Raspberrypi3: Mini UART driver
Niteesh gsnb.gn at gmail.com
Fri Dec 27 10:03:14 UTC 2019
I tried building it. I basically ran make in previously create rpi2 BSP
folder.
I did get some compile-time error, but I have fixed them. Now I get an*
undefined reference to `arm_pl011_write_polled'*
How to include the arm_pl011.c file?
On Fri, Dec 27, 2019 at 3:15 PM Niteesh <gsnb.gn at gmail.com> wrote:
> The changes I have made so far
> diff --git a/bsps/arm/raspberrypi/console/console-config.c
> b/bsps/arm/raspberrypi/console/console-config.c
> index d2186c918b..d982b2c9c2 100644
> --- a/bsps/arm/raspberrypi/console/console-config.c
> +++ b/bsps/arm/raspberrypi/console/console-config.c
> @@ -22,45 +22,53 @@
>  #include <libchip/serial.h>
> -#include <bspopts.h>
>  #include <bsp/irq.h>
>  #include <bsp/usart.h>
>  #include <bsp/raspberrypi.h>
> +#include <bsp/arm-pl011.h>
>  #include <bsp/fbcons.h>
> -console_tbl Console_Configuration_Ports [] = {
> -      .sDeviceName = "/dev/ttyS0",
> -      .deviceType = SERIAL_CUSTOM,
> -      .pDeviceFns = &bcm2835_usart_fns,
> -      .deviceProbe = NULL,
> -      .pDeviceFlow = NULL,
> -      .ulCtrlPort1 = BCM2835_UART0_BASE,
> -      .ulCtrlPort2 = 0,
> -      .ulClock = USART0_DEFAULT_BAUD,
> -      .ulIntVector = BCM2835_IRQ_ID_UART
> -      .sDeviceName ="/dev/fbcons",
> -      .pDeviceFns = &fbcons_fns,
> -      .deviceProbe = fbcons_probe,
> +#include <bspopts.h>
> +arm_pl011_context pl011_context = {
> +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
> +  .regs = (volatile pl011 *) BCM2835_PL011_BASE,
> +  .initial_baud = PL011_DEFAULT_BAUD
> -#define PORT_COUNT \
> -  (sizeof(Console_Configuration_Ports) \
> -    / sizeof(Console_Configuration_Ports [0]))
> +rpi_fb_context fb_context = {
> +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
> -unsigned long Console_Configuration_Count = PORT_COUNT;
> +const console_device console_device_table[] = {
> +    .device_file = "/dev/ttyS0",
> +    .probe = console_device_probe_default,
> +    .handler = &arm_pl011_fns,
> +    .context = &pl011_context.base
> +    .device_file = "/dev/fb0",
> +    // Should be changed to fbcons_probe (but it still use old interface)
> +    .probe = fbcons_probe,
> +    .handler = &fbcons_fns,
> +    .context = &fb_context.base
> +const size_t console_device_count =
> RTEMS_ARRAY_SIZE(console_device_table);
>  static void output_char(char c)
> -  const console_fns *con =
> -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
> -  con->deviceWritePolled((int) Console_Port_Minor, c);
> +  switch(SERIAL){
> +    case FB:
> +      fbcons_write_polled(&fb_context.base, c);
> +      break;
> +    case PL011:
> +      arm_pl011_write_polled(&pl011_context.base, c);
> +      break;
>  BSP_output_char_function_type BSP_output_char = output_char;
> diff --git a/bsps/arm/raspberrypi/console/console_select.c
> b/bsps/arm/raspberrypi/console/console_select.c
> index bd246ca868..dbca5c324f 100644
> --- a/bsps/arm/raspberrypi/console/console_select.c
> +++ b/bsps/arm/raspberrypi/console/console_select.c
> @@ -15,7 +15,7 @@
>   *  http://www.rtems.org/license/LICENSE
> +#include <bsp/raspberrypi.h>
>  #include <bsp.h>
>  #include <bsp/fatal.h>
>  #include <rtems/libio.h>
> @@ -30,53 +30,7 @@
>  #include <bsp/rpi-fb.h>
>  rtems_device_minor_number BSPPrintkPort = 0;
> - * Method to return true if the device associated with the
> - * minor number probs available.
> -static bool bsp_Is_Available( rtems_device_minor_number minor )
> -  console_tbl *cptr = Console_Port_Tbl[ minor ];
> -   * First perform the configuration dependent probe, then the
> -   * device dependent probe
> -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
> -       cptr->pDeviceFns->deviceProbe( minor ) ) {
> -    return true;
> -  return false;
> - * Method to return the first available device.
> -static rtems_device_minor_number bsp_First_Available_Device( void )
> -  rtems_device_minor_number minor;
> -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
> -      return minor;
> -   *  Error No devices were found.  We will want to bail here.
> -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> +CURRENT_SERIAL SERIAL = PL011;
>  void bsp_console_select( void )
> @@ -90,25 +44,13 @@ void bsp_console_select( void )
>    const char *opt;
> -  Console_Port_Minor = BSP_CONSOLE_UART0;
> -  BSPPrintkPort = BSP_CONSOLE_UART0;
>    opt = rpi_cmdline_get_arg( "--console=" );
>    if ( opt ) {
>      if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
>        if ( rpi_video_is_initialized() > 0 ) {
> -        Console_Port_Minor = BSP_CONSOLE_FB;
> -        BSPPrintkPort = BSP_CONSOLE_FB;
> +        SERIAL = FB;
> -   * If the device that was selected isn't available then
> -   * let the user know and select the first available device.
