Raspberrypi3: Mini UART driver
Christian Mauderer list at c-mauderer.de
Fri Dec 27 09:38:34 UTC 2019
On 27/12/2019 09:35, Niteesh wrote:
> Does the device's initialization happen in the first_open function for
> the new interface? Because the old legacy driver
> call's the initialization function directly.
Depending on what you do during initialization you can do it there. But
you have to clean up everything during last_close that you initialize
during first_open.
I _think_ (would have to check to be sure) that first_open can be called
multiple times. A case where that would happen should be the following:
- I assume that "/dev/ttyX" is the serial interface you are working on
and I assume it's _not_ the system console (otherwise it would be open
during start).
- Start of program:
- fd1 = open("/dev/ttyX")
  -> first_open is called
- fd2 = open("/dev/ttyX")
  -> first_open is _not_ called
- do some stuff with fd1 and fd2
- close(fd1)
  -> last_close is _not_ called
- close(fd2)
  -> last_close is called
  -> first_open is called again
> On Fri, Dec 27, 2019 at 2:00 PM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
>     On Fri, Dec 27, 2019 at 1:59 AM Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>         On 25/12/2019 15:32, Niteesh wrote:
>         > What about the framebuffer it still uses minor and major's?
>         I'm not entirely sure but I don't think that it is a problem to mix
>         legacy and new style drivers.
>     I want to create rtems_termios_device_handler for the framebuffer,
>     the current driver uses console_fns and
>     the functions have the old signatures, which uses major and minor
>     numbers, but the device handler uses the newer interface
>     staticboolmy_driver_first_open(
>       rtems_termios_tty             *tty,
>       rtems_termios_device_context  *base,
>       struct termios                *term,
>       rtems_libio_open_close_args_t *args
>     as mentioned in the doc will it cause any trouble? If it does then
>     will also have to rewrite the fb right?
>         > On Wed, Dec 25, 2019 at 3:20 PM Niteesh <gsnb.gn at gmail.com
>         > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>> wrote:
>         >     Just to make sure I am going in the right track.
>         >     I moved the uart register definitions to bsp/usart.h into
>         a struct
>         >     of uint32_t called usart0_regs
>         >     here is git diff of usart.c after changing it to the
>         latest console
>         >     interface.
>         >     diff --git a/bsps/arm/raspberrypi/console/usart.c
>         >     b/bsps/arm/raspberrypi/console/usart.c
>         >     index 25fb523621..b12f375a1c 100644
>         >     --- a/bsps/arm/raspberrypi/console/usart.c
>         >     +++ b/bsps/arm/raspberrypi/console/usart.c
>         >     @@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const
>         console_tbl *ct)
>         >      #endif
>         >     +typedef struct {
>         >     +  rtems_termios_device_context base;
>         >     +  const char *device_name;
>         >     +  volatile usart0_regs *regs;
>         >     +}uart0_context;
>         >      static void usart_set_baud(int minor, int baud)
>         >     @@ -55,10 +61,17 @@ static void usart_set_baud(int minor,
>         int baud)
>         >       return;
>         >     -static void usart_initialize(int minor)
>         >     +static volatile usart0_regs
>         >     *rpi_uart_get_regs(rtems_termios_device_context *base)
>         >     -  unsigned int gpio_reg;
>         >     +  uart0_context *ctx;
>         >     +  ctx = (usart0_regs *) base;
>         >     +  return ctx->regs;
>         >     +static void usart_initialize(rtems_termios_device_context
>         *base)
>         >     +  unsigned int gpio_reg;
>         >        ** Program GPIO pins for UART 0
>         >     @@ -75,67 +88,81 @@ static void usart_initialize(int minor)
>         >        usart_delay(150);
>         >        BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>         >     +  volatile uint32_t *uart_regs = rpi_uart_get_regs(base);
>         >        ** Init the PL011 UART
>         >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>         >     -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>         >     -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>         >     -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>         >     -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>         >     -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>         >     -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>         >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>         >     -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>         >     -  usart_set_baud(minor, 115000);
>         >     +  uart_regs->cr  = 0;
>         >     +  uart_regs->icr = 0x7ff;
>         >     +  uart_regs->imsc = 0;
>         >     +  uart_regs->ibrd = 1;
>         >     +  uart_regs->fbrd= 40;
>         >     +  uart_regs->lcrh= 0x70;
>         >     +  uart_regs->rsrecr= 0;
