Raspberrypi3: Mini UART driver
Niteesh gsnb.gn at gmail.com
Fri Dec 27 08:35:26 UTC 2019
Does the device's initialization happen in the first_open function for the
new interface? Because the old legacy driver
call's the initialization function directly.
On Fri, Dec 27, 2019 at 2:00 PM Niteesh <gsnb.gn at gmail.com> wrote:
> On Fri, Dec 27, 2019 at 1:59 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> On 25/12/2019 15:32, Niteesh wrote:
>> > What about the framebuffer it still uses minor and major's?
>> I'm not entirely sure but I don't think that it is a problem to mix
>> legacy and new style drivers.
> I want to create rtems_termios_device_handler for the framebuffer, the
> current driver uses console_fns and
> the functions have the old signatures, which uses major and minor numbers,
> but the device handler uses the newer interface
> static bool my_driver_first_open(
>   rtems_termios_tty             *tty,
>   rtems_termios_device_context  *base,
>   struct termios                *term,
>   rtems_libio_open_close_args_t *args)
> as mentioned in the doc will it cause any trouble? If it does then will
> also have to rewrite the fb right?
>> > On Wed, Dec 25, 2019 at 3:20 PM Niteesh <gsnb.gn at gmail.com
>> > <mailto:gsnb.gn at gmail.com>> wrote:
>> >     Just to make sure I am going in the right track.
>> >     I moved the uart register definitions to bsp/usart.h into a struct
>> >     of uint32_t called usart0_regs
>> >     here is git diff of usart.c after changing it to the latest console
>> >     interface.
>> >     diff --git a/bsps/arm/raspberrypi/console/usart.c
>> >     b/bsps/arm/raspberrypi/console/usart.c
>> >     index 25fb523621..b12f375a1c 100644
>> >     --- a/bsps/arm/raspberrypi/console/usart.c
>> >     +++ b/bsps/arm/raspberrypi/console/usart.c
>> >     @@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const console_tbl
>> *ct)
>> >      #endif
>> >     +typedef struct {
>> >     +  rtems_termios_device_context base;
>> >     +  const char *device_name;
>> >     +  volatile usart0_regs *regs;
>> >     +}uart0_context;
>> >      static void usart_set_baud(int minor, int baud)
>> >     @@ -55,10 +61,17 @@ static void usart_set_baud(int minor, int baud)
>> >       return;
>> >     -static void usart_initialize(int minor)
>> >     +static volatile usart0_regs
>> >     *rpi_uart_get_regs(rtems_termios_device_context *base)
>> >     -  unsigned int gpio_reg;
>> >     +  uart0_context *ctx;
>> >     +  ctx = (usart0_regs *) base;
>> >     +  return ctx->regs;
>> >     +static void usart_initialize(rtems_termios_device_context *base)
>> >     +  unsigned int gpio_reg;
>> >        ** Program GPIO pins for UART 0
>> >     @@ -75,67 +88,81 @@ static void usart_initialize(int minor)
>> >        usart_delay(150);
>> >        BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>> >     +  volatile uint32_t *uart_regs = rpi_uart_get_regs(base);
>> >        ** Init the PL011 UART
>> >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>> >     -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>> >     -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>> >     -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>> >     -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>> >     -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>> >     -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>> >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>> >     -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>> >     -  usart_set_baud(minor, 115000);
>> >     +  uart_regs->cr  = 0;
>> >     +  uart_regs->icr = 0x7ff;
>> >     +  uart_regs->imsc = 0;
>> >     +  uart_regs->ibrd = 1;
>> >     +  uart_regs->fbrd= 40;
>> >     +  uart_regs->lcrh= 0x70;
>> >     +  uart_regs->rsrecr= 0;
>> >     +  uart_regs->cr = 0x301;
>> >     +  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
>> >     +  // usart_set_baud(minor, 115000);
>> >     -static int usart_first_open(int major, int minor, void *arg)
