Raspberrypi3: Mini UART driver
Christian Mauderer list at c-mauderer.de
Fri Dec 27 10:08:49 UTC 2019
On 27/12/2019 11:03, Niteesh wrote:
> I tried building it. I basically ran make in previously create rpi2 BSP
> folder.
> I did get some compile-time error, but I have fixed them. Now I get
> an*undefined reference to `arm_pl011_write_polled'*
> How to include the arm_pl011.c file?
You have to add the file here:
c/src/lib/libbsp/arm/raspberrypi/Makefile.am
Note that you will have to execute a bootstrap again as soon as you
change anything there.
These files still follow an old folder structure. But they will be
replaced soon by Sebastians work on the new build system.
> On Fri, Dec 27, 2019 at 3:15 PM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
>     The changes I have made so far
>     diff --git a/bsps/arm/raspberrypi/console/console-config.c
>     b/bsps/arm/raspberrypi/console/console-config.c
>     index d2186c918b..d982b2c9c2 100644
>     --- a/bsps/arm/raspberrypi/console/console-config.c
>     +++ b/bsps/arm/raspberrypi/console/console-config.c
>     @@ -22,45 +22,53 @@
>      #include <libchip/serial.h>
>     -#include <bspopts.h>
>      #include <bsp/irq.h>
>      #include <bsp/usart.h>
>      #include <bsp/raspberrypi.h>
>     +#include <bsp/arm-pl011.h>
>      #include <bsp/fbcons.h>
>     -console_tbl Console_Configuration_Ports [] = {
>     -      .sDeviceName = "/dev/ttyS0",
>     -      .deviceType = SERIAL_CUSTOM,
>     -      .pDeviceFns = &bcm2835_usart_fns,
>     -      .deviceProbe = NULL,
>     -      .pDeviceFlow = NULL,
>     -      .ulCtrlPort1 = BCM2835_UART0_BASE,
>     -      .ulCtrlPort2 = 0,
>     -      .ulClock = USART0_DEFAULT_BAUD,
>     -      .ulIntVector = BCM2835_IRQ_ID_UART
>     -      .sDeviceName ="/dev/fbcons",
>     -      .pDeviceFns = &fbcons_fns,
>     -      .deviceProbe = fbcons_probe,
>     +#include <bspopts.h>
>     +arm_pl011_context pl011_context = {
>     +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>     +  .regs = (volatile pl011 *) BCM2835_PL011_BASE,
>     +  .initial_baud = PL011_DEFAULT_BAUD
>     -#define PORT_COUNT \
>     -  (sizeof(Console_Configuration_Ports) \
>     -    / sizeof(Console_Configuration_Ports [0]))
>     +rpi_fb_context fb_context = {
>     +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
>     -unsigned long Console_Configuration_Count = PORT_COUNT;
>     +const console_device console_device_table[] = {
>     +    .device_file = "/dev/ttyS0",
>     +    .probe = console_device_probe_default,
>     +    .handler = &arm_pl011_fns,
>     +    .context = &pl011_context.base
>     +    .device_file = "/dev/fb0",
>     +    // Should be changed to fbcons_probe (but it still use old
>     interface)
>     +    .probe = fbcons_probe,
>     +    .handler = &fbcons_fns,
>     +    .context = &fb_context.base
>     +const size_t console_device_count =
>     RTEMS_ARRAY_SIZE(console_device_table);
>      static void output_char(char c)
>     -  const console_fns *con =
>     -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>     -  con->deviceWritePolled((int) Console_Port_Minor, c);
>     +  switch(SERIAL){
>     +    case FB:
>     +      fbcons_write_polled(&fb_context.base, c);
>     +      break;
>     +    case PL011:
>     +      arm_pl011_write_polled(&pl011_context.base, c);
>     +      break;
>      BSP_output_char_function_type BSP_output_char = output_char;
>     diff --git a/bsps/arm/raspberrypi/console/console_select.c
>     b/bsps/arm/raspberrypi/console/console_select.c
>     index bd246ca868..dbca5c324f 100644
>     --- a/bsps/arm/raspberrypi/console/console_select.c
>     +++ b/bsps/arm/raspberrypi/console/console_select.c
>     @@ -15,7 +15,7 @@
>       *  http://www.rtems.org/license/LICENSE
>     +#include <bsp/raspberrypi.h>
>      #include <bsp.h>
>      #include <bsp/fatal.h>
>      #include <rtems/libio.h>
>     @@ -30,53 +30,7 @@
>      #include <bsp/rpi-fb.h>
>      rtems_device_minor_number BSPPrintkPort = 0;
>     - * Method to return true if the device associated with the
>     - * minor number probs available.
>     -static bool bsp_Is_Available( rtems_device_minor_number minor )
>     -  console_tbl *cptr = Console_Port_Tbl[ minor ];
>     -   * First perform the configuration dependent probe, then the
>     -   * device dependent probe
>     -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
>     -       cptr->pDeviceFns->deviceProbe( minor ) ) {
>     -    return true;
>     -  return false;
>     - * Method to return the first available device.
>     -static rtems_device_minor_number bsp_First_Available_Device( void )
>     -  rtems_device_minor_number minor;
>     -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
>     -      return minor;
>     -   *  Error No devices were found.  We will want to bail here.
>     -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>     +CURRENT_SERIAL SERIAL = PL011;
>      void bsp_console_select( void )
>     @@ -90,25 +44,13 @@ void bsp_console_select( void )
>        const char *opt;
>     -  Console_Port_Minor = BSP_CONSOLE_UART0;
>     -  BSPPrintkPort = BSP_CONSOLE_UART0;
>        opt = rpi_cmdline_get_arg( "--console=" );
>        if ( opt ) {
>          if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
>            if ( rpi_video_is_initialized() > 0 ) {
>     -        Console_Port_Minor = BSP_CONSOLE_FB;
>     -        BSPPrintkPort = BSP_CONSOLE_FB;
>     +        SERIAL = FB;
>     -   * If the device that was selected isn't available then
>     -   * let the user know and select the first available device.