> -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
> -    Console_Port_Minor = bsp_First_Available_Device();
> diff --git a/bsps/arm/raspberrypi/console/fbcons.c
> b/bsps/arm/raspberrypi/console/fbcons.c
> index 3669ba458d..26a694ac9f 100644
> --- a/bsps/arm/raspberrypi/console/fbcons.c
> +++ b/bsps/arm/raspberrypi/console/fbcons.c
> @@ -18,6 +18,7 @@
>  #include <rtems.h>
> +#include <rtems/termiostypes.h>
>  #include <stdlib.h>
> @@ -46,9 +47,10 @@ static void fbcons_init( int minor )
>   *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
>  static int fbcons_open(
> -  int   major,
> -  int   minor,
> -  void *arg
> +  struct rtems_termios_tty *tty,
> +  rtems_termios_device_context *base,
> +  struct termios *term,
> +  rtems_libio_open_close_args_t *args
>    return RTEMS_SUCCESSFUL;
> @@ -60,9 +62,9 @@ static int fbcons_open(
>   *  This function shuts down the requested port.
>  static int fbcons_close(
> -  int   major,
> -  int   minor,
> -  void *arg
>    return ( RTEMS_SUCCESSFUL );
> @@ -73,8 +75,8 @@ static int fbcons_close(
>   *  This routine polls out the requested character.
> -static void fbcons_write_polled(
> -  int  minor,
> +void fbcons_write_polled(
>    char c
> @@ -91,7 +93,7 @@ static void fbcons_write_polled(
>  static ssize_t fbcons_write_support_polled(
> -  int         minor,
>    const char *buf,
>    size_t      len
> @@ -102,7 +104,7 @@ static ssize_t fbcons_write_support_polled(
>     * poll each byte in the string out of the port.
>    while ( nwrite < len ) {
> -    fbcons_write_polled( minor, *buf++ );
> +    fbcons_write_polled( base, *buf++ );
>      nwrite++;
> @@ -117,7 +119,9 @@ static ssize_t fbcons_write_support_polled(
>   *  Console Termios polling input entry point.
> -static int fbcons_inbyte_nonblocking_polled( int minor )
> +static int fbcons_inbyte_nonblocking_polled(
>    // if( rtems_kbpoll() ) {
>    //   int c = getch();
> @@ -134,14 +138,16 @@ static int fbcons_inbyte_nonblocking_polled( int
> minor )
>   *  port settings.
>  static int fbcons_set_attributes(
> -  int                   minor,
>    const struct termios *t
>    return 0;
> -bool fbcons_probe( int minor )
> +bool fbcons_probe(
>    // rtems_status_code status;
>    static bool firstTime = true;
> @@ -163,15 +169,11 @@ bool fbcons_probe( int minor )
>    return ret;
> -const console_fns fbcons_fns =
> +const rtems_termios_device_handler fbcons_fns =
> -  .deviceProbe = libchip_serial_default_probe,     /* deviceProbe */
> -  .deviceFirstOpen = fbcons_open,                 /* deviceFirstOpen */
> -  .deviceLastClose = fbcons_close,                /* deviceLastClose */
> -  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
> -  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite */
> -  .deviceInitialize = fbcons_init,                /* deviceInitialize */
> -  .deviceWritePolled = fbcons_write_polled,       /* deviceWritePolled */
> -  .deviceSetAttributes = fbcons_set_attributes,   /* deviceSetAttributes
> -  .deviceOutputUsesInterrupts = FALSE,           /*
> deviceOutputUsesInterrupts*/
> +  .first_open = fbcons_open,
> +  .last_close = fbcons_close,
> +  .poll_read = fbcons_inbyte_nonblocking_polled,
> +  .write = fbcons_write_support_polled,
> +  .mode = TERMIOS_POLLED
> \ No newline at end of file
> diff --git a/bsps/arm/raspberrypi/console/usart.c
> b/bsps/arm/raspberrypi/console/usart.c
> index 25fb523621..471d0c553f 100644
> --- a/bsps/arm/raspberrypi/console/usart.c
> +++ b/bsps/arm/raspberrypi/console/usart.c
> @@ -23,145 +23,3 @@
>  #include <rtems/bspIo.h>
> -static void usart_delay(uint32_t n)
> - volatile uint32_t i = 0;
> - for(i = 0; i < n; i++)
> -#if 0
> - *  These will be useful when the driver supports interrupt driven IO.