>> >     +static bool usart_first_open(
>> >     +  rtems_termios_tty *tty,
>> >     +  rtems_termios_device_context *base,
>> >     +  struct termios *term,
>> >     +  rtems_libio_open_close_args_t *args
>> >     -  rtems_libio_open_close_args_t *oc =
>> >     (rtems_libio_open_close_args_t *) arg;
>> >     -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>> >     oc->iop->data1;
>> >     -  const console_tbl *ct = Console_Port_Tbl [minor];
>> >     -  console_data *cd = &Console_Port_Data [minor];
>> >     +  rtems_status_code sc;
>> >     +  bool ok;
>> >     -  cd->termios_data = tty;
>> >     -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>> >     +  ctx = (uart0_context *) base;
>> >     -  return 0;
>> >     +  usart_initialize(base);
>> >     +  sc = rtems_termios_set_initial_baud(tty,  USART0_DEFAULT_BAUD);
>> >     +  if ( sc != RTEMS_SUCCESSFUL ){
>> >     +    printk("Error setting the baud for termios\n");
>> >     +    return false;
>> >     -static int usart_last_close(int major, int minor, void *arg)
>> >     +static int usart_last_close(
>> >     +  rtems_termios_open_close_args_t *arg)
>> >        return 0;
>> >     -static int usart_read_polled(int minor)
>> >     +static int usart_read_polled(rtems_termios_device_context *base)
>> >     -  if (minor == 0) {
>> >     -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>> >     == 0) {
>> >     -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>> >     -    } else {
>> >     -      return -1;
>> >     -  } else {
>> >     -    printk("Unknown console minor number: %d\n", minor);
>> >     -    return -1;
>> >     +  regs = rpi_uart_get_regs(base);
>> >     +  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
>> >     +    return (regs->dr & 0xFF);
>> >     +  return -1;
>> >     -static void usart_write_polled(int minor, char c)
>> >     +static void usart_write_polled(rtems_termios_device_context *base,
>> >     char c)
>> >     -   while (1) {
>> >     -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF)
>> == 0)
>> >     -       break;
>> >     -   BCM2835_REG(BCM2835_UART0_DR) = c;
>> >     +  while (1) {
>> >     +    if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
>> >     +      break;
>> >     +  regs->dr = c;
>> >      static ssize_t usart_write_support_polled(
>> >     -  int minor,
>> >        const char *s,
>> >        size_t n
>> >     @@ -143,7 +170,7 @@ static ssize_t usart_write_support_polled(
>> >        ssize_t i = 0;
>> >        for (i = 0; i < n; ++i) {
>> >     -    usart_write_polled(minor, s [i]);
>> >     +    usart_write_polled(base, s[i]);
>> >        return n;
>> >     @@ -154,14 +181,11 @@ static int usart_set_attributes(int minor,
>> >     const struct termios *term)
>> >        return -1;
>> >     -const console_fns bcm2835_usart_fns = {
>> >     -  .deviceProbe = libchip_serial_default_probe,
>> >     -  .deviceFirstOpen = usart_first_open,
>> >     -  .deviceLastClose = usart_last_close,
>> >     -  .deviceRead = usart_read_polled,
>> >     -  .deviceWrite = usart_write_support_polled,
>> >     -  .deviceInitialize = usart_initialize,
>> >     -  .deviceWritePolled = usart_write_polled,
>> >     -  .deviceSetAttributes = usart_set_attributes,
>> >     -  .deviceOutputUsesInterrupts = false
>> >     +const rtems_termios_device_handler bcm2835_uart0_handler_polled = {
>> >     +  .first_open = usart_first_open,
>> >     +  .last_close = usart_last_close,
>> >     +  .poll_read = usart_read_polled,
>> >     +  .set_attributes = usart_set_attributes,
>> >     +  .write = usart_write_support_polled,
>> >     +  .mode = TERMIOS_POLLED
>> >     \ No newline at end of file
>> >     On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill <joel at rtems.org
>> >     <mailto:joel at rtems.org>> wrote:
>> >         On Tue, Dec 24, 2019, 12:19 PM Niteesh <gsnb.gn at gmail.com
>> >             And also the register definitions are in raspberrpi.h file
>> >             should I move them to usart.h.