>     -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
>     -    Console_Port_Minor = bsp_First_Available_Device();
>     diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>     b/bsps/arm/raspberrypi/console/fbcons.c
>     index 3669ba458d..26a694ac9f 100644
>     --- a/bsps/arm/raspberrypi/console/fbcons.c
>     +++ b/bsps/arm/raspberrypi/console/fbcons.c
>     @@ -18,6 +18,7 @@
>      #include <rtems.h>
>     +#include <rtems/termiostypes.h>
>      #include <stdlib.h>
>     @@ -46,9 +47,10 @@ static void fbcons_init( int minor )
>       *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
>      static int fbcons_open(
>     -  int   major,
>     -  int   minor,
>     -  void *arg
>     +  struct rtems_termios_tty *tty,
>     +  rtems_termios_device_context *base,
>     +  struct termios *term,
>     +  rtems_libio_open_close_args_t *args
>        return RTEMS_SUCCESSFUL;
>     @@ -60,9 +62,9 @@ static int fbcons_open(
>       *  This function shuts down the requested port.
>      static int fbcons_close(
>     -  int   major,
>     -  int   minor,
>     -  void *arg
>        return ( RTEMS_SUCCESSFUL );
>     @@ -73,8 +75,8 @@ static int fbcons_close(
>       *  This routine polls out the requested character.
>     -static void fbcons_write_polled(
>     -  int  minor,
>     +void fbcons_write_polled(
>        char c
>     @@ -91,7 +93,7 @@ static void fbcons_write_polled(
>      static ssize_t fbcons_write_support_polled(
>     -  int         minor,
>        const char *buf,
>        size_t      len
>     @@ -102,7 +104,7 @@ static ssize_t fbcons_write_support_polled(
>         * poll each byte in the string out of the port.
>        while ( nwrite < len ) {
>     -    fbcons_write_polled( minor, *buf++ );
>     +    fbcons_write_polled( base, *buf++ );
>          nwrite++;
>     @@ -117,7 +119,9 @@ static ssize_t fbcons_write_support_polled(
>       *  Console Termios polling input entry point.
>     -static int fbcons_inbyte_nonblocking_polled( int minor )
>     +static int fbcons_inbyte_nonblocking_polled(
>        // if( rtems_kbpoll() ) {
>        //   int c = getch();
>     @@ -134,14 +138,16 @@ static int fbcons_inbyte_nonblocking_polled(
>     int minor )
>       *  port settings.
>      static int fbcons_set_attributes(
>     -  int                   minor,
>        const struct termios *t
>        return 0;
>     -bool fbcons_probe( int minor )
>     +bool fbcons_probe(
>        // rtems_status_code status;
>        static bool firstTime = true;
>     @@ -163,15 +169,11 @@ bool fbcons_probe( int minor )
>        return ret;
>     -const console_fns fbcons_fns =
>     +const rtems_termios_device_handler fbcons_fns =
>     -  .deviceProbe = libchip_serial_default_probe,     /* deviceProbe */
>     -  .deviceFirstOpen = fbcons_open,                 /* deviceFirstOpen */
>     -  .deviceLastClose = fbcons_close,                /* deviceLastClose */
>     -  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
>     -  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite */
>     -  .deviceInitialize = fbcons_init,                /*
>     deviceInitialize */
>     -  .deviceWritePolled = fbcons_write_polled,       /*
>     deviceWritePolled */
>     -  .deviceSetAttributes = fbcons_set_attributes,   /*
>     deviceSetAttributes */
>     -  .deviceOutputUsesInterrupts = FALSE,           /*
>     deviceOutputUsesInterrupts*/
>     +  .first_open = fbcons_open,
>     +  .last_close = fbcons_close,
>     +  .poll_read = fbcons_inbyte_nonblocking_polled,
>     +  .write = fbcons_write_support_polled,
>     +  .mode = TERMIOS_POLLED
>     \ No newline at end of file
>     diff --git a/bsps/arm/raspberrypi/console/usart.c
>     b/bsps/arm/raspberrypi/console/usart.c
>     index 25fb523621..471d0c553f 100644
>     --- a/bsps/arm/raspberrypi/console/usart.c
>     +++ b/bsps/arm/raspberrypi/console/usart.c
>     @@ -23,145 +23,3 @@
>      #include <rtems/bspIo.h>
>     -static void usart_delay(uint32_t n)
>     - volatile uint32_t i = 0;
>     - for(i = 0; i < n; i++)
>     -#if 0
>     - *  These will be useful when the driver supports interrupt driven IO.