>         >     +  uart_regs->cr = 0x301;
>         >     +  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
>         >     +  // usart_set_baud(minor, 115000);
>         >     -static int usart_first_open(int major, int minor, void *arg)
>         >     +static bool usart_first_open(
>         >     +  rtems_termios_tty *tty,
>         >     +  rtems_termios_device_context *base,
>         >     +  struct termios *term,
>         >     +  rtems_libio_open_close_args_t *args
>         >     -  rtems_libio_open_close_args_t *oc =
>         >     (rtems_libio_open_close_args_t *) arg;
>         >     -  struct rtems_termios_tty *tty = (struct
>         rtems_termios_tty *)
>         >     oc->iop->data1;
>         >     -  const console_tbl *ct = Console_Port_Tbl [minor];
>         >     -  console_data *cd = &Console_Port_Data [minor];
>         >     +  rtems_status_code sc;
>         >     +  bool ok;
>         >     -  cd->termios_data = tty;
>         >     -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>         >     +  ctx = (uart0_context *) base;
>         >     -  return 0;
>         >     +  usart_initialize(base);
>         >     +  sc = rtems_termios_set_initial_baud(tty,
>          USART0_DEFAULT_BAUD);
>         >     +  if ( sc != RTEMS_SUCCESSFUL ){
>         >     +    printk("Error setting the baud for termios\n");
>         >     +    return false;
>         >     -static int usart_last_close(int major, int minor, void *arg)
>         >     +static int usart_last_close(
>         >     +  rtems_termios_open_close_args_t *arg)
>         >        return 0;
>         >     -static int usart_read_polled(int minor)
>         >     +static int usart_read_polled(rtems_termios_device_context
>         *base)
>         >     -  if (minor == 0) {
>         >     -    if (((BCM2835_REG(BCM2835_UART0_FR)) &
>         BCM2835_UART0_FR_RXFE)
>         >     == 0) {
>         >     -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>         >     -    } else {
>         >     -      return -1;
>         >     -  } else {
>         >     -    printk("Unknown console minor number: %d\n", minor);
>         >     -    return -1;
>         >     +  regs = rpi_uart_get_regs(base);
>         >     +  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
>         >     +    return (regs->dr & 0xFF);
>         >     +  return -1;
>         >     -static void usart_write_polled(int minor, char c)
>         >     +static void
>         usart_write_polled(rtems_termios_device_context *base,
>         >     char c)
>         >     -   while (1) {
>         >     -     if ((BCM2835_REG(BCM2835_UART0_FR) &
>         BCM2835_UART0_FR_TXFF) == 0)
>         >     -       break;
>         >     -   BCM2835_REG(BCM2835_UART0_DR) = c;
>         >     +  while (1) {
>         >     +    if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
>         >     +      break;
>         >     +  regs->dr = c;
>         >      static ssize_t usart_write_support_polled(
>         >     -  int minor,
>         >        const char *s,
>         >        size_t n
>         >     @@ -143,7 +170,7 @@ static ssize_t usart_write_support_polled(
>         >        ssize_t i = 0;
>         >        for (i = 0; i < n; ++i) {
>         >     -    usart_write_polled(minor, s [i]);
>         >     +    usart_write_polled(base, s[i]);
>         >        return n;
>         >     @@ -154,14 +181,11 @@ static int usart_set_attributes(int
>         minor,
>         >     const struct termios *term)
>         >        return -1;
>         >     -const console_fns bcm2835_usart_fns = {
>         >     -  .deviceProbe = libchip_serial_default_probe,
>         >     -  .deviceFirstOpen = usart_first_open,
>         >     -  .deviceLastClose = usart_last_close,
>         >     -  .deviceRead = usart_read_polled,
>         >     -  .deviceWrite = usart_write_support_polled,
>         >     -  .deviceInitialize = usart_initialize,
>         >     -  .deviceWritePolled = usart_write_polled,
>         >     -  .deviceSetAttributes = usart_set_attributes,
>         >     -  .deviceOutputUsesInterrupts = false
>         >     +const rtems_termios_device_handler
>         bcm2835_uart0_handler_polled = {
>         >     +  .first_open = usart_first_open,
>         >     +  .last_close = usart_last_close,
>         >     +  .poll_read = usart_read_polled,
>         >     +  .set_attributes = usart_set_attributes,
>         >     +  .write = usart_write_support_polled,
>         >     +  .mode = TERMIOS_POLLED
>         >     \ No newline at end of file
>         >     On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill
>         <joel at rtems.org <mailto:joel at rtems.org>
>         >     <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>         >         On Tue, Dec 24, 2019, 12:19 PM Niteesh
>         <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>         wrote:
>         >             And also the register definitions are in
>         raspberrpi.h file
>         >             should I move them to usart.h.