>> >         Sounds right if you mean bsp/usart.h
>> >             I have a doubt we have a register field in device_context
>> >             typedef struct {
>> >                 volatile some_chip_registers *regs;
>> >             } my_driver_context;
>> >             How does the reg field point to the correct memory location?
>> >             for instance in IMX BSP,
>> >             there is a struct with register field's but none of the
>> >             define a memory location?
>> >         Make sure the structure has volatiles and proper alignment. :)
>> >             On Tue, Dec 24, 2019 at 11:37 PM Niteesh <gsnb.gn at gmail.com
>> >                 How to handle different serial devices? In other BSPs
>> >                 the uart devices are the same, so
>> >                 they were able to put it under a single array? But here
>> >                 we have 2 uarts and a FB?
>> >                 On Tue, Dec 24, 2019 at 8:18 PM Christian Mauderer
>> >                 <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>> >                     On 24/12/2019 12:06, Niteesh wrote:
>> >                     > The current raspi console section is like this:
>> >                     > The bsp_console_select in console_select.c is
>> >                     responsible for selecting
>> >                     > between uart and the framebuffer. It does so
>> >                     > by setting the Console_port_minor.
>> >                     > The console_config is responsible for output_char
>> >                     function.
>> >                     > And other files are driver code.
>> >                     > If rewriting, this would be my approach,
>> >                     > Rewrite the bsp_console_select to set some kind of
>> >                     a variable like in
>> >                     > IMX, then in console_initialize function
>> >                     > link the right driver to /dev/console.
>> >                     > Replace the console_tbl with the device_context
>> >                     and console_fns with
>> >                     > termios_device_handlers and
>> >                     > finally add in the console_initialization
>> function.
>> >                     I agree that this would be a clean solution. So if
>> >                     you want you can do
>> >                     that. But there might is a hurdle: As far as I
>> >                     understood you you only
>> >                     have a Pi3? So you might have a hard time testing
>> >                     the changes. Maybe the
>> >                     simulator could work.
>> >                     Another possibility could be to set the
>> >                     "Console_port_minor" to
>> >                     something unused (for example -1). In that case you
>> >                     can define another
>> >                     /dev/console.
>> >                     Best regards and merry Christmas (in case you
>> celebrate)
>> >                     Christian
>> >                     > On Tue, Dec 24, 2019 at 2:13 PM Niteesh
>> >                     <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>> >                     <mailto:gsnb.gn at gmail.com>>> wrote:
>> >                     >     Thank you so much, for such a detailed answer.
>> >                     Now things make
>> >                     >     really good sense to me,
>> >                     >     going through the code now is just a breeze.
>> >                     But I still have one
>> >                     >     question
>> >                     >     for the newer driver interface is
>> >                     console_initialize the function
>> >                     >     which RTEMS calls while initializing
>> >                     >     the console? Which means I can't mess with the
>> >                     name right? It is
>> >                     >     similar to the main function, right?
>> >                     >     The current driver is a legacy one, how do you
>> >                     want me to proceed,
>> >                     >     shall I rewrite the legacy to a
>> >                     >     the new one, this is will be a great
>> >                     learning experience for me also
>> >                     >     and we also get the BSP updated to the latest
>> >                     interface.
>> >                     >     On Tue, Dec 24, 2019 at 3:20 AM Christian
>> Mauderer
>> >                     <mailto:list at c-mauderer.de>>> wrote:
>> >                     >         Hello Niteesh,
>> >                     >         quite a lot of questions. I'll try to
>> >                     answer them. Note that it
>> >                     >         has been
>> >                     >         some time since I had a detailed look at
>> >                     that code so if something I
>> >                     >         tell seems odd please don't hesitate to
>> >                     question it.