>     -static rtems_vector_number usart_get_irq_number(const console_tbl *ct)
>     -  return ct->ulIntVector;
>     -static uint32_t usart_get_baud(const console_tbl *ct)
>     -  return ct->ulClock;
>     -#endif
>     -static void usart_set_baud(int minor, int baud)
>     -  * Nothing for now
>     - return;
>     -static void usart_initialize(int minor)
>     -  unsigned int gpio_reg;
>     -  ** Program GPIO pins for UART 0
>     -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>     -  gpio_reg &= ~(7<<12);    /* gpio14 */
>     -  gpio_reg |=  (4<<12);    /* alt0   */
>     -  gpio_reg &= ~(7<<15);    /* gpio15 */
>     -  gpio_reg |=  (4<<15);    /* alt0   */
>     -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>     -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>     -  usart_delay(150);
>     -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>     -  usart_delay(150);
>     -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>     -  ** Init the PL011 UART
>     -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>     -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>     -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>     -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>     -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>     -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>     -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>     -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>     -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>     -  usart_set_baud(minor, 115000);
>     -static int usart_first_open(int major, int minor, void *arg)
>     -  rtems_libio_open_close_args_t *oc =
>     (rtems_libio_open_close_args_t *) arg;
>     -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>     oc->iop->data1;
>     -  const console_tbl *ct = Console_Port_Tbl [minor];
>     -  console_data *cd = &Console_Port_Data [minor];
>     -  cd->termios_data = tty;
>     -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>     -  return 0;
>     -static int usart_last_close(int major, int minor, void *arg)
>     -  return 0;
>     -static int usart_read_polled(int minor)
>     -  if (minor == 0) {
>     -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>     == 0) {
>     -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>     -    } else {
>     -      return -1;
>     -  } else {
>     -    printk("Unknown console minor number: %d\n", minor);
>     -    return -1;
>     -static void usart_write_polled(int minor, char c)
>     -   while (1) {
>     -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
>     -       break;
>     -   BCM2835_REG(BCM2835_UART0_DR) = c;
>     -static ssize_t usart_write_support_polled(
>     -  int minor,
>     -  const char *s,
>     -  size_t n
>     -  ssize_t i = 0;
>     -  for (i = 0; i < n; ++i) {
>     -    usart_write_polled(minor, s [i]);
>     -  return n;
>     -static int usart_set_attributes(int minor, const struct termios *term)
>     -  return -1;
>     -const console_fns bcm2835_usart_fns = {
>     -  .deviceFirstOpen = usart_first_open,
>     -  .deviceLastClose = usart_last_close,
>     -  .deviceRead = usart_read_polled,
>     -  .deviceWrite = usart_write_support_polled,
>     -  .deviceInitialize = usart_initialize,
>     -  .deviceWritePolled = usart_write_polled,
>     -  .deviceSetAttributes = usart_set_attributes,
>     -  .deviceOutputUsesInterrupts = false
>     diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     index d0e126699a..f2ff25dc63 100644
>     --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     @@ -33,12 +33,23 @@ extern "C" {
>      #define FB_CONSOLE 0x50492835
>     -bool fbcons_probe( int minor );
>     +bool fbcons_probe(
>     +  char c
>     +typedef struct {
>     +    rtems_termios_device_context base;
>     +} rpi_fb_context ;
>       * Driver function table
>     -extern const console_fns fbcons_fns;
>     +extern const rtems_termios_device_handler fbcons_fns;
>      #ifdef __cplusplus
>     diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     index 40c80cf408..4e5c84c741 100644
>     --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     @@ -60,6 +60,22 @@
>      #define RPI_PERIPHERAL_SIZE         0x01000000
>     + * @name Current Serial Device
>     +typedef enum {
>     +  PL011 = 0,
>     +  AUX_UART,
>     +  FB
>     +}CURRENT_SERIAL;
>     +extern CURRENT_SERIAL SERIAL;
>       * @name Internal ARM Timer Registers
>     @@ -184,42 +200,6 @@
>     - * @name UART 0 (PL011) Registers
>     -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
>     -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
>     -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
>     -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
>     -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
>     -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
>     -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
>     -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
>     -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
>     -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
>     -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
>     -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
>     -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
>     -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
>     -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
>     -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
>     -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
>     -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
>     -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
>     -#define BCM2835_UART0_MIS_RX    0x10
>     -#define BCM2835_UART0_MIS_TX    0x20
>     -#define BCM2835_UART0_IMSC_RX   0x10
>     -#define BCM2835_UART0_IMSC_TX   0x20
>     -#define BCM2835_UART0_FR_RXFE   0x10
>     -#define BCM2835_UART0_FR_TXFF   0x20
>     -#define BCM2835_UART0_ICR_RX    0x10
>     -#define BCM2835_UART0_ICR_TX    0x20
>     diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>     b/bsps/arm/raspberrypi/include/bsp/usart.h
>     index d3e710c5e9..abbf53626c 100644
>     --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>     +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>     @@ -32,9 +32,8 @@
>      extern "C" {
>      #endif /* __cplusplus */
>     -#define USART0_DEFAULT_BAUD 115000
>     -extern const console_fns bcm2835_usart_fns;
>     +#define PL011_DEFAULT_BAUD 115000
>     +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>      #ifdef __cplusplus
>     On Fri, Dec 27, 2019 at 3:12 PM Niteesh <gsnb.gn at gmail.com
>         On Fri, Dec 27, 2019 at 2:53 PM Christian Mauderer
>         <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>             Hello Niteesh,
>             let me repeat two important questions:
>             - How do you plan to test the changes? Simulator is OK for
>             me but
>             untested is not OK.
>         Since I don't have the older pi's, the simulator will be my only
>         option. And did you
>         take a look at the exception?
>             - Isn't it possible to just use the driver from
>             bsps/arm/shared/serial/arm-pl011.c and remove the BSP
>             specific completely?
>         Yes, I have done this. I usart.c file is now completely empty.
>         All we have to define was
>         the start address for the PL011 peripheral in usart.h.
>             On 27/12/2019 06:29, Niteesh wrote:
>             > On Fri, Dec 27, 2019 at 1:58 AM Christian Mauderer
>             > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>             wrote:
>             >     Hello Niteesh,
>             >     sorry for not answering earlier. During this time of
>             the year you have
>             >     to expect some delays on the mailing list due to
>             public holydays and
>             >     vacations.
>             > That's okay, I understand.
>             >     On 25/12/2019 10:50, Niteesh wrote:
>             >     > Just to make sure I am going in the right track.
>             >     > I moved the uart register definitions to bsp/usart.h
>             into a struct of
>             >     > uint32_t called usart0_regs
>             >     > here is git diff of usart.c after changing it to the
>             latest console
>             >     > interface.
>             >     Do you have a plan how you want to test these changes?
>             >     The direction looks OK. Some notes below.
>             >     By the way: Maybe it would be a better idea to just
>             remove it completely
>             >     and use the bsps/arm/shared/serial/arm-pl011.c driver
>             instead? That
>             >     reduces the ammount of code and therefore ammount of
>             bugs we have in
>             >     this BSP.
>             >     > diff --git a/bsps/arm/raspberrypi/console/usart.c
>             >     > b/bsps/arm/raspberrypi/console/usart.c
>             >     > index 25fb523621..b12f375a1c 100644
>             >     > --- a/bsps/arm/raspberrypi/console/usart.c
>             >     > +++ b/bsps/arm/raspberrypi/console/usart.c
>             >     > @@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const
>             >     console_tbl *ct)
>             >     >  #endif
>             >     > +typedef struct {
>             >     > +  rtems_termios_device_context base;
>             >     > +  const char *device_name;
>             >     > +  volatile usart0_regs *regs;
>             >     > +}uart0_context;
>             >     Why uart0_context and not usart_context? All other
>             names in this file
>             >     are called usart_...