> -static rtems_vector_number usart_get_irq_number(const console_tbl *ct)
> -  return ct->ulIntVector;
> -static uint32_t usart_get_baud(const console_tbl *ct)
> -  return ct->ulClock;
> -#endif
> -static void usart_set_baud(int minor, int baud)
> -  * Nothing for now
> - return;
> -static void usart_initialize(int minor)
> -  unsigned int gpio_reg;
> -  ** Program GPIO pins for UART 0
> -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
> -  gpio_reg &= ~(7<<12);    /* gpio14 */
> -  gpio_reg |=  (4<<12);    /* alt0   */
> -  gpio_reg &= ~(7<<15);    /* gpio15 */
> -  gpio_reg |=  (4<<15);    /* alt0   */
> -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
> -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
> -  usart_delay(150);
> -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
> -  usart_delay(150);
> -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> -  ** Init the PL011 UART
> -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
> -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
> -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
> -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
> -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
> -  usart_set_baud(minor, 115000);
> -static int usart_first_open(int major, int minor, void *arg)
> -  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *)
> arg;
> -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
> oc->iop->data1;
> -  const console_tbl *ct = Console_Port_Tbl [minor];
> -  console_data *cd = &Console_Port_Data [minor];
> -  cd->termios_data = tty;
> -  rtems_termios_set_initial_baud(tty, ct->ulClock);
> -  return 0;
> -static int usart_last_close(int major, int minor, void *arg)
> -  return 0;
> -static int usart_read_polled(int minor)
> -  if (minor == 0) {
> -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) == 0) {
> -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
> -    } else {
> -      return -1;
> -  } else {
> -    printk("Unknown console minor number: %d\n", minor);
> -    return -1;
> -static void usart_write_polled(int minor, char c)
> -   while (1) {
> -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
> -       break;
> -   BCM2835_REG(BCM2835_UART0_DR) = c;
> -static ssize_t usart_write_support_polled(
> -  int minor,
> -  const char *s,
> -  size_t n
> -  ssize_t i = 0;
> -  for (i = 0; i < n; ++i) {
> -    usart_write_polled(minor, s [i]);
> -  return n;
> -static int usart_set_attributes(int minor, const struct termios *term)
> -  return -1;
> -const console_fns bcm2835_usart_fns = {
> -  .deviceFirstOpen = usart_first_open,
> -  .deviceLastClose = usart_last_close,
> -  .deviceRead = usart_read_polled,
> -  .deviceWrite = usart_write_support_polled,
> -  .deviceInitialize = usart_initialize,
> -  .deviceWritePolled = usart_write_polled,
> -  .deviceSetAttributes = usart_set_attributes,
> -  .deviceOutputUsesInterrupts = false
> diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> index d0e126699a..f2ff25dc63 100644
> --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> @@ -33,12 +33,23 @@ extern "C" {
>  #define FB_CONSOLE 0x50492835
> -bool fbcons_probe( int minor );
> +bool fbcons_probe(
> +  char c
> +typedef struct {
> +    rtems_termios_device_context base;
> +} rpi_fb_context ;
>   * Driver function table
> -extern const console_fns fbcons_fns;
> +extern const rtems_termios_device_handler fbcons_fns;
>  #ifdef __cplusplus
> diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> index 40c80cf408..4e5c84c741 100644
> --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> @@ -60,6 +60,22 @@
>  #define RPI_PERIPHERAL_SIZE         0x01000000
> + * @name Current Serial Device
> +typedef enum {
> +  PL011 = 0,
> +  AUX_UART,
> +  FB
> +}CURRENT_SERIAL;
> +extern CURRENT_SERIAL SERIAL;
>   * @name Internal ARM Timer Registers
> @@ -184,42 +200,6 @@
> - * @name UART 0 (PL011) Registers
> -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
> -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
> -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
> -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
> -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
> -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
> -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
> -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
> -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
> -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
> -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
> -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
> -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
> -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
> -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
> -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
> -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
> -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
> -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
> -#define BCM2835_UART0_MIS_RX    0x10
> -#define BCM2835_UART0_MIS_TX    0x20
> -#define BCM2835_UART0_IMSC_RX   0x10
> -#define BCM2835_UART0_IMSC_TX   0x20
> -#define BCM2835_UART0_FR_RXFE   0x10
> -#define BCM2835_UART0_FR_TXFF   0x20
> -#define BCM2835_UART0_ICR_RX    0x10
> -#define BCM2835_UART0_ICR_TX    0x20
> diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
> b/bsps/arm/raspberrypi/include/bsp/usart.h
> index d3e710c5e9..abbf53626c 100644
> --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> @@ -32,9 +32,8 @@
>  extern "C" {
>  #endif /* __cplusplus */
> -#define USART0_DEFAULT_BAUD 115000
> -extern const console_fns bcm2835_usart_fns;
> +#define PL011_DEFAULT_BAUD 115000
> +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>  #ifdef __cplusplus
> On Fri, Dec 27, 2019 at 3:12 PM Niteesh <gsnb.gn at gmail.com> wrote:
>> On Fri, Dec 27, 2019 at 2:53 PM Christian Mauderer <list at c-mauderer.de>
>> wrote:
>>> Hello Niteesh,
>>> let me repeat two important questions:
>>> - How do you plan to test the changes? Simulator is OK for me but
>>> untested is not OK.
>> Since I don't have the older pi's, the simulator will be my only option.
>> And did you
>> take a look at the exception?
>>> - Isn't it possible to just use the driver from
>>> bsps/arm/shared/serial/arm-pl011.c and remove the BSP specific
>>> completely?
>> Yes, I have done this. I usart.c file is now completely empty. All we
>> have to define was
>> the start address for the PL011 peripheral in usart.h.
