Raspberrypi3: Mini UART driver
Christian Mauderer list at c-mauderer.de
Fri Dec 27 09:30:22 UTC 2019
On 27/12/2019 09:30, Niteesh wrote:
> On Fri, Dec 27, 2019 at 1:59 AM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     On 25/12/2019 15:32, Niteesh wrote:
>     > What about the framebuffer it still uses minor and major's?
>     I'm not entirely sure but I don't think that it is a problem to mix
>     legacy and new style drivers.
> I want to create rtems_termios_device_handler for the framebuffer, the
> current driver uses console_fns and
> the functions have the old signatures, which uses major and minor
> numbers, but the device handler uses the newer interface
> staticboolmy_driver_first_open(
>   rtems_termios_tty             *tty,
>   rtems_termios_device_context  *base,
>   struct termios                *term,
>   rtems_libio_open_close_args_t *args
> as mentioned in the doc will it cause any trouble?
I wouldn't expect trouble.
> If it does then will
> also have to rewrite the fb right?
You should only have to touch the bsps/arm/raspberrypi/console/fbcons.c
file which is a very simple one. I don't expect that you have to touch
any other file.
>     > On Wed, Dec 25, 2019 at 3:20 PM Niteesh <gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>
>     > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>> wrote:
>     >     Just to make sure I am going in the right track.
>     >     I moved the uart register definitions to bsp/usart.h into a struct
>     >     of uint32_t called usart0_regs
>     >     here is git diff of usart.c after changing it to the latest
>     console
>     >     interface.
>     >     diff --git a/bsps/arm/raspberrypi/console/usart.c
>     >     b/bsps/arm/raspberrypi/console/usart.c
>     >     index 25fb523621..b12f375a1c 100644
>     >     --- a/bsps/arm/raspberrypi/console/usart.c
>     >     +++ b/bsps/arm/raspberrypi/console/usart.c
>     >     @@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const
>     console_tbl *ct)
>     >      #endif
>     >     +typedef struct {
>     >     +  rtems_termios_device_context base;
>     >     +  const char *device_name;
>     >     +  volatile usart0_regs *regs;
>     >     +}uart0_context;
>     >      static void usart_set_baud(int minor, int baud)
>     >     @@ -55,10 +61,17 @@ static void usart_set_baud(int minor, int
>     baud)
>     >       return;
>     >     -static void usart_initialize(int minor)
>     >     +static volatile usart0_regs
>     >     *rpi_uart_get_regs(rtems_termios_device_context *base)
>     >     -  unsigned int gpio_reg;
>     >     +  uart0_context *ctx;
>     >     +  ctx = (usart0_regs *) base;
>     >     +  return ctx->regs;
>     >     +static void usart_initialize(rtems_termios_device_context *base)
>     >     +  unsigned int gpio_reg;
>     >        ** Program GPIO pins for UART 0
>     >     @@ -75,67 +88,81 @@ static void usart_initialize(int minor)
>     >        usart_delay(150);
>     >        BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>     >     +  volatile uint32_t *uart_regs = rpi_uart_get_regs(base);
>     >        ** Init the PL011 UART
>     >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>     >     -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>     >     -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>     >     -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>     >     -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>     >     -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>     >     -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>     >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>     >     -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>     >     -  usart_set_baud(minor, 115000);
>     >     +  uart_regs->cr  = 0;
>     >     +  uart_regs->icr = 0x7ff;
>     >     +  uart_regs->imsc = 0;
>     >     +  uart_regs->ibrd = 1;
>     >     +  uart_regs->fbrd= 40;
>     >     +  uart_regs->lcrh= 0x70;
>     >     +  uart_regs->rsrecr= 0;
>     >     +  uart_regs->cr = 0x301;
>     >     +  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
>     >     +  // usart_set_baud(minor, 115000);
>     >     -static int usart_first_open(int major, int minor, void *arg)
>     >     +static bool usart_first_open(