>             > Sorry, for the inconsistent naming, should I rename it as
>             pl011_context
>             > since we will be adding
>             > mini uart for rpi3, IMHO it would be better.
>             If you touch nearly all locations where the name is used:
>             Yes. But
>             again: There is already a generic pl011 driver. Use that
>             driver if possible.
>             >     >  static void usart_set_baud(int minor, int baud)
>             >     > @@ -55,10 +61,17 @@ static void usart_set_baud(int
>             minor, int baud)
>             >     >   return;
>             >     > -static void usart_initialize(int minor)
>             >     > +static volatile usart0_regs
>             >     > *rpi_uart_get_regs(rtems_termios_device_context *base)
>             >     > -  unsigned int gpio_reg;
>             >     > +  uart0_context *ctx;
>             >     > +  ctx = (usart0_regs *) base;
>             >     > +  return ctx->regs;
>             >     > +static void
>             usart_initialize(rtems_termios_device_context *base)
>             >     > +  unsigned int gpio_reg;
>             >     >    ** Program GPIO pins for UART 0
>             >     > @@ -75,67 +88,81 @@ static void usart_initialize(int
>             minor)
>             >     >    usart_delay(150);
>             >     >    BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>             >     > +  volatile uint32_t *uart_regs =
>             rpi_uart_get_regs(base);
>             >     >    ** Init the PL011 UART
>             >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>             >     > -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>             >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>             >     > -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>             >     > -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>             >     > -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>             >     > -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>             >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>             >     > -  usart_set_baud(minor, 115000);
>             >     > +  uart_regs->cr  = 0;
>             >     > +  uart_regs->icr = 0x7ff;
>             >     > +  uart_regs->imsc = 0;
>             >     > +  uart_regs->ibrd = 1;
>             >     > +  uart_regs->fbrd= 40;
>             >     > +  uart_regs->lcrh= 0x70;
>             >     > +  uart_regs->rsrecr= 0;
>             >     > +  uart_regs->cr = 0x301;
>             >     > +  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
>             >     > +  // usart_set_baud(minor, 115000);
>             >     Why is this line commented now?
>             > It actually does nothing. The function body was empty. The
>             current baud
>             > rate is set directly
>             > in the initialization function. I was planning to update
>             it once, I was
>             > finished with the interface.
>             If it is empty: Is it necessary? There is a
>             rtems_termios_set_initial_baud(...) which should do the same.
>             >     > -static int usart_first_open(int major, int minor,
>             void *arg)
>             >     > +static bool usart_first_open(
>             >     > +  rtems_termios_tty *tty,
>             >     > +  rtems_termios_device_context *base,
>             >     > +  struct termios *term,
>             >     > +  rtems_libio_open_close_args_t *args
>             >     > -  rtems_libio_open_close_args_t *oc =
>             >     > arg;
>             >     > -  struct rtems_termios_tty *tty = (struct
>             >     > oc->iop->data1;
>             >     > -  const console_tbl *ct = Console_Port_Tbl [minor];
>             >     > -  console_data *cd = &Console_Port_Data [minor];
>             >     > +  rtems_status_code sc;
>             >     > +  bool ok;
>             >     > -  cd->termios_data = tty;
>             >     > -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>             >     > +  ctx = (uart0_context *) base;
>             >     > -  return 0;
>             >     > +  usart_initialize(base);
>             >     > +  sc = rtems_termios_set_initial_baud(tty,
>              USART0_DEFAULT_BAUD);
>             >     > +  if ( sc != RTEMS_SUCCESSFUL ){
>             >     > +    printk("Error setting the baud for termios\n");
>             >     > +    return false;
>             >     There is a return missing here. Did you compile the
>             code? The compiler
>             >     should give you a warning about that.
>             >     > -static int usart_last_close(int major, int minor,
>             void *arg)
>             >     > +static int usart_last_close(
>             >     The first_open returns a bool but last_close returns
>             still an int? Is
>             >     this correct? I don't have the interface memorized.
>             > last_close return type is void.
>             Then you should fix that here.
>             >     > +  rtems_termios_open_close_args_t *arg)
>             >     >    return 0;
>             >     > -static int usart_read_polled(int minor)
>             >     > +static int
>             usart_read_polled(rtems_termios_device_context *base)
>             >     > -  if (minor == 0) {
>             >     > -    if (((BCM2835_REG(BCM2835_UART0_FR)) &
>             >     == 0) {
>             >     > -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>             >     > -    } else {
>             >     > -      return -1;
>             >     > -  } else {
>             >     > -    printk("Unknown console minor number: %d\n",
>             minor);
>             >     > -    return -1;
>             >     > +  regs = rpi_uart_get_regs(base);
>             >     Just noted that here: Why rpi_uart_get_regs and not
>             usart_get_regs?
>             >     Please use a consitent naming scheme.