>>> On 27/12/2019 06:29, Niteesh wrote:
>>> > On Fri, Dec 27, 2019 at 1:58 AM Christian Mauderer <list at c-mauderer.de
>>> > <mailto:list at c-mauderer.de>> wrote:
>>> >     Hello Niteesh,
>>> >     sorry for not answering earlier. During this time of the year you
>>> have
>>> >     to expect some delays on the mailing list due to public holydays
>>> and
>>> >     vacations.
>>> > That's okay, I understand.
>>> >     On 25/12/2019 10:50, Niteesh wrote:
>>> >     > Just to make sure I am going in the right track.
>>> >     > I moved the uart register definitions to bsp/usart.h into a
>>> struct of
>>> >     > uint32_t called usart0_regs
>>> >     > here is git diff of usart.c after changing it to the latest
>>> console
>>> >     > interface.
>>> >     Do you have a plan how you want to test these changes?
>>> >     The direction looks OK. Some notes below.
>>> >     By the way: Maybe it would be a better idea to just remove it
>>> completely
>>> >     and use the bsps/arm/shared/serial/arm-pl011.c driver instead? That
>>> >     reduces the ammount of code and therefore ammount of bugs we have
>>> in
>>> >     this BSP.
>>> >     > index 25fb523621..b12f375a1c 100644
>>> >     > @@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const
>>> >     console_tbl *ct)
>>> >     >  #endif
>>> >     > +typedef struct {
>>> >     > +  const char *device_name;
>>> >     > +  volatile usart0_regs *regs;
>>> >     > +}uart0_context;
>>> >     Why uart0_context and not usart_context? All other names in this
>>> file
>>> >     are called usart_...
>>> > Sorry, for the inconsistent naming, should I rename it as pl011_context
>>> > since we will be adding
>>> > mini uart for rpi3, IMHO it would be better.
>>> If you touch nearly all locations where the name is used: Yes. But
>>> again: There is already a generic pl011 driver. Use that driver if
>>> possible.
>>> >     > @@ -55,10 +61,17 @@ static void usart_set_baud(int minor, int
>>> baud)
>>> >     >   return;
>>> >     > +static volatile usart0_regs
>>> >     > *rpi_uart_get_regs(rtems_termios_device_context *base)
>>> >     > +  uart0_context *ctx;
>>> >     > +  ctx = (usart0_regs *) base;
>>> >     > +  return ctx->regs;
>>> >     > +static void usart_initialize(rtems_termios_device_context *base)
>>> >     > +  unsigned int gpio_reg;
>>> >     > @@ -75,67 +88,81 @@ static void usart_initialize(int minor)
>>> >     >    usart_delay(150);
>>> >     > +  volatile uint32_t *uart_regs = rpi_uart_get_regs(base);
>>> >     > +  uart_regs->cr  = 0;
>>> >     > +  uart_regs->icr = 0x7ff;
>>> >     > +  uart_regs->imsc = 0;
>>> >     > +  uart_regs->ibrd = 1;
>>> >     > +  uart_regs->fbrd= 40;
>>> >     > +  uart_regs->lcrh= 0x70;
>>> >     > +  uart_regs->rsrecr= 0;
>>> >     > +  uart_regs->cr = 0x301;
>>> >     > +  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
>>> >     > +  // usart_set_baud(minor, 115000);
>>> >     Why is this line commented now?
>>> > It actually does nothing. The function body was empty. The current baud
>>> > rate is set directly
>>> > in the initialization function. I was planning to update it once, I was
>>> > finished with the interface.
>>> If it is empty: Is it necessary? There is a
>>> rtems_termios_set_initial_baud(...) which should do the same.
>>> >     > +static bool usart_first_open(
>>> >     > +  rtems_termios_tty *tty,
>>> >     > arg;
>>> >     > oc->iop->data1;
>>> >     > +  rtems_status_code sc;
>>> >     > +  bool ok;
>>> >     > +  ctx = (uart0_context *) base;
>>> >     > -  return 0;
>>> >     > +  usart_initialize(base);
>>> >     > +  sc = rtems_termios_set_initial_baud(tty,
>>>  USART0_DEFAULT_BAUD);
>>> >     > +  if ( sc != RTEMS_SUCCESSFUL ){
>>> >     > +    printk("Error setting the baud for termios\n");
>>> >     > +    return false;
>>> >     There is a return missing here. Did you compile the code? The
>>> compiler
>>> >     should give you a warning about that.
>>> >     > +static int usart_last_close(
>>> >     The first_open returns a bool but last_close returns still an int?
>>> Is
>>> >     this correct? I don't have the interface memorized.
>>> > last_close return type is void.
>>> Then you should fix that here.
>>> >     > +  rtems_termios_open_close_args_t *arg)
>>> >     >    return 0;
>>> >     > +static int usart_read_polled(rtems_termios_device_context *base)
>>> >     > -  if (minor == 0) {
>>> >     == 0) {
>>> >     > -    } else {
>>> >     > -      return -1;
>>> >     > -  } else {
>>> >     > -    return -1;
>>> >     > +  regs = rpi_uart_get_regs(base);
>>> >     Just noted that here: Why rpi_uart_get_regs and not usart_get_regs?
>>> >     Please use a consitent naming scheme.