>> >                     >         Please note that in RTEMS their are more
>> >                     or less two "levels" of
>> >                     >         support
>> >                     >         for a serial console:
>> >                     >         1. A very basic polled system console
>> >                     (also known as
>> >                     >         "debug-console" in
>> >                     >         some BSPs). This one is used for printk
>> >                     and should work in basically
>> >                     >         every case. It is used for critical system
>> >                     messages like
>> >                     >         printing the
>> >                     >         exception frame. For that a BSP has to
>> >                     provide a
>> >                     >         "BSP_output_char" function.
>> >                     >         2. A full featured UART driver integrated
>> >                     into Termios. That one
>> >                     >         will be
>> >                     >         used for all normal I/O on the UARTs.
>> >                     >         As far as I know the "console_tbl
>> >                     Console_Configuration_Ports"
>> >                     >         belongs
>> >                     >         to a table based legacy interface. It is
>> >                     handled in the file
>> >                     >         bsps/shared/dev/serial/legacy-console.c.
>> >                     I'm not sure whether it is
>> >                     >         documented in the BSP guide because it
>> >                     shouldn't be used for new
>> >                     >         BSPs.
>> >                     >         Same is true for the "major" and "minor"
>> >                     stuff: It's not really
>> >                     >         used for
>> >                     >         new drivers.
>> >                     >         Newer drivers use the initialization that
>> >                     is described in the manual
>> >                     >         that you have already found. Basically
>> >                     they use
>> >                     >         "rtems_termios_device_install" to register
>> >                     a new UART as
>> >                     >         "/dev/ttySomething". Some recent (ARM)
>> >                     BSPs that do that are the
>> >                     >         imx or
>> >                     >         the atsam.
>> >                     >         The console that is used for stdin, stdout
>> >                     and stderr (printf,
>> >                     >         scanf,
>> >                     >         ...) is the one called "/dev/console"
>> >                     (defined in
>> >                     >         CONSOLE_DEVICE_NAME).
>> >                     >         For the legacy table based interface it's
>> >                     the one with the index of
>> >                     >         "Console_Port_Minor".
>> >                     >         If you want to access any UART other than
>> >                     the one for stdin and
>> >                     >         stdout
>> >                     >         you do that the same way like on Linux:
>> >                     Just use the "open"
>> >                     >         function on
>> >                     >         the "/dev/ttySomething" and use "read",
>> >                     "write" and simmilar or use
>> >                     >         "fopen" together with "fread", "fwrite",
>> >                     "fprintf", ...
>> >                     >         "printf" (and family) is a function
>> >                     belonging to the C library.
>> >                     >         In our
>> >                     >         case that's newlib. It will format your
>> >                     message and after some other
>> >                     >         preprocessing will call the "write"
>> >                     function of the file that is
>> >                     >         opened
>> >                     >         as stdout (which is "/dev/console" in the
>> >                     default case).
>> >                     >         I hope that I helped you with that
>> >                     explanation. Please feel free
>> >                     >         to ask
>> >                     >         anything if it isn't clear.
>> >                     >         Best regards
>> >                     >         Christian
>> >                     >         On 23/12/2019 19:50, Niteesh wrote:
>> >                     >         > And finally, how does printf work? It is
>> >                     a macro? In that
>> >                     >         case, how does
>> >                     >         > any write to
>> >                     >         > a console work?
>> >                     >         > On Tue, Dec 24, 2019 at 12:18 AM Niteesh
>> >                     <mailto:gsnb.gn at gmail.com> <mailto:
>> >                     <mailto:gsnb.gn at gmail.com>>>> wrote:
>> >                     >         >     Is the correct port minor number set
>> >                     during the
>> >                     >         initialization? What
>> >                     >         >     is the application want's to
>> >                     >         >     access some other port?