>             >     > +  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
>             >     > +    return (regs->dr & 0xFF);
>             >     > +  return -1;
>             >     > -static void usart_write_polled(int minor, char c)
>             >     > +static void
>             usart_write_polled(rtems_termios_device_context
>             >     *base, char c)
>             >     > -   while (1) {
>             >     > -     if ((BCM2835_REG(BCM2835_UART0_FR) &
>             >     == 0)
>             >     > -       break;
>             >     > -   BCM2835_REG(BCM2835_UART0_DR) = c;
>             >     > +  while (1) {
>             >     > +    if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
>             >     > +      break;
>             >     > +  regs->dr = c;
>             >     >  static ssize_t usart_write_support_polled(
>             >     > -  int minor,
>             >     >    const char *s,
>             >     >    size_t n
>             >     > @@ -143,7 +170,7 @@ static ssize_t
>             >     >    ssize_t i = 0;
>             >     >    for (i = 0; i < n; ++i) {
>             >     > -    usart_write_polled(minor, s [i]);
>             >     > +    usart_write_polled(base, s[i]);
>             >     >    return n;
>             >     > @@ -154,14 +181,11 @@ static int
>             >     > struct termios *term)
>             >     >    return -1;
>             >     > -const console_fns bcm2835_usart_fns = {
>             >     > -  .deviceProbe = libchip_serial_default_probe,
>             >     > -  .deviceFirstOpen = usart_first_open,
>             >     > -  .deviceLastClose = usart_last_close,
>             >     > -  .deviceRead = usart_read_polled,
>             >     > -  .deviceWrite = usart_write_support_polled,
>             >     > -  .deviceInitialize = usart_initialize,
>             >     > -  .deviceWritePolled = usart_write_polled,
>             >     > -  .deviceSetAttributes = usart_set_attributes,
>             >     > -  .deviceOutputUsesInterrupts = false
>             >     > +const rtems_termios_device_handler
>             bcm2835_uart0_handler_polled = {
>             >     > +  .first_open = usart_first_open,
>             >     > +  .last_close = usart_last_close,
>             >     > +  .poll_read = usart_read_polled,
>             >     > +  .set_attributes = usart_set_attributes,
>             >     > +  .write = usart_write_support_polled,
>             >     > +  .mode = TERMIOS_POLLED
>             >     > \ No newline at end of file
>             >     > On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill
>             <joel at rtems.org <mailto:joel at rtems.org>
>             >     <mailto:joel at rtems.org <mailto:joel at rtems.org>>
>             >     > <mailto:joel at rtems.org <mailto:joel at rtems.org>
>             <mailto:joel at rtems.org <mailto:joel at rtems.org>>>> wrote:
>             >     >     On Tue, Dec 24, 2019, 12:19 PM Niteesh
>             <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>             >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>
>             >     >     <mailto:gsnb.gn at gmail.com
>             <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
>             <mailto:gsnb.gn at gmail.com>>>> wrote:
>             >     >         And also the register definitions are in
>             raspberrpi.h file
>             >     >         should I move them to usart.h.
>             >     >     Sounds right if you mean bsp/usart.h
>             >     >         I have a doubt we have a register field in
>             device_context
>             >     >         typedef struct {
>             >     >             rtems_termios_device_context base;
>             >     >             const char *device_name;
>             >     >             volatile some_chip_registers *regs;
>             >     >         } my_driver_context;
>             >     >         How does the reg field point to the correct
>             >     memory location? for
>             >     >         instance in IMX BSP,
>             >     >         there is a struct with register field's but
>             none of the
>             >     define a
>             >     >         memory location?
>             >     >     Make sure the structure has volatiles and proper
>             alignment. :)
>             >     >         On Tue, Dec 24, 2019 at 11:37 PM Niteesh
>             >     >             How to handle different serial devices?
>             In other BSPs the
>             >     >             uart devices are the same, so
>             >     >             they were able to put it under a single
>             array? But here we
>             >     >             have 2 uarts and a FB?
>             >     >             On Tue, Dec 24, 2019 at 8:18 PM
>             Christian Mauderer
>             >     >             <list at c-mauderer.de
>             <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>             <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>             >     >                 On 24/12/2019 12:06, Niteesh wrote:
>             >     >                 > The current raspi console section
>             is like this:
>             >     >                 > The bsp_console_select in
>             console_select.c is
>             >     >                 responsible for selecting
>             >     >                 > between uart and the framebuffer.
>             It does so
>             >     >                 > by setting the Console_port_minor.
>             >     >                 > The console_config is responsible
>             for output_char
>             >     >                 function.
>             >     >                 > And other files are driver code.
>             >     >                 > If rewriting, this would be my
>             approach,
>             >     >                 > Rewrite the bsp_console_select to
>             set some kind of a
>             >     >                 variable like in
>             >     >                 > IMX, then in console_initialize
>             function
>             >     >                 > link the right driver to /dev/console.
>             >     >                 > Replace the console_tbl with the
>             device_context and
>             >     >                 console_fns with
>             >     >                 > termios_device_handlers and
>             >     >                 > finally add in the
>             console_initialization function.
>             >     >                 I agree that this would be a clean
>             solution. So if you
>             >     >                 want you can do
>             >     >                 that. But there might is a hurdle:
>             As far as I
>             >     >                 understood you you only
>             >     >                 have a Pi3? So you might have a hard
>             time testing the
>             >     >                 changes. Maybe the
>             >     >                 simulator could work.
>             >     >                 Another possibility could be to set the
>             >     >                 "Console_port_minor" to
>             >     >                 something unused (for example -1).
>             In that case
>             >     you can
>             >     >                 define another
>             >     >                 /dev/console.
>             >     >                 Best regards and merry Christmas (in
>             case you
>             >     celebrate)
>             >     >                 Christian
>             >     >                 > On Tue, Dec 24, 2019 at 2:13 PM
>             Niteesh
>             >     >                 <gsnb.gn at gmail.com
>             <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>
>             >     >                 > <mailto:gsnb.gn at gmail.com
>             >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>>>
>             >     >                 wrote:
>             >     >                 >     Thank you so much, for such a
>             detailed
>             >     answer. Now
>             >     >                 things make
>             >     >                 >     really good sense to me,
>             >     >                 >     going through the code now is
>             just a breeze.
>             >     But I
>             >     >                 still have one
>             >     >                 >     question
>             >     >                 >     for the newer driver interface is
>             >     >                 console_initialize the function
>             >     >                 >     which RTEMS calls while
>             initializing
>             >     >                 >     the console? Which means I
>             can't mess with the
>             >     >                 name right? It is
>             >     >                 >     similar to the main function,
>             right?
>             >     >                 >     The current driver is a legacy
>             one, how do you
>             >     >                 want me to proceed,
>             >     >                 >     shall I rewrite the legacy to a
>             >     >                 >     the new one, this is will be a
>             great
>             >     >                 learning experience for me also
>             >     >                 >     and we also get the BSP
>             updated to the latest
>             >     >                 interface.