>>> >     > +  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
>>> >     > +    return (regs->dr & 0xFF);
>>> >     > +  return -1;
>>> >     > +static void usart_write_polled(rtems_termios_device_context
>>> >     *base, char c)
>>> >     > -   while (1) {
>>> >     == 0)
>>> >     > -       break;
>>> >     > +  while (1) {
>>> >     > +    if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
>>> >     > +      break;
>>> >     > +  regs->dr = c;
>>> >     > -  int minor,
>>> >     >    const char *s,
>>> >     >    size_t n
>>> >     > @@ -143,7 +170,7 @@ static ssize_t usart_write_support_polled(
>>> >     >    ssize_t i = 0;
>>> >     > +    usart_write_polled(base, s[i]);
>>> >     >    return n;
>>> >     > @@ -154,14 +181,11 @@ static int usart_set_attributes(int minor,
>>> const
>>> >     >    return -1;
>>> >     > +const rtems_termios_device_handler bcm2835_uart0_handler_polled
>>> >     > +  .first_open = usart_first_open,
>>> >     > +  .last_close = usart_last_close,
>>> >     > +  .poll_read = usart_read_polled,
>>> >     > +  .set_attributes = usart_set_attributes,
>>> >     > +  .write = usart_write_support_polled,
>>> >     > On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill <joel at rtems.org
>>> >     <mailto:joel at rtems.org>
>>> >     > <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>>> >     >     On Tue, Dec 24, 2019, 12:19 PM Niteesh <gsnb.gn at gmail.com
>>> >     <mailto:gsnb.gn at gmail.com>
>>> >     >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>
>>> wrote:
>>> >     >         And also the register definitions are in raspberrpi.h
>>> file
>>> >     >         should I move them to usart.h.
>>> >     >     Sounds right if you mean bsp/usart.h
>>> >     >         I have a doubt we have a register field in device_context
>>> >     >         typedef struct {
>>> >     >             volatile some_chip_registers *regs;
>>> >     >         } my_driver_context;
>>> >     >         How does the reg field point to the correct
>>> >     memory location? for
>>> >     >         instance in IMX BSP,
>>> >     >         there is a struct with register field's but none of the
>>> >     define a
>>> >     >         memory location?
>>> >     >     Make sure the structure has volatiles and proper alignment.
>>> >     >         On Tue, Dec 24, 2019 at 11:37 PM Niteesh
>>> >     <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>>> wrote:
>>> >     >             How to handle different serial devices? In other
>>> BSPs the
>>> >     >             uart devices are the same, so
>>> >     >             they were able to put it under a single array? But
>>> here we
>>> >     >             have 2 uarts and a FB?
>>> >     >             On Tue, Dec 24, 2019 at 8:18 PM Christian Mauderer
>>> >     >             <list at c-mauderer.de <mailto:list at c-mauderer.de>
>>> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>>> >     >                 On 24/12/2019 12:06, Niteesh wrote:
>>> >     >                 > The current raspi console section is like this:
>>> >     >                 > The bsp_console_select in console_select.c is
>>> >     >                 responsible for selecting
>>> >     >                 > between uart and the framebuffer. It does so
>>> >     >                 > by setting the Console_port_minor.
>>> >     >                 > The console_config is responsible for
>>> output_char
>>> >     >                 function.
>>> >     >                 > And other files are driver code.
>>> >     >                 > If rewriting, this would be my approach,
>>> >     >                 > Rewrite the bsp_console_select to set some
>>> kind of a
>>> >     >                 variable like in
>>> >     >                 > IMX, then in console_initialize function
>>> >     >                 > link the right driver to /dev/console.
>>> >     >                 > Replace the console_tbl with the
>>> device_context and
>>> >     >                 console_fns with
>>> >     >                 > termios_device_handlers and
>>> >     >                 > finally add in the console_initialization
>>> function.
>>> >     >                 I agree that this would be a clean solution. So
>>> if you
>>> >     >                 want you can do
>>> >     >                 that. But there might is a hurdle: As far as I
>>> >     >                 understood you you only
>>> >     >                 have a Pi3? So you might have a hard time
>>> testing the
>>> >     >                 changes. Maybe the
>>> >     >                 simulator could work.
>>> >     >                 Another possibility could be to set the
>>> >     >                 "Console_port_minor" to
>>> >     >                 something unused (for example -1). In that case
>>> >     you can
>>> >     >                 define another
>>> >     >                 /dev/console.
>>> >     >                 Best regards and merry Christmas (in case you
>>> >     celebrate)
>>> >     >                 Christian
>>> >     >                 > On Tue, Dec 24, 2019 at 2:13 PM Niteesh
>>> >     <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
>>> >     <mailto:gsnb.gn at gmail.com>>>>
>>> >     >                 wrote:
>>> >     >                 >     Thank you so much, for such a detailed
>>> >     answer. Now
>>> >     >                 things make
>>> >     >                 >     really good sense to me,
>>> >     >                 >     going through the code now is just a
>>> breeze.
>>> >     But I
>>> >     >                 still have one
>>> >     >                 >     question
>>> >     >                 >     for the newer driver interface is
>>> >     >                 console_initialize the function
>>> >     >                 >     which RTEMS calls while initializing
>>> >     >                 >     the console? Which means I can't mess with
>>> the
>>> >     >                 name right? It is
>>> >     >                 >     similar to the main function, right?