>     >     +  rtems_termios_tty *tty,
>     >     +  rtems_termios_device_context *base,
>     >     +  struct termios *term,
>     >     +  rtems_libio_open_close_args_t *args
>     >     -  rtems_libio_open_close_args_t *oc =
>     >     (rtems_libio_open_close_args_t *) arg;
>     >     -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>     >     oc->iop->data1;
>     >     -  const console_tbl *ct = Console_Port_Tbl [minor];
>     >     -  console_data *cd = &Console_Port_Data [minor];
>     >     +  rtems_status_code sc;
>     >     +  bool ok;
>     >     -  cd->termios_data = tty;
>     >     -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>     >     +  ctx = (uart0_context *) base;
>     >     -  return 0;
>     >     +  usart_initialize(base);
>     >     +  sc = rtems_termios_set_initial_baud(tty,  USART0_DEFAULT_BAUD);
>     >     +  if ( sc != RTEMS_SUCCESSFUL ){
>     >     +    printk("Error setting the baud for termios\n");
>     >     +    return false;
>     >     -static int usart_last_close(int major, int minor, void *arg)
>     >     +static int usart_last_close(
>     >     +  rtems_termios_open_close_args_t *arg)
>     >        return 0;
>     >     -static int usart_read_polled(int minor)
>     >     +static int usart_read_polled(rtems_termios_device_context *base)
>     >     -  if (minor == 0) {
>     >     -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>     >     == 0) {
>     >     -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>     >     -    } else {
>     >     -      return -1;
>     >     -  } else {
>     >     -    printk("Unknown console minor number: %d\n", minor);
>     >     -    return -1;
>     >     +  regs = rpi_uart_get_regs(base);
>     >     +  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
>     >     +    return (regs->dr & 0xFF);
>     >     +  return -1;
>     >     -static void usart_write_polled(int minor, char c)
>     >     +static void usart_write_polled(rtems_termios_device_context
>     *base,
>     >     char c)
>     >     -   while (1) {
>     >     -     if ((BCM2835_REG(BCM2835_UART0_FR) &
>     BCM2835_UART0_FR_TXFF) == 0)
>     >     -       break;
>     >     -   BCM2835_REG(BCM2835_UART0_DR) = c;
>     >     +  while (1) {
>     >     +    if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
>     >     +      break;
>     >     +  regs->dr = c;
>     >      static ssize_t usart_write_support_polled(
>     >     -  int minor,
>     >        const char *s,
>     >        size_t n
>     >     @@ -143,7 +170,7 @@ static ssize_t usart_write_support_polled(
>     >        ssize_t i = 0;
>     >        for (i = 0; i < n; ++i) {
>     >     -    usart_write_polled(minor, s [i]);
>     >     +    usart_write_polled(base, s[i]);
>     >        return n;
>     >     @@ -154,14 +181,11 @@ static int usart_set_attributes(int minor,
>     >     const struct termios *term)
>     >        return -1;
>     >     -const console_fns bcm2835_usart_fns = {
>     >     -  .deviceProbe = libchip_serial_default_probe,
>     >     -  .deviceFirstOpen = usart_first_open,
>     >     -  .deviceLastClose = usart_last_close,
>     >     -  .deviceRead = usart_read_polled,
>     >     -  .deviceWrite = usart_write_support_polled,
>     >     -  .deviceInitialize = usart_initialize,
>     >     -  .deviceWritePolled = usart_write_polled,
>     >     -  .deviceSetAttributes = usart_set_attributes,
>     >     -  .deviceOutputUsesInterrupts = false
>     >     +const rtems_termios_device_handler
>     bcm2835_uart0_handler_polled = {
>     >     +  .first_open = usart_first_open,
>     >     +  .last_close = usart_last_close,
>     >     +  .poll_read = usart_read_polled,
>     >     +  .set_attributes = usart_set_attributes,
>     >     +  .write = usart_write_support_polled,
>     >     +  .mode = TERMIOS_POLLED
>     >     \ No newline at end of file
>     >     On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill <joel at rtems.org
>     <mailto:joel at rtems.org>
>     >     <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>     >         On Tue, Dec 24, 2019, 12:19 PM Niteesh <gsnb.gn at gmail.com
>     >             And also the register definitions are in raspberrpi.h file
>     >             should I move them to usart.h.