>         >         Sounds right if you mean bsp/usart.h
>         >             I have a doubt we have a register field in
>         device_context
>         >             typedef struct {
>         >                 volatile some_chip_registers *regs;
>         >             } my_driver_context;
>         >             How does the reg field point to the correct
>         memory location?
>         >             for instance in IMX BSP,
>         >             there is a struct with register field's but none
>         of the
>         >             define a memory location?
>         >         Make sure the structure has volatiles and proper
>         alignment. :)
>         >             On Tue, Dec 24, 2019 at 11:37 PM Niteesh
>         >                 How to handle different serial devices? In
>         other BSPs
>         >                 the uart devices are the same, so
>         >                 they were able to put it under a single array?
>         But here
>         >                 we have 2 uarts and a FB?
>         >                 On Tue, Dec 24, 2019 at 8:18 PM Christian Mauderer
>         <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>         <mailto:list at c-mauderer.de>>> wrote:
>         >                     On 24/12/2019 12:06, Niteesh wrote:
>         >                     > The current raspi console section is
>         like this:
>         >                     > The bsp_console_select in
>         console_select.c is
>         >                     responsible for selecting
>         >                     > between uart and the framebuffer. It does so
>         >                     > by setting the Console_port_minor.
>         >                     > The console_config is responsible for
>         output_char
>         >                     function.
>         >                     > And other files are driver code.
>         >                     > If rewriting, this would be my approach,
>         >                     > Rewrite the bsp_console_select to set
>         some kind of
>         >                     a variable like in
>         >                     > IMX, then in console_initialize function
>         >                     > link the right driver to /dev/console.
>         >                     > Replace the console_tbl with the
>         device_context
>         >                     and console_fns with
>         >                     > termios_device_handlers and
>         >                     > finally add in the
>         console_initialization function.
>         >                     I agree that this would be a clean
>         solution. So if
>         >                     you want you can do
>         >                     that. But there might is a hurdle: As far as I
>         >                     understood you you only
>         >                     have a Pi3? So you might have a hard time
>         testing
>         >                     the changes. Maybe the
>         >                     simulator could work.
>         >                     Another possibility could be to set the
>         >                     "Console_port_minor" to
>         >                     something unused (for example -1). In that
>         case you
>         >                     can define another
>         >                     /dev/console.
>         >                     Best regards and merry Christmas (in case
>         you celebrate)
>         >                     Christian
>         >                     > On Tue, Dec 24, 2019 at 2:13 PM Niteesh
>         <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
>         <mailto:gsnb.gn at gmail.com>>>> wrote:
>         >                     >     Thank you so much, for such a
>         detailed answer.
>         >                     Now things make
>         >                     >     really good sense to me,
>         >                     >     going through the code now is just a
>         breeze.
>         >                     But I still have one
>         >                     >     question
>         >                     >     for the newer driver interface is
>         >                     console_initialize the function
>         >                     >     which RTEMS calls while initializing
>         >                     >     the console? Which means I can't
>         mess with the
>         >                     name right? It is
>         >                     >     similar to the main function, right?
>         >                     >     The current driver is a legacy one,
>         how do you
>         >                     want me to proceed,
>         >                     >     shall I rewrite the legacy to a
>         >                     >     the new one, this is will be a great
>         >                     learning experience for me also
>         >                     >     and we also get the BSP updated to
>         the latest
>         >                     interface.
