2019 19:50, Niteesh wrote:
> > > And finally, how does printf work? It is
> a macro? In that
> > case, how does
> > > any write to
> > > a console work?
> > > On Tue, Dec 24, 2019 at 12:18 AM Niteesh
> <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>>>> wrote:
> > > Is the correct port minor number set
> during the
> > initialization? What
> > > is the application want's to
> > > access some other port?
> > > On Tue, Dec 24, 2019 at 12:16 AM Niteesh
> > > I would like to clarify my
> doubts regarding the
> > console driver.
> > > I went through the documentation
> > > for the console
> driver https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction.
> > > But it is quite different from
> how some BSPs initialize.
> > > Correct me if I am wrong
> > > The console_tbl contains the
> various entries of serial
> > ports.
> > > The console_fns is a struct of
> function pointers,
> > which point to
> > > the BSP uart functions.
> > > The
> BSP_output_char_function_type is what will be
> > called for
> > > printing a char on to the console.
> > > How does RTEMS initialize the
> uart? It's seems not to
> > be same
> > > for all BSPs.
> > > The doc says that the driver's
> > is called
> > > once during the rtems
> initialization process.
> > > The console init function
> install the serial driver using
> > > rtems_termios_device_install but
> there seems to be
> > > no such function in the
> raspberry pi? But there is a
> > entry in
> > > console_fns for init function,
> but then how does it
> > > gets called?
> > > And for BSP's with multiple
> serial's, the output function
> > > chooses the right serial using
> console_port_minor,
> > > Is it during initialization?
> > > What is the need for get and set
> register functions?
> > > On Mon, Dec 23, 2019 at 1:04 AM
> Christian Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
> <mailto:list at c-mauderer.de>>>> wrote:
> > > On 22/12/2019 19:45, Joel
> Sherrill wrote:
> > > > On Sun, Dec 22, 2019,
> 12:29 PM Niteesh
> <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
> at 8:44 PM Christian
> > Mauderer
> <mailto:list at c-mauderer.de>>>>> wrote:
> > > > Hello Niteesh,
> > > > thanks for doing
> that work.
> > > > On 22/12/2019
> 12:10, Niteesh wrote:
> > > > > The rpi1 and
> rpi2 use the PL011 UART,
> > whereas,
> > > with RPI's
> > > > equipped with
> wireless/Bluetooth module, the PL011 is
> > > connected to the Bluetooth
> > > > > module, and the
> mini UART is used as
> > the primary
> > > UART.
> > > > In my opinion it
> would be great if you
> > could use
> > > the FDT to
> > > > distinguish
> > > > between the
> boards. That should allow to add
> > > raspberry 3 (and
> > > > maybe 4)
> > > > support without
> adding another BSP. More
> > BSPs mean
> > > a bigger
> > > > maintenance
> > > > effort for the
> RTEMS community.
> > > > Learning more about
> FDT is on my list for a long
> > > time. I would love
> > > > to work on that
> > > > but I have almost no
> exp with FDT's.
> > > > But another thing
> could also be done, in
> raspberrypi/start/bspstart.c we get the
> > revision and
> > > > model of the board
> using the mailbox. Every
> > board has
> > > a unique id,
> > > > which we could use to
> initialize
> > > > the BSP. But using FDT
> seems to be a more
> > elegant
> > > option, it is a
> > > > lot of work I think,
> but we could take
> > > > help from libbsd and
> linux I suppose. What
> > do you think?
> > > > I think there are almost
> always two steps to a
> > project
> > > like this: get it
> > > > to work and make it nice. :)
> > > > If you fix the startup
> code to read the board
> > revision and
> > > memory size,
> > > > you can get a working BSP
> that dynamically
> > adapts to the
> > > models and
> > > > memory variations with
> minimal modifications. If
> > you want
> > > to then
> > > > convert the BSP to FDT, it
> will be a LOT easier
> > to debug
> > > with a working BSP.