>     >         Sounds right if you mean bsp/usart.h
>     >             I have a doubt we have a register field in device_context
>     >             typedef struct {
>     >                 volatile some_chip_registers *regs;
>     >             } my_driver_context;
>     >             How does the reg field point to the correct
>     memory location?
>     >             for instance in IMX BSP,
>     >             there is a struct with register field's but none of the
>     >             define a memory location?
>     >         Make sure the structure has volatiles and proper alignment. :)
>     >             On Tue, Dec 24, 2019 at 11:37 PM Niteesh
>     <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>     wrote:
>     >                 How to handle different serial devices? In other BSPs
>     >                 the uart devices are the same, so
>     >                 they were able to put it under a single array? But
>     here
>     >                 we have 2 uarts and a FB?
>     >                 On Tue, Dec 24, 2019 at 8:18 PM Christian Mauderer
>     >                 <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >                     On 24/12/2019 12:06, Niteesh wrote:
>     >                     > The current raspi console section is like this:
>     >                     > The bsp_console_select in console_select.c is
>     >                     responsible for selecting
>     >                     > between uart and the framebuffer. It does so
>     >                     > by setting the Console_port_minor.
>     >                     > The console_config is responsible for
>     output_char
>     >                     function.
>     >                     > And other files are driver code.
>     >                     > If rewriting, this would be my approach,
>     >                     > Rewrite the bsp_console_select to set some
>     kind of
>     >                     a variable like in
>     >                     > IMX, then in console_initialize function
>     >                     > link the right driver to /dev/console.
>     >                     > Replace the console_tbl with the device_context
>     >                     and console_fns with
>     >                     > termios_device_handlers and
>     >                     > finally add in the console_initialization
>     function.
>     >                     I agree that this would be a clean solution. So if
>     >                     you want you can do
>     >                     that. But there might is a hurdle: As far as I
>     >                     understood you you only
>     >                     have a Pi3? So you might have a hard time testing
>     >                     the changes. Maybe the
>     >                     simulator could work.
>     >                     Another possibility could be to set the
>     >                     "Console_port_minor" to
>     >                     something unused (for example -1). In that
>     case you
>     >                     can define another
>     >                     /dev/console.
>     >                     Best regards and merry Christmas (in case you
>     celebrate)
>     >                     Christian
>     >                     > On Tue, Dec 24, 2019 at 2:13 PM Niteesh
>     >                     > <mailto:gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>>>> wrote:
>     >                     >     Thank you so much, for such a detailed
>     answer.
>     >                     Now things make
>     >                     >     really good sense to me,
>     >                     >     going through the code now is just a breeze.
>     >                     But I still have one
>     >                     >     question
>     >                     >     for the newer driver interface is
>     >                     console_initialize the function
>     >                     >     which RTEMS calls while initializing
>     >                     >     the console? Which means I can't mess
>     with the
>     >                     name right? It is
>     >                     >     similar to the main function, right?
>     >                     >     The current driver is a legacy one, how
>     do you
>     >                     want me to proceed,
>     >                     >     shall I rewrite the legacy to a
>     >                     >     the new one, this is will be a great
>     >                     learning experience for me also
>     >                     >     and we also get the BSP updated to the
>     latest
>     >                     interface.
>     >                     >     On Tue, Dec 24, 2019 at 3:20 AM
>     Christian Mauderer
>     >                     >     <list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>> wrote:
>     >                     >         Hello Niteesh,
>     >                     >         quite a lot of questions. I'll try to
>     >                     answer them. Note that it
>     >                     >         has been
>     >                     >         some time since I had a detailed look at
>     >                     that code so if something I
>     >                     >         tell seems odd please don't hesitate to
>     >                     question it.