>> >                     >         >     On Tue, Dec 24, 2019 at 12:16 AM
>> Niteesh
>> >                     >         >         I would like to clarify my
>> >                     doubts regarding the
>> >                     >         console driver.
>> >                     >         >         I went through the documentation
>> >                     >         >         for the console
>> >                       driver
>> https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction
>> >                     >         >         But it is quite different from
>> >                     how some BSPs initialize.
>> >                     >         >         Correct me if I am wrong
>> >                     >         >         The console_tbl contains the
>> >                     various entries of serial
>> >                     >         ports.
>> >                     >         >         The console_fns is a struct of
>> >                     function pointers,
>> >                     >         which point to
>> >                     >         >         the BSP uart functions.
>> >                     >         >         The
>> >                     BSP_output_char_function_type is what will be
>> >                     >         called for
>> >                     >         >         printing a char on to the
>> console.
>> >                     >         >         How does RTEMS initialize the
>> >                     uart? It's seems not to
>> >                     >         be same
>> >                     >         >         for all BSPs.
>> >                     >         >         The doc says that the driver's
>> >                     >         is called
>> >                     >         >         once during the rtems
>> >                     initialization process.
>> >                     >         >         The console init function
>> >                     install the serial driver using
>> >                     >         >         rtems_termios_device_install but
>> >                     there seems to be
>> >                     >         >         no such function in the
>> >                     raspberry pi? But there is a
>> >                     >         entry in
>> >                     >         >         console_fns for init function,
>> >                     but then how does it
>> >                     >         >         gets called?
>> >                     >         >         And for BSP's with multiple
>> >                     serial's, the output function
>> >                     >         >         chooses the right serial using
>> >                     console_port_minor,
>> >                     >         >         Is it during initialization?
>> >                     >         >         What is the need for get and set
>> >                     register functions?
>> >                     >         >         On Mon, Dec 23, 2019 at 1:04 AM
>> >                     Christian Mauderer
>> >                     <mailto:list at c-mauderer.de <mailto:
>> >                     <mailto:list at c-mauderer.de>>>> wrote:
>> >                     >         >             On 22/12/2019 19:45, Joel
>> >                     Sherrill wrote:
>> >                     >         >             > On Sun, Dec 22, 2019,
>> >                     12:29 PM Niteesh
>> >                     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com
>> >                     at 8:44 PM Christian
>> >                     >         Mauderer
>> >                     <mailto:list at c-mauderer.de>>>>> wrote:
>> >                     >         >             >         Hello Niteesh,
>> >                     >         >             >         thanks for doing
>> >                     that work.
>> >                     >         >             >         On 22/12/2019
>> >                     12:10, Niteesh wrote:
>> >                     >         >             >         > The rpi1 and
>> >                     rpi2 use the PL011 UART,
>> >                     >         whereas,
>> >                     >         >             with RPI's
>> >                     >         >             >         equipped with
>> >                     wireless/Bluetooth module, the PL011 is
>> >                     >         >             connected to the Bluetooth
>> >                     >         >             >         > module, and the
>> >                     mini UART is used as
>> >                     >         the primary
>> >                     >         >             UART.
>> >                     >         >             >         In my opinion it
>> >                     would be great if you
>> >                     >         could use
>> >                     >         >             the FDT to
>> >                     >         >             >         distinguish
>> >                     >         >             >         between the
>> >                     boards. That should allow to add
>> >                     >         >             raspberry 3 (and
>> >                     >         >             >         maybe 4)
>> >                     >         >             >         support without
>> >                     adding another BSP. More
>> >                     >         BSPs mean
>> >                     >         >             a bigger
>> >                     >         >             >         maintenance
>> >                     >         >             >         effort for the
>> >                     RTEMS community.
>> >                     >         >             >     Learning more about
>> >                     FDT is on my list for a long
>> >                     >         >             time.  I would love
>> >                     >         >             >     to work on that
>> >                     >         >             >     but I have almost no
>> >                     exp with FDT's.