>>> >     >                 >     The current driver is a legacy one, how do
>>> you
>>> >     >                 want me to proceed,
>>> >     >                 >     shall I rewrite the legacy to a
>>> >     >                 >     the new one, this is will be a great
>>> >     >                 learning experience for me also
>>> >     >                 >     and we also get the BSP updated to the
>>> latest
>>> >     >                 interface.
>>> >     >                 >     On Tue, Dec 24, 2019 at 3:20 AM Christian
>>> >     Mauderer
>>> >     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>>> >     <mailto:list at c-mauderer.de>>>>
>>> >     >                 wrote:
>>> >     >                 >         Hello Niteesh,
>>> >     >                 >         quite a lot of questions. I'll try to
>>> answer
>>> >     >                 them. Note that it
>>> >     >                 >         has been
>>> >     >                 >         some time since I had a detailed look
>>> at
>>> >     that
>>> >     >                 code so if something I
>>> >     >                 >         tell seems odd please don't hesitate to
>>> >     >                 question it.
>>> >     >                 >         Please note that in RTEMS their are
>>> more or
>>> >     >                 less two "levels" of
>>> >     >                 >         support
>>> >     >                 >         for a serial console:
>>> >     >                 >         1. A very basic polled system console
>>> (also
>>> >     >                 known as
>>> >     >                 >         "debug-console" in
>>> >     >                 >         some BSPs). This one is used for
>>> printk and
>>> >     >                 should work in basically
>>> >     >                 >         every case. It is used for critical
>>> system
>>> >     >                 messages like
>>> >     >                 >         printing the
>>> >     >                 >         exception frame. For that a BSP has to
>>> >     provide a
>>> >     >                 >         "BSP_output_char" function.
>>> >     >                 >         2. A full featured UART driver
>>> >     integrated into
>>> >     >                 Termios. That one
>>> >     >                 >         will be
>>> >     >                 >         used for all normal I/O on the UARTs.
>>> >     >                 >         As far as I know the "console_tbl
>>> >     >                 Console_Configuration_Ports"
>>> >     >                 >         belongs
>>> >     >                 >         to a table based legacy interface. It
>>> is
>>> >     >                 handled in the file
>>>  bsps/shared/dev/serial/legacy-console.c. I'm
>>> >     >                 not sure whether it is
>>> >     >                 >         documented in the BSP guide because it
>>> >     >                 shouldn't be used for new
>>> >     >                 >         BSPs.
>>> >     >                 >         Same is true for the "major" and
>>> "minor"
>>> >     >                 stuff: It's not really
>>> >     >                 >         used for
>>> >     >                 >         new drivers.
>>> >     >                 >         Newer drivers use the initialization
>>> that is
>>> >     >                 described in the manual
>>> >     >                 >         that you have already found. Basically
>>> >     they use
>>> >     >                 >         "rtems_termios_device_install" to
>>> register a
>>> >     >                 new UART as
>>> >     >                 >         "/dev/ttySomething". Some recent (ARM)
>>> BSPs
>>> >     >                 that do that are the
>>> >     >                 >         imx or
>>> >     >                 >         the atsam.
>>> >     >                 >         The console that is used for stdin,
>>> >     stdout and
>>> >     >                 stderr (printf,
>>> >     >                 >         scanf,
>>> >     >                 >         ...) is the one called "/dev/console"
>>> >     (defined in
>>> >     >                 >         CONSOLE_DEVICE_NAME).
>>> >     >                 >         For the legacy table based interface
>>> >     it's the
>>> >     >                 one with the index of
>>> >     >                 >         "Console_Port_Minor".
>>> >     >                 >         If you want to access any UART other
>>> >     than the
>>> >     >                 one for stdin and
>>> >     >                 >         stdout
>>> >     >                 >         you do that the same way like on
>>> Linux: Just
>>> >     >                 use the "open"
>>> >     >                 >         function on
>>> >     >                 >         the "/dev/ttySomething" and use "read",
>>> >     >                 "write" and simmilar or use
>>> >     >                 >         "fopen" together with "fread",
>>> "fwrite",
>>> >     >                 "fprintf", ...
>>> >     >                 >         "printf" (and family) is a function
>>> >     belonging
>>> >     >                 to the C library.
>>> >     >                 >         In our
>>> >     >                 >         case that's newlib. It will format your
>>> >     >                 message and after some other
>>> >     >                 >         preprocessing will call the "write"
>>> function
>>> >     >                 of the file that is
>>> >     >                 >         opened
>>> >     >                 >         as stdout (which is "/dev/console" in
>>> the
>>> >     >                 default case).
>>> >     >                 >         I hope that I helped you with that
>>> >     >                 explanation. Please feel free
>>> >     >                 >         to ask
>>> >     >                 >         anything if it isn't clear.
>>> >     >                 >         Best regards
>>> >     >                 >         Christian
>>> >     >                 >         On 23/12/2019 19:50, Niteesh wrote:
>>> >     >                 >         > And finally, how does printf work?
>>> It is a
>>> >     >                 macro? In that
>>> >     >                 >         case, how does
>>> >     >                 >         > any write to
>>> >     >                 >         > a console work?