>             >     >                 >     On Tue, Dec 24, 2019 at 3:20
>             AM Christian
>             >     Mauderer
>             >     >                 >     <list at c-mauderer.de
>             <mailto:list at c-mauderer.de>> <mailto:list at c-mauderer.de
>             >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>
>             >     >                 wrote:
>             >     >                 >         Hello Niteesh,
>             >     >                 >         quite a lot of questions.
>             I'll try to answer
>             >     >                 them. Note that it
>             >     >                 >         has been
>             >     >                 >         some time since I had a
>             detailed look at
>             >     that
>             >     >                 code so if something I
>             >     >                 >         tell seems odd please
>             don't hesitate to
>             >     >                 question it.
>             >     >                 >         Please note that in RTEMS
>             their are more or
>             >     >                 less two "levels" of
>             >     >                 >         support
>             >     >                 >         for a serial console:
>             >     >                 >         1. A very basic polled
>             system console (also
>             >     >                 known as
>             >     >                 >         "debug-console" in
>             >     >                 >         some BSPs). This one is
>             used for printk and
>             >     >                 should work in basically
>             >     >                 >         every case. It is used for
>             critical system
>             >     >                 messages like
>             >     >                 >         printing the
>             >     >                 >         exception frame. For that
>             a BSP has to
>             >     provide a
>             >     >                 >         "BSP_output_char" function.
>             >     >                 >         2. A full featured UART driver
>             >     integrated into
>             >     >                 Termios. That one
>             >     >                 >         will be
>             >     >                 >         used for all normal I/O on
>             the UARTs.
>             >     >                 >         As far as I know the
>             "console_tbl
>             >     >                 Console_Configuration_Ports"
>             >     >                 >         belongs
>             >     >                 >         to a table based legacy
>             interface. It is
>             >     >                 handled in the file
>              bsps/shared/dev/serial/legacy-console.c. I'm
>             >     >                 not sure whether it is
>             >     >                 >         documented in the BSP
>             guide because it
>             >     >                 shouldn't be used for new
>             >     >                 >         BSPs.
>             >     >                 >         Same is true for the
>             "major" and "minor"
>             >     >                 stuff: It's not really
>             >     >                 >         used for
>             >     >                 >         new drivers.
>             >     >                 >         Newer drivers use the
>             initialization that is
>             >     >                 described in the manual
>             >     >                 >         that you have already
>             found. Basically
>             >     they use
>              "rtems_termios_device_install" to register a
>             >     >                 new UART as
>             >     >                 >         "/dev/ttySomething". Some
>             recent (ARM) BSPs
>             >     >                 that do that are the
>             >     >                 >         imx or
>             >     >                 >         the atsam.
>             >     >                 >         The console that is used
>             for stdin,
>             >     stdout and
>             >     >                 stderr (printf,
>             >     >                 >         scanf,
>             >     >                 >         ...) is the one called
>             "/dev/console"
>             >     (defined in
>             >     >                 >         CONSOLE_DEVICE_NAME).
>             >     >                 >         For the legacy table based
>             interface
>             >     it's the
>             >     >                 one with the index of
>             >     >                 >         "Console_Port_Minor".
>             >     >                 >         If you want to access any
>             UART other
>             >     than the
>             >     >                 one for stdin and
>             >     >                 >         stdout
>             >     >                 >         you do that the same way
>             like on Linux: Just
>             >     >                 use the "open"
>             >     >                 >         function on
>             >     >                 >         the "/dev/ttySomething"
>             and use "read",
>             >     >                 "write" and simmilar or use
>             >     >                 >         "fopen" together with
>             "fread", "fwrite",
>             >     >                 "fprintf", ...
>             >     >                 >         "printf" (and family) is a
>             function
>             >     belonging
>             >     >                 to the C library.
>             >     >                 >         In our
>             >     >                 >         case that's newlib. It
>             will format your
>             >     >                 message and after some other
>             >     >                 >         preprocessing will call
>             the "write" function
>             >     >                 of the file that is
>             >     >                 >         opened
>             >     >                 >         as stdout (which is
>             "/dev/console" in the
>             >     >                 default case).
>             >     >                 >         I hope that I helped you
>             with that
>             >     >                 explanation. Please feel free
>             >     >                 >         to ask
>             >     >                 >         anything if it isn't clear.
>             >     >                 >         Best regards
>             >     >                 >         Christian
>             >     >                 >         On 23/12/2019 19:50,
>             Niteesh wrote:
>             >     >                 >         > And finally, how does
>             printf work? It is a
>             >     >                 macro? In that
>             >     >                 >         case, how does
>             >     >                 >         > any write to
>             >     >                 >         > a console work?
>             >     >                 >         > On Tue, Dec 24, 2019 at
>             12:18 AM Niteesh
>             <mailto:gsnb.gn at gmail.com>>>>>> wrote:
>             >     >                 >         >     Is the correct port
>             minor number set
>             >     >                 during the
>             >     >                 >         initialization? What
>             >     >                 >         >     is the application
>             want's to
>             >     >                 >         >     access some other port?
>             at 12:16 AM
>             >     Niteesh
>             >     >                 >         <gsnb.gn at gmail.com
>             >     >                 >         >         I would like to
>             clarify my doubts
>             >     >                 regarding the
>             >     >                 >         console driver.
>             >     >                 >         >         I went through
>             the documentation
>             >     >                 >         >         for the console
>                 driver https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction.
>             >     >                 >         >         But it is quite
>             different from how
>             >     >                 some BSPs initialize.
>             >     >                 >         >         Correct me if I
>             am wrong
>             >     >                 >         >         The console_tbl
>             contains the
>             >     various
>             >     >                 entries of serial
>             >     >                 >         ports.
>             >     >                 >         >         The console_fns
>             is a struct of
>             >     >                 function pointers,
>             >     >                 >         which point to
>             >     >                 >         >         the BSP uart
>             functions.
>             >     >                 >         >         The
>             >     BSP_output_char_function_type is
>             >     >                 what will be
>             >     >                 >         called for
>             >     >                 >         >         printing a char
>             on to the console.
>             >     >                 >         >         How does RTEMS
>             initialize the
>             >     uart?