>> >                     >         >             >     But another thing
>> >                     could also be done, in
>> >                      raspberrypi/start/bspstart.c we get the
>> >                     >         revision and
>> >                     >         >             >     model of the board
>> >                     using the mailbox. Every
>> >                     >         board has
>> >                     >         >             a unique id,
>> >                     >         >             >     which we could use to
>> >                     initialize
>> >                     >         >             >     the BSP. But using FDT
>> >                     seems to be a more
>> >                     >         elegant
>> >                     >         >             option, it is a
>> >                     >         >             >     lot of work I think,
>> >                     but we could take
>> >                     >         >             >     help from libbsd and
>> >                     linux I suppose. What
>> >                     >         do you think?
>> >                     >         >             > I think there are almost
>> >                     always two steps to a
>> >                     >         project
>> >                     >         >             like this: get it
>> >                     >         >             > to work and make it nice.
>> >                     >         >             > If you fix the startup
>> >                     code to read the board
>> >                     >         revision and
>> >                     >         >             memory size,
>> >                     >         >             > you can get a working BSP
>> >                     that dynamically
>> >                     >         adapts to the
>> >                     >         >             models and
>> >                     >         >             > memory variations with
>> >                     minimal modifications. If
>> >                     >         you want
>> >                     >         >             to then
>> >                     >         >             > convert the BSP to FDT, it
>> >                     will be a LOT easier
>> >                     >         to debug
>> >                     >         >             with a working BSP.
>> >                     >         >             > Plus you may be able to
>> >                     identify every variation
>> >                     >         point
>> >                     >         >             based on just the
>> >                     >         >             > model info. Then FDT is
>> >                     just a matter of
>> >                     >         switching the
>> >                     >         >             source of
>> >                     >         >             > some/all of the info.
>> >                     >         >             > That would be my work plan
>> >                     anyway.
>> >                     >         >             I agree with Joel that a
>> >                     secure development basis
>> >                     >         (also
>> >                     >         >             known as "hack")
>> >                     >         >             as a first step is a good
>> >                     idea. You maybe even
>> >                     >         just make the
>> >                     >         >             mini UART
>> >                     >         >             the default driver while you
>> >                     are developing. Then
>> >                     >         you can be
>> >                     >         >             sure that
>> >                     >         >             you have the right driver.
>> >                     >         >             As soon as that works you
>> >                     can either change to the
>> >                     >         revision
>> >                     >         >             method or
>> >                     >         >             (better) to the FDT one and
>> >                     after that the patches
>> >                     >         can be
>> >                     >         >             merged. Using
>> >                     >         >             the FDT isn't that
>> >                     complicated. Basically you
>> >                     >         search for a
>> >                     >         >             node based on
>> >                     >         >             different parameters. For an
>> >                     example you can take
>> >                     >         a look at
>> >                     >         >             the imx BSP.
>> >                     >         >             In imx_uart_probe
>> >                     >         (bsps/arm/imx/console/console-config.c) a
>> >                     >         >             fdt node is
>> >                     >         >             searched and based on that a
>> >                     UART driver is used.
>> >                     >         But again:
>> >                     >         >             Follow
>> >                     >         >             Joels suggestion to start
>> >                     simple and secure.
>> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>> >                     >         >             >         > But from the
>> >                     above doc (PAGE 10), the
>> >                     >         mini uart
>> >                     >         >             has 16550 like
>> >                     >         >             >         registers
>> >                     >         >             >         > and RTEMS
>> >                     already has the driver for it
>> >                     bsps/shared/dev/serial/ns16550.c. But
>> >                     >         I am not
>> >                     >         >             sure how
>> >                     >         >             >         compatible they
>> >                     >         >             >         > are? Should a
>> >                     new driver be
>> >                     >         implemented from
>> >                     >         >             scratch or use
>> >                     >         >             >         ns16550 if
>> >                     >         >             >         > possible?
>> >                     >         >             >         In general it's
>> >                     better to re-use
>> >                     >         existing code.