>     >                     >         Please note that in RTEMS their are more
>     >                     or less two "levels" of
>     >                     >         support
>     >                     >         for a serial console:
>     >                     >         1. A very basic polled system console
>     >                     (also known as
>     >                     >         "debug-console" in
>     >                     >         some BSPs). This one is used for printk
>     >                     and should work in basically
>     >                     >         every case. It is used for critical
>     system
>     >                     messages like
>     >                     >         printing the
>     >                     >         exception frame. For that a BSP has to
>     >                     provide a
>     >                     >         "BSP_output_char" function.
>     >                     >         2. A full featured UART driver
>     integrated
>     >                     into Termios. That one
>     >                     >         will be
>     >                     >         used for all normal I/O on the UARTs.
>     >                     >         As far as I know the "console_tbl
>     >                     Console_Configuration_Ports"
>     >                     >         belongs
>     >                     >         to a table based legacy interface. It is
>     >                     handled in the file
>     >                     >         bsps/shared/dev/serial/legacy-console.c.
>     >                     I'm not sure whether it is
>     >                     >         documented in the BSP guide because it
>     >                     shouldn't be used for new
>     >                     >         BSPs.
>     >                     >         Same is true for the "major" and "minor"
>     >                     stuff: It's not really
>     >                     >         used for
>     >                     >         new drivers.
>     >                     >         Newer drivers use the initialization
>     that
>     >                     is described in the manual
>     >                     >         that you have already found. Basically
>     >                     they use
>     >                     >         "rtems_termios_device_install" to
>     register
>     >                     a new UART as
>     >                     >         "/dev/ttySomething". Some recent (ARM)
>     >                     BSPs that do that are the
>     >                     >         imx or
>     >                     >         the atsam.
>     >                     >         The console that is used for stdin,
>     stdout
>     >                     and stderr (printf,
>     >                     >         scanf,
>     >                     >         ...) is the one called "/dev/console"
>     >                     (defined in
>     >                     >         CONSOLE_DEVICE_NAME).
>     >                     >         For the legacy table based interface
>     it's
>     >                     the one with the index of
>     >                     >         "Console_Port_Minor".
>     >                     >         If you want to access any UART other
>     than
>     >                     the one for stdin and
>     >                     >         stdout
>     >                     >         you do that the same way like on Linux:
>     >                     Just use the "open"
>     >                     >         function on
>     >                     >         the "/dev/ttySomething" and use "read",
>     >                     "write" and simmilar or use
>     >                     >         "fopen" together with "fread", "fwrite",
>     >                     "fprintf", ...
>     >                     >         "printf" (and family) is a function
>     >                     belonging to the C library.
>     >                     >         In our
>     >                     >         case that's newlib. It will format your
>     >                     message and after some other
>     >                     >         preprocessing will call the "write"
>     >                     function of the file that is
>     >                     >         opened
>     >                     >         as stdout (which is "/dev/console"
>     in the
>     >                     default case).
>     >                     >         I hope that I helped you with that
>     >                     explanation. Please feel free
>     >                     >         to ask
>     >                     >         anything if it isn't clear.
>     >                     >         Best regards
>     >                     >         Christian
>     >                     >         On 23/12/2019 19:50, Niteesh wrote:
>     >                     >         > And finally, how does printf work?
>     It is
>     >                     a macro? In that
>     >                     >         case, how does
>     >                     >         > any write to
>     >                     >         > a console work?
>     >                     >         > On Tue, Dec 24, 2019 at 12:18 AM
>     Niteesh
>     >                     >         > <mailto:gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>> <mailto:gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>>>>> wrote:
>     >                     >         >     Is the correct port minor
>     number set
>     >                     during the
>     >                     >         initialization? What
>     >                     >         >     is the application want's to
>     >                     >         >     access some other port?