>             >     >                 It's seems not to
>             >     >                 >         be same
>             >     >                 >         >         for all BSPs.
>             >     >                 >         >         The doc says
>             that the driver's
>             >     >                 initialization function
>             >     >                 >         is called
>             >     >                 >         >         once during the
>             rtems
>             >     initialization
>             >     >                 process.
>             >     >                 >         >         The console init
>             function install
>             >     >                 the serial driver using
>              rtems_termios_device_install but
>             >     >                 there seems to be
>             >     >                 >         >         no such function
>             in the raspberry
>             >     >                 pi? But there is a
>             >     >                 >         entry in
>             >     >                 >         >         console_fns for
>             init function, but
>             >     >                 then how does it
>             >     >                 >         >         gets called?
>             >     >                 >         >         And for BSP's
>             with multiple
>             >     >                 serial's, the output function
>             >     >                 >         >         chooses the
>             right serial using
>             >     >                 console_port_minor,
>             >     >                 >         >         Is it during
>             initialization?
>             >     >                 >         >         What is the need
>             for get and set
>             >     >                 register functions?
>             >     >                 >         >         On Mon, Dec 23,
>             2019 at 1:04 AM
>             >     >                 Christian Mauderer
>             <mailto:list at c-mauderer.de>>> <mailto:list at c-mauderer.de
>             >     >                 >         <mailto:list at c-mauderer.de
>             <mailto:list at c-mauderer.de>>>>>> wrote:
>             >     >                 >         >             On
>             22/12/2019 19:45, Joel
>             >     >                 Sherrill wrote:
>             >     >                 >         >             > On Sun,
>             Dec 22, 2019,
>             >     12:29 PM
>             >     >                 Niteesh
>             <mailto:gsnb.gn at gmail.com>>>> <mailto:gsnb.gn at gmail.com
>             <mailto:gsnb.gn at gmail.com>>>>>>> wrote:
>             >     >                 >         >             >     On
>             Sun, Dec 22, 2019 at
>             >     >                 8:44 PM Christian
>             >     >                 >         Mauderer
>             <mailto:list at c-mauderer.de>>>> <mailto:list at c-mauderer.de
>             <mailto:list at c-mauderer.de>>>>>>> wrote:
>              Hello Niteesh,
>              thanks for doing
>             >     that
>             >     >                 work.
>             >     >                 >         >             >         On
>             22/12/2019 12:10,
>             >     >                 Niteesh wrote:
>             The rpi1 and rpi2
>             >     >                 use the PL011 UART,
>             >     >                 >         whereas,
>             >     >                 >         >             with RPI's
>              equipped with
>             wireless/Bluetooth
>             >     >                 module, the PL011 is
>             >     >                 >         >             connected to
>             the Bluetooth
>             module, and
>             >     the mini
>             >     >                 UART is used as
>             >     >                 >         the primary
>             >     >                 >         >             UART.
>             >     >                 >         >             >         In
>             my opinion it
>             >     would
>             >     >                 be great if you
>             >     >                 >         could use
>             >     >                 >         >             the FDT to
>              distinguish
>              between the boards.
>             >     >                 That should allow to add
>             >     >                 >         >             raspberry 3 (and
>              maybe 4)
>              support without
>             >     adding
>             >     >                 another BSP. More
>             >     >                 >         BSPs mean
>             >     >                 >         >             a bigger
>              maintenance
>              effort for the RTEMS
>             >     >                 community.
>              Learning more about
>             >     FDT is
>             >     >                 on my list for a long
>             >     >                 >         >             time.  I
>             would love
>             >     >                 >         >             >     to
>             work on that
>             >     >                 >         >             >     but I
>             have almost no exp
>             >     >                 with FDT's.
>             >     >                 >         >             >     But
>             another thing could
>             >     >                 also be done, in
>             >     >                  raspberrypi/start/bspstart.c we get the
>             >     >                 >         revision and
>             >     >                 >         >             >     model
>             of the board using
>             >     >                 the mailbox. Every
>             >     >                 >         board has
>             >     >                 >         >             a unique id,
>             >     >                 >         >             >     which
>             we could use to
>             >     >                 initialize
>             >     >                 >         >             >     the
>             BSP. But using FDT
>             >     >                 seems to be a more
>             >     >                 >         elegant
>             >     >                 >         >             option, it is a
>             >     >                 >         >             >     lot of
>             work I think, but
>             >     >                 we could take
>             >     >                 >         >             >     help
>             from libbsd and
>             >     linux
>             >     >                 I suppose. What
>             >     >                 >         do you think?
>             >     >                 >         >             > I think
>             there are almost
>             >     >                 always two steps to a
>             >     >                 >         project
>             >     >                 >         >             like this:
>             get it
>             >     >                 >         >             > to work
>             and make it nice. :)
>             >     >                 >         >             > If you fix
>             the startup
>             >     code to
>             >     >                 read the board
>             >     >                 >         revision and
>             >     >                 >         >             memory size,
>             >     >                 >         >             > you can
>             get a working
>             >     BSP that
>             >     >                 dynamically
>             >     >                 >         adapts to the
>             >     >                 >         >             models and
>             >     >                 >         >             > memory
>             variations with
>             >     minimal
>             >     >                 modifications. If
>             >     >                 >         you want
>             >     >                 >         >             to then
>             >     >                 >         >             > convert
>             the BSP to FDT, it
>             >     >                 will be a LOT easier
>             >     >                 >         to debug
>             >     >                 >         >             with a
>             working BSP.
>             >     >                 >         >             > Plus you
>             may be able to
>             >     >                 identify every variation
>             >     >                 >         point
>             >     >                 >         >             based on
>             just the
>             >     >                 >         >             > model
>             info. Then FDT is
>             >     just a
>             >     >                 matter of
>             >     >                 >         switching the
>             >     >                 >         >             source of
>             >     >                 >         >             > some/all
>             of the info.
>             >     >                 >         >             > That would
>             be my work
>             >     plan anyway.