>         >                     >     On Tue, Dec 24, 2019 at 3:20 AM
>         Christian Mauderer
>         >                     >     <list at c-mauderer.de
>         <mailto:list at c-mauderer.de>>>> wrote:
>         >                     >         Hello Niteesh,
>         >                     >         quite a lot of questions. I'll
>         try to
>         >                     answer them. Note that it
>         >                     >         has been
>         >                     >         some time since I had a detailed
>         look at
>         >                     that code so if something I
>         >                     >         tell seems odd please don't
>         hesitate to
>         >                     question it.
>         >                     >         Please note that in RTEMS their
>         are more
>         >                     or less two "levels" of
>         >                     >         support
>         >                     >         for a serial console:
>         >                     >         1. A very basic polled system
>         console
>         >                     (also known as
>         >                     >         "debug-console" in
>         >                     >         some BSPs). This one is used for
>         printk
>         >                     and should work in basically
>         >                     >         every case. It is used for
>         critical system
>         >                     messages like
>         >                     >         printing the
>         >                     >         exception frame. For that a BSP
>         has to
>         >                     provide a
>         >                     >         "BSP_output_char" function.
>         >                     >         2. A full featured UART driver
>         integrated
>         >                     into Termios. That one
>         >                     >         will be
>         >                     >         used for all normal I/O on the
>         UARTs.
>         >                     >         As far as I know the "console_tbl
>         >                     Console_Configuration_Ports"
>         >                     >         belongs
>         >                     >         to a table based legacy
>         interface. It is
>         >                     handled in the file
>          bsps/shared/dev/serial/legacy-console.c.
>         >                     I'm not sure whether it is
>         >                     >         documented in the BSP guide
>         because it
>         >                     shouldn't be used for new
>         >                     >         BSPs.
>         >                     >         Same is true for the "major" and
>         "minor"
>         >                     stuff: It's not really
>         >                     >         used for
>         >                     >         new drivers.
>         >                     >         Newer drivers use the
>         initialization that
>         >                     is described in the manual
>         >                     >         that you have already found.
>         Basically
>         >                     they use
>         >                     >         "rtems_termios_device_install"
>         to register
>         >                     a new UART as
>         >                     >         "/dev/ttySomething". Some recent
>         (ARM)
>         >                     BSPs that do that are the
>         >                     >         imx or
>         >                     >         the atsam.
>         >                     >         The console that is used for
>         stdin, stdout
>         >                     and stderr (printf,
>         >                     >         scanf,
>         >                     >         ...) is the one called
>         "/dev/console"
>         >                     (defined in
>         >                     >         CONSOLE_DEVICE_NAME).
>         >                     >         For the legacy table based
>         interface it's
>         >                     the one with the index of
>         >                     >         "Console_Port_Minor".
>         >                     >         If you want to access any UART
>         other than
>         >                     the one for stdin and
>         >                     >         stdout
>         >                     >         you do that the same way like on
>         Linux:
>         >                     Just use the "open"
>         >                     >         function on
>         >                     >         the "/dev/ttySomething" and use
>         "read",
>         >                     "write" and simmilar or use
>         >                     >         "fopen" together with "fread",
>         "fwrite",
>         >                     "fprintf", ...
>         >                     >         "printf" (and family) is a function
>         >                     belonging to the C library.
>         >                     >         In our
>         >                     >         case that's newlib. It will
>         format your
>         >                     message and after some other
>         >                     >         preprocessing will call the "write"
>         >                     function of the file that is
>         >                     >         opened
>         >                     >         as stdout (which is
>         "/dev/console" in the
>         >                     default case).
>         >                     >         I hope that I helped you with that
>         >                     explanation. Please feel free
>         >                     >         to ask
>         >                     >         anything if it isn't clear.
>         >                     >         Best regards
>         >                     >         Christian
>         >                     >         On 23/12/2019 19:50, Niteesh wrote:
>         >                     >         > And finally, how does printf
>         work? It is
>         >                     a macro? In that
>         >                     >         case, how does
>         >                     >         > any write to
>         >                     >         > a console work?
>         >                     >         > On Tue, Dec 24, 2019 at 12:18
>         AM Niteesh
>         >                     >         > <mailto:gsnb.gn at gmail.com
>         <mailto:gsnb.gn at gmail.com>> <mailto:gsnb.gn at gmail.com
>         <mailto:gsnb.gn at gmail.com>>>>> wrote:
>         >                     >         >     Is the correct port minor
>         number set
>         >                     during the
>         >                     >         initialization? What
>         >                     >         >     is the application want's to
>         >                     >         >     access some other port?