>     >                     >         >     On Tue, Dec 24, 2019 at 12:16
>     AM Niteesh
>     >                     >         <gsnb.gn at gmail.com
>     >                     >         >         I would like to clarify my
>     >                     doubts regarding the
>     >                     >         console driver.
>     >                     >         >         I went through the
>     documentation
>     >                     >         >         for the console
>        driver https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction.
>     >                     >         >         But it is quite different from
>     >                     how some BSPs initialize.
>     >                     >         >         Correct me if I am wrong
>     >                     >         >         The console_tbl contains the
>     >                     various entries of serial
>     >                     >         ports.
>     >                     >         >         The console_fns is a struct of
>     >                     function pointers,
>     >                     >         which point to
>     >                     >         >         the BSP uart functions.
>     >                     >         >         The
>     >                     BSP_output_char_function_type is what will be
>     >                     >         called for
>     >                     >         >         printing a char on to the
>     console.
>     >                     >         >         How does RTEMS initialize the
>     >                     uart? It's seems not to
>     >                     >         be same
>     >                     >         >         for all BSPs.
>     >                     >         >         The doc says that the driver's
>     >                     initialization function
>     >                     >         is called
>     >                     >         >         once during the rtems
>     >                     initialization process.
>     >                     >         >         The console init function
>     >                     install the serial driver using
>      rtems_termios_device_install but
>     >                     there seems to be
>     >                     >         >         no such function in the
>     >                     raspberry pi? But there is a
>     >                     >         entry in
>     >                     >         >         console_fns for init function,
>     >                     but then how does it
>     >                     >         >         gets called?
>     >                     >         >         And for BSP's with multiple
>     >                     serial's, the output function
>     >                     >         >         chooses the right serial using
>     >                     console_port_minor,
>     >                     >         >         Is it during initialization?
>     >                     >         >         What is the need for get
>     and set
>     >                     register functions?
>     >                     >         >         On Mon, Dec 23, 2019 at
>     1:04 AM
>     >                     Christian Mauderer
>     >                     >         >         <list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>>> wrote:
>     >                     >         >             On 22/12/2019 19:45, Joel
>     >                     Sherrill wrote:
>     >                     >         >             > On Sun, Dec 22, 2019,
>     >                     12:29 PM Niteesh
>     <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
>     >                     at 8:44 PM Christian
>     >                     >         Mauderer
>     <mailto:list at c-mauderer.de>>>>>> wrote:
>     >                     >         >             >         Hello Niteesh,
>     >                     >         >             >         thanks for doing
>     >                     that work.
>     >                     >         >             >         On 22/12/2019
>     >                     12:10, Niteesh wrote:
>     >                     >         >             >         > The rpi1 and
>     >                     rpi2 use the PL011 UART,
>     >                     >         whereas,
>     >                     >         >             with RPI's
>     >                     >         >             >         equipped with
>     >                     wireless/Bluetooth module, the PL011 is
>     >                     >         >             connected to the Bluetooth
>     >                     >         >             >         > module,
>     and the
>     >                     mini UART is used as
>     >                     >         the primary
>     >                     >         >             UART.
>     >                     >         >             >         In my opinion it
>     >                     would be great if you
>     >                     >         could use
>     >                     >         >             the FDT to
>     >                     >         >             >         distinguish
>     >                     >         >             >         between the
>     >                     boards. That should allow to add
>     >                     >         >             raspberry 3 (and
>     >                     >         >             >         maybe 4)
>     >                     >         >             >         support without
>     >                     adding another BSP. More
>     >                     >         BSPs mean
>     >                     >         >             a bigger
>     >                     >         >             >         maintenance
>     >                     >         >             >         effort for the
>     >                     RTEMS community.
>     >                     >         >             >     Learning more about
>     >                     FDT is on my list for a long
>     >                     >         >             time.  I would love
>     >                     >         >             >     to work on that
>     >                     >         >             >     but I have almost no
>     >                     exp with FDT's.