>>> >     >                 >         > On Tue, Dec 24, 2019 at 12:18 AM
>>> Niteesh
>>> >     <mailto:gsnb.gn at gmail.com>> <mailto:gsnb.gn at gmail.com
>>> >     <mailto:gsnb.gn at gmail.com>>>>> wrote:
>>> >     >                 >         >     Is the correct port minor number
>>> set
>>> >     >                 during the
>>> >     >                 >         initialization? What
>>> >     >                 >         >     is the application want's to
>>> >     >                 >         >     access some other port?
>>> >     >                 >         >     On Tue, Dec 24, 2019 at 12:16 AM
>>> >     Niteesh
>>> >     >                 >         >         I would like to clarify my
>>> doubts
>>> >     >                 regarding the
>>> >     >                 >         console driver.
>>> >     >                 >         >         I went through the
>>> documentation
>>> >     >                 >         >         for the console
>>> >        driver
>>> https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction
>>> >     >                 >         >         But it is quite different
>>> from how
>>> >     >                 some BSPs initialize.
>>> >     >                 >         >         Correct me if I am wrong
>>> >     >                 >         >         The console_tbl contains the
>>> >     various
>>> >     >                 entries of serial
>>> >     >                 >         ports.
>>> >     >                 >         >         The console_fns is a struct
>>> of
>>> >     >                 function pointers,
>>> >     >                 >         which point to
>>> >     >                 >         >         the BSP uart functions.
>>> >     >                 >         >         The
>>> >     BSP_output_char_function_type is
>>> >     >                 what will be
>>> >     >                 >         called for
>>> >     >                 >         >         printing a char on to the
>>> console.
>>> >     >                 >         >         How does RTEMS initialize the
>>> >     uart?
>>> >     >                 It's seems not to
>>> >     >                 >         be same
>>> >     >                 >         >         for all BSPs.
>>> >     >                 >         >         The doc says that the
>>> driver's
>>> >     >                 >         is called
>>> >     >                 >         >         once during the rtems
>>> >     initialization
>>> >     >                 process.
>>> >     >                 >         >         The console init function
>>> install
>>> >     >                 the serial driver using
>>> but
>>> >     >                 there seems to be
>>> >     >                 >         >         no such function in the
>>> raspberry
>>> >     >                 pi? But there is a
>>> >     >                 >         entry in
>>> >     >                 >         >         console_fns for init
>>> function, but
>>> >     >                 then how does it
>>> >     >                 >         >         gets called?
>>> >     >                 >         >         And for BSP's with multiple
>>> >     >                 serial's, the output function
>>> >     >                 >         >         chooses the right serial
>>> using
>>> >     >                 console_port_minor,
>>> >     >                 >         >         Is it during initialization?
>>> >     >                 >         >         What is the need for get and
>>> set
>>> >     >                 register functions?
>>> >     >                 >         >         On Mon, Dec 23, 2019 at 1:04
>>> AM
>>> >     >                 Christian Mauderer
>>> >     <mailto:list at c-mauderer.de>> <mailto:list at c-mauderer.de
>>> >     <mailto:list at c-mauderer.de>>>>> wrote:
>>> >     >                 >         >             On 22/12/2019 19:45, Joel
>>> >     >                 Sherrill wrote:
>>> >     >                 >         >             > On Sun, Dec 22, 2019,
>>> >     12:29 PM
>>> >     >                 Niteesh
>>> >     >                 >         >             <mailto:
>>> >     <mailto:gsnb.gn at gmail.com>>> <mailto:gsnb.gn at gmail.com
>>> >     <mailto:gsnb.gn at gmail.com>>>>>> wrote:
>>> >     >                 >         >             >     On Sun, Dec 22,
>>> 2019 at
>>> >     >                 8:44 PM Christian
>>> >     >                 >         Mauderer
>>> >     <mailto:list at c-mauderer.de>>> <mailto:list at c-mauderer.de
>>> >     >                 >         >             <mailto:
>>> >     <mailto:list at c-mauderer.de>>>>>> wrote:
>>> >     >                 >         >             >         Hello Niteesh,
>>> >     >                 >         >             >         thanks for
>>> doing
>>> >     that
>>> >     >                 work.
>>> >     >                 >         >             >         On 22/12/2019
>>> 12:10,
>>> >     >                 Niteesh wrote:
>>> >     >                 >         >             >         > The rpi1 and
>>> rpi2
>>> >     >                 use the PL011 UART,
>>> >     >                 >         whereas,
>>> >     >                 >         >             with RPI's
>>> >     >                 >         >             >         equipped with
>>> wireless/Bluetooth
>>> >     >                 module, the PL011 is
>>> >     >                 >         >             connected to the
>>> Bluetooth
>>> >     >                 >         >             >         > module, and
>>> >     the mini
>>> >     >                 UART is used as
>>> >     >                 >         the primary
>>> >     >                 >         >             UART.
>>> >     >                 >         >             >         In my opinion
>>> it
>>> >     would
>>> >     >                 be great if you
>>> >     >                 >         could use
>>> >     >                 >         >             the FDT to
>>> >     >                 >         >             >         distinguish
>>> >     >                 >         >             >         between the
>>> boards.