>         12:16 AM Niteesh
>         >                     >         <gsnb.gn at gmail.com
>         >                     >         >         I would like to clarify my
>         >                     doubts regarding the
>         >                     >         console driver.
>         >                     >         >         I went through the
>         documentation
>         >                     >         >         for the console
>            driver https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction.
>         >                     >         >         But it is quite
>         different from
>         >                     how some BSPs initialize.
>         >                     >         >         Correct me if I am wrong
>         >                     >         >         The console_tbl
>         contains the
>         >                     various entries of serial
>         >                     >         ports.
>         >                     >         >         The console_fns is a
>         struct of
>         >                     function pointers,
>         >                     >         which point to
>         >                     >         >         the BSP uart functions.
>         >                     >         >         The
>         >                     BSP_output_char_function_type is what will be
>         >                     >         called for
>         >                     >         >         printing a char on to
>         the console.
>         >                     >         >         How does RTEMS
>         initialize the
>         >                     uart? It's seems not to
>         >                     >         be same
>         >                     >         >         for all BSPs.
>         >                     >         >         The doc says that the
>         driver's
>         >                     >         is called
>         >                     >         >         once during the rtems
>         >                     initialization process.
>         >                     >         >         The console init function
>         >                     install the serial driver using
>          rtems_termios_device_install but
>         >                     there seems to be
>         >                     >         >         no such function in the
>         >                     raspberry pi? But there is a
>         >                     >         entry in
>         >                     >         >         console_fns for init
>         function,
>         >                     but then how does it
>         >                     >         >         gets called?
>         >                     >         >         And for BSP's with
>         multiple
>         >                     serial's, the output function
>         >                     >         >         chooses the right
>         serial using
>         >                     console_port_minor,
>         >                     >         >         Is it during
>         initialization?
>         >                     >         >         What is the need for
>         get and set
>         >                     register functions?
>         >                     >         >         On Mon, Dec 23, 2019
>         at 1:04 AM
>         >                     Christian Mauderer
>         >                     >         >         <list at c-mauderer.de
>         <mailto:list at c-mauderer.de>>>>> wrote:
>         >                     >         >             On 22/12/2019
>         19:45, Joel
>         >                     Sherrill wrote:
>         >                     >         >             > On Sun, Dec 22,
>         2019,
>         >                     12:29 PM Niteesh
>         <mailto:gsnb.gn at gmail.com>>>>>> wrote:
>         >                     >         >             >     On Sun, Dec
>         22, 2019
>         >                     at 8:44 PM Christian
>         >                     >         Mauderer
>          <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>         <mailto:list at c-mauderer.de>>>>>> wrote:
>         >                     >         >             >         Hello
>         Niteesh,
>         >                     >         >             >         thanks
>         for doing
>         >                     that work.
>         >                     >         >             >         On
>         22/12/2019
>         >                     12:10, Niteesh wrote:
>         >                     >         >             >         > The
>         rpi1 and
>         >                     rpi2 use the PL011 UART,
>         >                     >         whereas,
>         >                     >         >             with RPI's
>         >                     >         >             >         equipped
>         with
>         >                     wireless/Bluetooth module, the PL011 is
>         >                     >         >             connected to the
>         Bluetooth
>         module, and the
>         >                     mini UART is used as
>         >                     >         the primary
>         >                     >         >             UART.
>         >                     >         >             >         In my
>         opinion it
>         >                     would be great if you
>         >                     >         could use
>         >                     >         >             the FDT to
>         >                     >         >             >         distinguish
>         >                     >         >             >         between the
>         >                     boards. That should allow to add
>         >                     >         >             raspberry 3 (and
>         >                     >         >             >         maybe 4)
>         >                     >         >             >         support
>         without
>         >                     adding another BSP. More
>         >                     >         BSPs mean
>         >                     >         >             a bigger
>         >                     >         >             >         maintenance
>         >                     >         >             >         effort
>         for the
>         >                     RTEMS community.