> > > > Plus you may be able to
> identify every variation
> > point
> > > based on just the
> > > > model info. Then FDT is
> just a matter of
> > switching the
> > > source of
> > > > some/all of the info.
> > > > That would be my work plan
> anyway.
> > > I agree with Joel that a
> secure development basis
> > (also
> > > known as "hack")
> > > as a first step is a good
> idea. You maybe even
> > just make the
> > > mini UART
> > > the default driver while you
> are developing. Then
> > you can be
> > > sure that
> > > you have the right driver.
> > > As soon as that works you
> can either change to the
> > revision
> > > method or
> > > (better) to the FDT one and
> after that the patches
> > can be
> > > merged. Using
> > > the FDT isn't that
> complicated. Basically you
> > search for a
> > > node based on
> > > different parameters. For an
> example you can take
> > a look at
> > > the imx BSP.
> > > In imx_uart_probe
> > (bsps/arm/imx/console/console-config.c) a
> > > fdt node is
> > > searched and based on that a
> UART driver is used.
> > But again:
> > > Follow
> > > Joels suggestion to start
> simple and secure.
> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
> > > > > But from the
> above doc (PAGE 10), the
> > mini uart
> > > has 16550 like
> > > > registers
> > > > > and RTEMS
> already has the driver for it
> bsps/shared/dev/serial/ns16550.c. But
> > I am not
> > > sure how
> > > > compatible they
> > > > > are? Should a
> new driver be
> > implemented from
> > > scratch or use
> > > > ns16550 if
> > > > > possible?
> > > > In general it's
> better to re-use
> > existing code.
> > > That has multiple
> > > > advantages:
> > > > - It reduces the
> maintenance effort.
> > Fewer code
> > > means fewer work.
> > > > - If you have
> multiple driver for the
> > same or
> > > similar hardware
> > > > it can
> > > > happen that a bug
> is fixed in one but
> > not the other.
> > > > - It's simpler to
> find a hardware to
> > test changes.
> > > > - The driver
> becomes more universal with
> > every new
> > > supported
> > > > hardware.
> > > > That increases the
> chance that it fits
> > the next
> > > new hardware.
> > > > I'm sure there are
> some more if you ask
> > someone else.
> > > > I do understand the
> issues, I just spent
> > some time
> > > reading the
> > > > driver code.
> > > > I think we could most
> probably use it. I
> > will take a
> > > closer look and
> > > > will update.
> > > Great.
> > > > > Also, the core
> clock on which the
> > PL011 is based
> > > on is changed
> > > > in rpi3.
> > > > > Rpi1 and 2 use
> 250Mhz as the default
> > clock but
> > > it was changed
> > > > to 400Mhz
> > > > > in Rpi3 and newer
> > > > Again: Would be
> great if that could be
> > adapted
> > > based on FDT or by
> > > > reading the right
> registers.
> > > > > Few differences
> between PL011 and Mini
> > uart
> > > > > The mini UART
> has smaller FIFOs.
> > Combined with
> > > the lack of
> > > > flow control,
> > > > > this makes it
> more prone to losing
> > characters at
> > > higher baud
> > > > rates. It
> > > > > is also
> generally less capable than
> > the PL011,
> > > mainly due to
> > > > its baud
> > > > > rate link to the
> VPU clock speed.
> > > > That shouldn't
> really be a problem for
> > the system
> > > console.
> > > > > The particular
> deficiencies of the
> > mini UART
> > > compared to the
> > > > PL011 are :
> > > > > No break detection
> > > > > No framing
> errors detection
> > > > > No parity bit
> > > > > No receive
> timeout interrupt
> > > > > No DCD, DSR, DTR
> or RI signals
> > > > devel mailing list
> > > > devel at rtems.org
> <mailto:devel at rtems.org> <mailto:devel at rtems.org
> <mailto:devel at rtems.org>>
> <mailto:devel at rtems.org>>>
> <mailto:devel at rtems.org>>>>