>     >                     >         >             >     But another thing
>     >                     could also be done, in
>     >                      raspberrypi/start/bspstart.c we get the
>     >                     >         revision and
>     >                     >         >             >     model of the board
>     >                     using the mailbox. Every
>     >                     >         board has
>     >                     >         >             a unique id,
>     >                     >         >             >     which we could
>     use to
>     >                     initialize
>     >                     >         >             >     the BSP. But
>     using FDT
>     >                     seems to be a more
>     >                     >         elegant
>     >                     >         >             option, it is a
>     >                     >         >             >     lot of work I think,
>     >                     but we could take
>     >                     >         >             >     help from libbsd and
>     >                     linux I suppose. What
>     >                     >         do you think?
>     >                     >         >             > I think there are almost
>     >                     always two steps to a
>     >                     >         project
>     >                     >         >             like this: get it
>     >                     >         >             > to work and make it
>     nice. :)
>     >                     >         >             > If you fix the startup
>     >                     code to read the board
>     >                     >         revision and
>     >                     >         >             memory size,
>     >                     >         >             > you can get a
>     working BSP
>     >                     that dynamically
>     >                     >         adapts to the
>     >                     >         >             models and
>     >                     >         >             > memory variations with
>     >                     minimal modifications. If
>     >                     >         you want
>     >                     >         >             to then
>     >                     >         >             > convert the BSP to
>     FDT, it
>     >                     will be a LOT easier
>     >                     >         to debug
>     >                     >         >             with a working BSP.
>     >                     >         >             > Plus you may be able to
>     >                     identify every variation
>     >                     >         point
>     >                     >         >             based on just the
>     >                     >         >             > model info. Then FDT is
>     >                     just a matter of
>     >                     >         switching the
>     >                     >         >             source of
>     >                     >         >             > some/all of the info.
>     >                     >         >             > That would be my
>     work plan
>     >                     anyway.
>     >                     >         >             I agree with Joel that a
>     >                     secure development basis
>     >                     >         (also
>     >                     >         >             known as "hack")
>     >                     >         >             as a first step is a good
>     >                     idea. You maybe even
>     >                     >         just make the
>     >                     >         >             mini UART
>     >                     >         >             the default driver
>     while you
>     >                     are developing. Then
>     >                     >         you can be
>     >                     >         >             sure that
>     >                     >         >             you have the right driver.
>     >                     >         >             As soon as that works you
>     >                     can either change to the
>     >                     >         revision
>     >                     >         >             method or
>     >                     >         >             (better) to the FDT
>     one and
>     >                     after that the patches
>     >                     >         can be
>     >                     >         >             merged. Using
>     >                     >         >             the FDT isn't that
>     >                     complicated. Basically you
>     >                     >         search for a
>     >                     >         >             node based on
>     >                     >         >             different parameters.
>     For an
>     >                     example you can take
>     >                     >         a look at
>     >                     >         >             the imx BSP.
>     >                     >         >             In imx_uart_probe
>      (bsps/arm/imx/console/console-config.c) a
>     >                     >         >             fdt node is
>     >                     >         >             searched and based on
>     that a
>     >                     UART driver is used.
>     >                     >         But again:
>     >                     >         >             Follow
>     >                     >         >             Joels suggestion to start
>     >                     simple and secure.
>         https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>     >                     >         >             >         > But from the
>     >                     above doc (PAGE 10), the
>     >                     >         mini uart
>     >                     >         >             has 16550 like
>     >                     >         >             >         registers
>     >                     >         >             >         > and RTEMS
>     >                     already has the driver for it
>     >                     bsps/shared/dev/serial/ns16550.c. But
>     >                     >         I am not
>     >                     >         >             sure how
>     >                     >         >             >         compatible they
>     >                     >         >             >         > are? Should a
>     >                     new driver be
>     >                     >         implemented from
>     >                     >         >             scratch or use
>     >                     >         >             >         ns16550 if
>     >                     >         >             >         > possible?