>> >                     >         >             That has multiple
>> >                     >         >             >         advantages:
>> >                     >         >             >         - It reduces the
>> >                     maintenance effort.
>> >                     >         Fewer code
>> >                     >         >             means fewer work.
>> >                     >         >             >         - If you have
>> >                     multiple driver for the
>> >                     >         same or
>> >                     >         >             similar hardware
>> >                     >         >             >         it can
>> >                     >         >             >         happen that a bug
>> >                     is fixed in one but
>> >                     >         not the other.
>> >                     >         >             >         - It's simpler to
>> >                     find a hardware to
>> >                     >         test changes.
>> >                     >         >             >         - The driver
>> >                     becomes more universal with
>> >                     >         every new
>> >                     >         >             supported
>> >                     >         >             >         hardware.
>> >                     >         >             >         That increases the
>> >                     chance that it fits
>> >                     >         the next
>> >                     >         >             new hardware.
>> >                     >         >             >         I'm sure there are
>> >                     some more if you ask
>> >                     >         someone else.
>> >                     >         >             >     I do understand the
>> >                     issues, I just spent
>> >                     >         some time
>> >                     >         >             reading the
>> >                     >         >             >     driver code.
>> >                     >         >             >     I think we could most
>> >                     probably use it. I
>> >                     >         will take a
>> >                     >         >             closer look and
>> >                     >         >             >     will update.
>> >                     >         >             Great.
>> >                     >         >             >         > Also, the core
>> >                     clock on which the
>> >                     >         PL011 is based
>> >                     >         >             on is changed
>> >                     >         >             >         in rpi3.
>> >                     >         >             >         > Rpi1 and 2 use
>> >                     250Mhz as the default
>> >                     >         clock but
>> >                     >         >             it was changed
>> >                     >         >             >         to 400Mhz
>> >                     >         >             >         > in Rpi3 and
>> newer
>> >                     >         >             >         Again: Would be
>> >                     great if that could be
>> >                     >         adapted
>> >                     >         >             based on FDT or by
>> >                     >         >             >         reading the right
>> >                     registers.
>> >                     >         >             >         > Few differences
>> >                     between PL011 and Mini
>> >                     >         uart
>> >                     >         >             >         > The mini UART
>> >                     has smaller FIFOs.
>> >                     >         Combined with
>> >                     >         >             the lack of
>> >                     >         >             >         flow control,
>> >                     >         >             >         > this makes it
>> >                     more prone to losing
>> >                     >         characters at
>> >                     >         >             higher baud
>> >                     >         >             >         rates. It
>> >                     >         >             >         > is also
>> >                     generally less capable than
>> >                     >         the PL011,
>> >                     >         >             mainly due to
>> >                     >         >             >         its baud
>> >                     >         >             >         > rate link to the
>> >                     VPU clock speed.
>> >                     >         >             >         That shouldn't
>> >                     really be a problem for
>> >                     >         the system
>> >                     >         >             console.
>> >                     >         >             >         > The particular
>> >                     deficiencies of the
>> >                     >         mini UART
>> >                     >         >             compared to the
>> >                     >         >             >         PL011 are :
>> >                     >         >             >         > No break
>> detection
>> >                     >         >             >         > No framing
>> >                     errors detection
>> >                     >         >             >         > No parity bit
>> >                     >         >             >         > No receive
>> >                     timeout interrupt
>> >                     >         >             >         > No DCD, DSR, DTR
>> >                     or RI signals
>> >                      _______________________________________________
>> >                     >         >             >     devel mailing list
>> >                     >         >             >     devel at rtems.org
>> >                     <mailto:devel at rtems.org> <mailto:devel at rtems.org
>> >                     <mailto:devel at rtems.org>>
>> >                     <mailto:devel at rtems.org>>>
>> >                     <mailto:devel at rtems.org>>>>
>> >                      http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191227/631c8260/attachment-0001.html>