>         >                     >         >             >     Learning
>         more about
>         >                     FDT is on my list for a long
>         >                     >         >             time.  I would love
>         >                     >         >             >     to work on that
>         >                     >         >             >     but I have
>         almost no
>         >                     exp with FDT's.
>         >                     >         >             >     But another
>         thing
>         >                     could also be done, in
>         >                      raspberrypi/start/bspstart.c we get the
>         >                     >         revision and
>         >                     >         >             >     model of the
>         board
>         >                     using the mailbox. Every
>         >                     >         board has
>         >                     >         >             a unique id,
>         >                     >         >             >     which we
>         could use to
>         >                     initialize
>         >                     >         >             >     the BSP. But
>         using FDT
>         >                     seems to be a more
>         >                     >         elegant
>         >                     >         >             option, it is a
>         >                     >         >             >     lot of work
>         I think,
>         >                     but we could take
>         >                     >         >             >     help from
>         libbsd and
>         >                     linux I suppose. What
>         >                     >         do you think?
>         >                     >         >             > I think there
>         are almost
>         >                     always two steps to a
>         >                     >         project
>         >                     >         >             like this: get it
>         >                     >         >             > to work and make
>         it nice. :)
>         >                     >         >             > If you fix the
>         startup
>         >                     code to read the board
>         >                     >         revision and
>         >                     >         >             memory size,
>         >                     >         >             > you can get a
>         working BSP
>         >                     that dynamically
>         >                     >         adapts to the
>         >                     >         >             models and
>         >                     >         >             > memory
>         variations with
>         >                     minimal modifications. If
>         >                     >         you want
>         >                     >         >             to then
>         >                     >         >             > convert the BSP
>         to FDT, it
>         >                     will be a LOT easier
>         >                     >         to debug
>         >                     >         >             with a working BSP.
>         >                     >         >             > Plus you may be
>         able to
>         >                     identify every variation
>         >                     >         point
>         >                     >         >             based on just the
>         >                     >         >             > model info. Then
>         FDT is
>         >                     just a matter of
>         >                     >         switching the
>         >                     >         >             source of
>         >                     >         >             > some/all of the
>         info.
>         >                     >         >             > That would be my
>         work plan
>         >                     anyway.
>         >                     >         >             I agree with Joel
>         that a
>         >                     secure development basis
>         >                     >         (also
>         >                     >         >             known as "hack")
>         >                     >         >             as a first step is
>         a good
>         >                     idea. You maybe even
>         >                     >         just make the
>         >                     >         >             mini UART
>         >                     >         >             the default driver
>         while you
>         >                     are developing. Then
>         >                     >         you can be
>         >                     >         >             sure that
>         >                     >         >             you have the right
>         driver.
>         >                     >         >             As soon as that
>         works you
>         >                     can either change to the
>         >                     >         revision
>         >                     >         >             method or
>         >                     >         >             (better) to the
>         FDT one and
>         >                     after that the patches
>         >                     >         can be
>         >                     >         >             merged. Using
>         >                     >         >             the FDT isn't that
>         >                     complicated. Basically you
>         >                     >         search for a
>         >                     >         >             node based on
>         >                     >         >             different
>         parameters. For an
>         >                     example you can take
>         >                     >         a look at
>         >                     >         >             the imx BSP.
>         >                     >         >             In imx_uart_probe
>          (bsps/arm/imx/console/console-config.c) a
>         >                     >         >             fdt node is
>         >                     >         >             searched and based
>         on that a
>         >                     UART driver is used.
>         >                     >         But again:
>         >                     >         >             Follow
>         >                     >         >             Joels suggestion
>         to start
>         >                     simple and secure.
>             https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>         >                     >         >             >         > But
>         from the
>         >                     above doc (PAGE 10), the
>         >                     >         mini uart
>         >                     >         >             has 16550 like
>         >                     >         >             >         registers
>         >                     >         >             >         > and RTEMS
>         >                     already has the driver for it
>         >                     bsps/shared/dev/serial/ns16550.c. But
>         >                     >         I am not
>         >                     >         >             sure how
>          compatible they
>         >                     >         >             >         > are?
>         Should a
>         >                     new driver be
>         >                     >         implemented from
>         >                     >         >             scratch or use
>         >                     >         >             >         ns16550 if
>         >                     >         >             >         > possible?