>     >                     >         >             >         In general it's
>     >                     better to re-use
>     >                     >         existing code.
>     >                     >         >             That has multiple
>     >                     >         >             >         advantages:
>     >                     >         >             >         - It reduces the
>     >                     maintenance effort.
>     >                     >         Fewer code
>     >                     >         >             means fewer work.
>     >                     >         >             >         - If you have
>     >                     multiple driver for the
>     >                     >         same or
>     >                     >         >             similar hardware
>     >                     >         >             >         it can
>     >                     >         >             >         happen that
>     a bug
>     >                     is fixed in one but
>     >                     >         not the other.
>     >                     >         >             >         - It's
>     simpler to
>     >                     find a hardware to
>     >                     >         test changes.
>     >                     >         >             >         - The driver
>     >                     becomes more universal with
>     >                     >         every new
>     >                     >         >             supported
>     >                     >         >             >         hardware.
>     >                     >         >             >         That
>     increases the
>     >                     chance that it fits
>     >                     >         the next
>     >                     >         >             new hardware.
>     >                     >         >             >         I'm sure
>     there are
>     >                     some more if you ask
>     >                     >         someone else.
>     >                     >         >             >     I do understand the
>     >                     issues, I just spent
>     >                     >         some time
>     >                     >         >             reading the
>     >                     >         >             >     driver code.
>     >                     >         >             >     I think we could
>     most
>     >                     probably use it. I
>     >                     >         will take a
>     >                     >         >             closer look and
>     >                     >         >             >     will update.
>     >                     >         >             Great.
>     >                     >         >             >         > Also, the core
>     >                     clock on which the
>     >                     >         PL011 is based
>     >                     >         >             on is changed
>     >                     >         >             >         in rpi3.
>     >                     >         >             >         > Rpi1 and 2 use
>     >                     250Mhz as the default
>     >                     >         clock but
>     >                     >         >             it was changed
>     >                     >         >             >         to 400Mhz
>     >                     >         >             >         > in Rpi3
>     and newer
>     >                     >         >             >         Again: Would be
>     >                     great if that could be
>     >                     >         adapted
>     >                     >         >             based on FDT or by
>     >                     >         >             >         reading the
>     right
>     >                     registers.
>     >                     >         >             >         > Few
>     differences
>     >                     between PL011 and Mini
>     >                     >         uart
>     >                     >         >             >         > The mini UART
>     >                     has smaller FIFOs.
>     >                     >         Combined with
>     >                     >         >             the lack of
>     >                     >         >             >         flow control,
>     >                     >         >             >         > this makes it
>     >                     more prone to losing
>     >                     >         characters at
>     >                     >         >             higher baud
>     >                     >         >             >         rates. It
>     >                     >         >             >         > is also
>     >                     generally less capable than
>     >                     >         the PL011,
>     >                     >         >             mainly due to
>     >                     >         >             >         its baud
>     >                     >         >             >         > rate link
>     to the
>     >                     VPU clock speed.
>     >                     >         >             >         That shouldn't
>     >                     really be a problem for
>     >                     >         the system
>     >                     >         >             console.
>     >                     >         >             >         > The particular
>     >                     deficiencies of the
>     >                     >         mini UART
>     >                     >         >             compared to the
>     >                     >         >             >         PL011 are :
>     >                     >         >             >         > No break
>     detection
>     >                     >         >             >         > No framing
>     >                     errors detection
>     >                     >         >             >         > No parity bit
>     >                     >         >             >         > No receive
>     >                     timeout interrupt
>     >                     >         >             >         > No DCD,
>     DSR, DTR
>     >                     or RI signals
>     >                      _______________________________________________
>     >                     >         >             >     devel mailing list
>     >                     >         >             >     devel at rtems.org
>     <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org>> <mailto:devel at rtems.org
>     >                     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>     <mailto:devel at rtems.org>>>>
>     <mailto:devel at rtems.org>>>>>
>     >                      http://lists.rtems.org/mailman/listinfo/devel