>             >     >                 >         >             I agree with
>             Joel that a
>             >     secure
>             >     >                 development basis
>             >     >                 >         (also
>             >     >                 >         >             known as "hack")
>             >     >                 >         >             as a first
>             step is a good
>             >     idea.
>             >     >                 You maybe even
>             >     >                 >         just make the
>             >     >                 >         >             mini UART
>             >     >                 >         >             the default
>             driver while
>             >     you are
>             >     >                 developing. Then
>             >     >                 >         you can be
>             >     >                 >         >             sure that
>             >     >                 >         >             you have the
>             right driver.
>             >     >                 >         >             As soon as
>             that works you can
>             >     >                 either change to the
>             >     >                 >         revision
>             >     >                 >         >             method or
>             >     >                 >         >             (better) to
>             the FDT one and
>             >     >                 after that the patches
>             >     >                 >         can be
>             >     >                 >         >             merged. Using
>             >     >                 >         >             the FDT
>             isn't that
>             >     complicated.
>             >     >                 Basically you
>             >     >                 >         search for a
>             >     >                 >         >             node based on
>             >     >                 >         >             different
>             parameters. For an
>             >     >                 example you can take
>             >     >                 >         a look at
>             >     >                 >         >             the imx BSP.
>             >     >                 >         >             In
>             imx_uart_probe
>              (bsps/arm/imx/console/console-config.c) a
>             >     >                 >         >             fdt node is
>             >     >                 >         >             searched and
>             based on that a
>             >     >                 UART driver is used.
>             >     >                 >         But again:
>             >     >                 >         >             Follow
>             >     >                 >         >             Joels
>             suggestion to start
>             >     simple
>             >     >                 and secure.
>                  https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>             But from the above
>             >     >                 doc (PAGE 10), the
>             >     >                 >         mini uart
>             >     >                 >         >             has 16550 like
>              registers
>             and RTEMS already
>             >     >                 has the driver for it
>             >     >                 bsps/shared/dev/serial/ns16550.c. But
>             >     >                 >         I am not
>             >     >                 >         >             sure how
>              compatible they
>             are? Should a new
>             >     >                 driver be
>             >     >                 >         implemented from
>             >     >                 >         >             scratch or use
>              ns16550 if
>             possible?
>             >     >                 >         >             >         In
>             general it's
>             >     better
>             >     >                 to re-use
>             >     >                 >         existing code.
>             >     >                 >         >             That has
>             multiple
>              advantages:
>             It reduces the
>             >     >                 maintenance effort.
>             >     >                 >         Fewer code
>             >     >                 >         >             means fewer
>             work.
>             If you have
>             >     multiple
>             >     >                 driver for the
>             >     >                 >         same or
>             >     >                 >         >             similar hardware
>             >     >                 >         >             >         it can
>              happen that a bug is
>             >     >                 fixed in one but
>             >     >                 >         not the other.
>             It's simpler
>             >     to find
>             >     >                 a hardware to
>             >     >                 >         test changes.
>             The driver becomes
>             >     >                 more universal with
>             >     >                 >         every new
>             >     >                 >         >             supported
>              hardware.
>              That increases the
>             >     >                 chance that it fits
>             >     >                 >         the next
>             >     >                 >         >             new hardware.
>              I'm sure there are
>             >     >                 some more if you ask
>             >     >                 >         someone else.
>             >     >                 >         >             >     I do
>             understand the
>             >     >                 issues, I just spent
>             >     >                 >         some time
>             >     >                 >         >             reading the
>             >     >                 >         >             >     driver
>             code.
>             >     >                 >         >             >     I
>             think we could most
>             >     >                 probably use it. I
>             >     >                 >         will take a
>             >     >                 >         >             closer look and
>             >     >                 >         >             >     will
>             update.
>             >     >                 >         >             Great.
>             Also, the core
>             >     clock
>             >     >                 on which the
>             >     >                 >         PL011 is based
>             >     >                 >         >             on is changed
>             >     >                 >         >             >         in
>             rpi3.
>             Rpi1 and 2 use
>             >     >                 250Mhz as the default
>             >     >                 >         clock but
>             >     >                 >         >             it was changed
>             >     >                 >         >             >         to
>             400Mhz
>             in Rpi3 and newer
>              Again: Would be
>             >     great
>             >     >                 if that could be
>             >     >                 >         adapted
>             >     >                 >         >             based on FDT
>             or by
>              reading the right
>             >     >                 registers.
>             Few differences
>             >     >                 between PL011 and Mini
>             >     >                 >         uart
>             The mini UART has
>             >     >                 smaller FIFOs.
>             >     >                 >         Combined with
>             >     >                 >         >             the lack of
>              flow control,
>             this makes it more
>             >     >                 prone to losing
>             >     >                 >         characters at
>             >     >                 >         >             higher baud
>              rates. It
>             is also generally
>             >     >                 less capable than
>             >     >                 >         the PL011,
>             >     >                 >         >             mainly due to
>              its baud
>             rate link to
>             >     the VPU
>             >     >                 clock speed.
>              That shouldn't
>             >     really
>             >     >                 be a problem for
>             >     >                 >         the system
>             >     >                 >         >             console.
>             The particular
>             >     >                 deficiencies of the
>             >     >                 >         mini UART
>             >     >                 >         >             compared to the
>              PL011 are :
>             No break detection
>             No framing errors
>             >     >                 detection
>             No parity bit
>             No receive timeout
>             >     >                 interrupt
>             No DCD, DSR,
>             >     DTR or
>             >     >                 RI signals
>               _______________________________________________
>             >     >                 >         >             >     devel
>             mailing list
>              devel at rtems.org <mailto:devel at rtems.org>
>             >     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>             >     >                 <mailto:devel at rtems.org
>             <mailto:devel at rtems.org> <mailto:devel at rtems.org
>             <mailto:devel at rtems.org>>>
>             <mailto:devel at rtems.org>>>>
>             >     >                 >         <mailto:devel at rtems.org
>             <mailto:devel at rtems.org>>>>>
>             <mailto:devel at rtems.org>>>>>>
>               http://lists.rtems.org/mailman/listinfo/devel