>         >                     >         >             >         In
>         general it's
>         >                     better to re-use
>         >                     >         existing code.
>         >                     >         >             That has multiple
>         >                     >         >             >         advantages:
>         >                     >         >             >         - It
>         reduces the
>         >                     maintenance effort.
>         >                     >         Fewer code
>         >                     >         >             means fewer work.
>         >                     >         >             >         - If you
>         have
>         >                     multiple driver for the
>         >                     >         same or
>         >                     >         >             similar hardware
>         >                     >         >             >         it can
>         >                     >         >             >         happen
>         that a bug
>         >                     is fixed in one but
>         >                     >         not the other.
>         >                     >         >             >         - It's
>         simpler to
>         >                     find a hardware to
>         >                     >         test changes.
>         >                     >         >             >         - The driver
>         >                     becomes more universal with
>         >                     >         every new
>         >                     >         >             supported
>         >                     >         >             >         hardware.
>         >                     >         >             >         That
>         increases the
>         >                     chance that it fits
>         >                     >         the next
>         >                     >         >             new hardware.
>         >                     >         >             >         I'm sure
>         there are
>         >                     some more if you ask
>         >                     >         someone else.
>         >                     >         >             >     I do
>         understand the
>         >                     issues, I just spent
>         >                     >         some time
>         >                     >         >             reading the
>         >                     >         >             >     driver code.
>         >                     >         >             >     I think we
>         could most
>         >                     probably use it. I
>         >                     >         will take a
>         >                     >         >             closer look and
>         >                     >         >             >     will update.
>         >                     >         >             Great.
>         >                     >         >             >         > Also,
>         the core
>         >                     clock on which the
>         >                     >         PL011 is based
>         >                     >         >             on is changed
>         >                     >         >             >         in rpi3.
>         >                     >         >             >         > Rpi1
>         and 2 use
>         >                     250Mhz as the default
>         >                     >         clock but
>         >                     >         >             it was changed
>         >                     >         >             >         to 400Mhz
>         >                     >         >             >         > in
>         Rpi3 and newer
>         >                     >         >             >         Again:
>         Would be
>         >                     great if that could be
>         >                     >         adapted
>         >                     >         >             based on FDT or by
>         >                     >         >             >         reading
>         the right
>         >                     registers.
>         >                     >         >             >         > Few
>         differences
>         >                     between PL011 and Mini
>         >                     >         uart
>         >                     >         >             >         > The
>         mini UART
>         >                     has smaller FIFOs.
>         >                     >         Combined with
>         >                     >         >             the lack of
>         >                     >         >             >         flow
>         control,
>         >                     >         >             >         > this
>         makes it
>         >                     more prone to losing
>         >                     >         characters at
>         >                     >         >             higher baud
>         >                     >         >             >         rates. It
>         >                     >         >             >         > is also
>         >                     generally less capable than
>         >                     >         the PL011,
>         >                     >         >             mainly due to
>         >                     >         >             >         its baud
>         >                     >         >             >         > rate
>         link to the
>         >                     VPU clock speed.
>         >                     >         >             >         That
>         shouldn't
>         >                     really be a problem for
>         >                     >         the system
>         >                     >         >             console.
>         >                     >         >             >         > The
>         particular
>         >                     deficiencies of the
>         >                     >         mini UART
>         >                     >         >             compared to the
>         >                     >         >             >         PL011 are :
>         >                     >         >             >         > No
>         break detection
>         >                     >         >             >         > No framing
>         >                     errors detection
>         >                     >         >             >         > No
>         parity bit
>         >                     >         >             >         > No receive
>         >                     timeout interrupt
>         >                     >         >             >         > No
>         DCD, DSR, DTR
>         >                     or RI signals
>           _______________________________________________
>         >                     >         >             >     devel
>         mailing list
>          devel at rtems.org <mailto:devel at rtems.org>
>         <mailto:devel at rtems.org>> <mailto:devel at rtems.org
>         <mailto:devel at rtems.org>>>
>         <mailto:devel at rtems.org>>>>
>          <mailto:devel at rtems.org <mailto:devel at rtems.org>
>         <mailto:devel at rtems.org>>>>>
>         >                      http://lists.rtems.org/mailman/listinfo/devel