>>> >     >                 That should allow to add
>>> >     >                 >         >             raspberry 3 (and
>>> >     >                 >         >             >         maybe 4)
>>> >     >                 >         >             >         support without
>>> >     adding
>>> >     >                 another BSP. More
>>> >     >                 >         BSPs mean
>>> >     >                 >         >             a bigger
>>> >     >                 >         >             >         maintenance
>>> >     >                 >         >             >         effort for the
>>> RTEMS
>>> >     >                 community.
>>> >     >                 >         >             >     Learning more about
>>> >     FDT is
>>> >     >                 on my list for a long
>>> >     >                 >         >             time.  I would love
>>> >     >                 >         >             >     to work on that
>>> >     >                 >         >             >     but I have almost
>>> no exp
>>> >     >                 with FDT's.
>>> >     >                 >         >             >     But another thing
>>> could
>>> >     >                 also be done, in
>>> >     >                  raspberrypi/start/bspstart.c we get the
>>> >     >                 >         revision and
>>> >     >                 >         >             >     model of the board
>>> using
>>> >     >                 the mailbox. Every
>>> >     >                 >         board has
>>> >     >                 >         >             a unique id,
>>> >     >                 >         >             >     which we could use
>>> to
>>> >     >                 initialize
>>> >     >                 >         >             >     the BSP. But using
>>> FDT
>>> >     >                 seems to be a more
>>> >     >                 >         elegant
>>> >     >                 >         >             option, it is a
>>> >     >                 >         >             >     lot of work I
>>> think, but
>>> >     >                 we could take
>>> >     >                 >         >             >     help from libbsd
>>> and
>>> >     linux
>>> >     >                 I suppose. What
>>> >     >                 >         do you think?
>>> >     >                 >         >             > I think there are
>>> almost
>>> >     >                 always two steps to a
>>> >     >                 >         project
>>> >     >                 >         >             like this: get it
>>> >     >                 >         >             > to work and make it
>>> nice. :)
>>> >     >                 >         >             > If you fix the startup
>>> >     code to
>>> >     >                 read the board
>>> >     >                 >         revision and
>>> >     >                 >         >             memory size,
>>> >     >                 >         >             > you can get a working
>>> >     BSP that
>>> >     >                 dynamically
>>> >     >                 >         adapts to the
>>> >     >                 >         >             models and
>>> >     >                 >         >             > memory variations with
>>> >     minimal
>>> >     >                 modifications. If
>>> >     >                 >         you want
>>> >     >                 >         >             to then
>>> >     >                 >         >             > convert the BSP to
>>> FDT, it
>>> >     >                 will be a LOT easier
>>> >     >                 >         to debug
>>> >     >                 >         >             with a working BSP.
>>> >     >                 >         >             > Plus you may be able to
>>> >     >                 identify every variation
>>> >     >                 >         point
>>> >     >                 >         >             based on just the
>>> >     >                 >         >             > model info. Then FDT is
>>> >     just a
>>> >     >                 matter of
>>> >     >                 >         switching the
>>> >     >                 >         >             source of
>>> >     >                 >         >             > some/all of the info.
>>> >     >                 >         >             > That would be my work
>>> >     plan anyway.
>>> >     >                 >         >             I agree with Joel that a
>>> >     secure
>>> >     >                 development basis
>>> >     >                 >         (also
>>> >     >                 >         >             known as "hack")
>>> >     >                 >         >             as a first step is a good
>>> >     idea.
>>> >     >                 You maybe even
>>> >     >                 >         just make the
>>> >     >                 >         >             mini UART
>>> >     >                 >         >             the default driver while
>>> >     you are
>>> >     >                 developing. Then
>>> >     >                 >         you can be
>>> >     >                 >         >             sure that
>>> >     >                 >         >             you have the right
>>> driver.
>>> >     >                 >         >             As soon as that works
>>> you can
>>> >     >                 either change to the
>>> >     >                 >         revision
>>> >     >                 >         >             method or
>>> >     >                 >         >             (better) to the FDT one
>>> and
>>> >     >                 after that the patches
>>> >     >                 >         can be
>>> >     >                 >         >             merged. Using
>>> >     >                 >         >             the FDT isn't that
>>> >     complicated.
>>> >     >                 Basically you
>>> >     >                 >         search for a
>>> >     >                 >         >             node based on
>>> >     >                 >         >             different parameters.
>>> For an
>>> >     >                 example you can take
>>> >     >                 >         a look at
>>> >     >                 >         >             the imx BSP.
>>> >     >                 >         >             In imx_uart_probe
>>>  (bsps/arm/imx/console/console-config.c) a
>>> >     >                 >         >             fdt node is
>>> >     >                 >         >             searched and based on
>>> that a
>>> >     >                 UART driver is used.
>>> >     >                 >         But again:
>>> >     >                 >         >             Follow
>>> >     >                 >         >             Joels suggestion to start
>>> >     simple
>>> >     >                 and secure.
>>> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>>> >     >                 >         >             >         > But from the
>>> above
>>> >     >                 doc (PAGE 10), the
>>> >     >                 >         mini uart
>>> >     >                 >         >             has 16550 like
>>> >     >                 >         >             >         registers
>>> >     >                 >         >             >         > and RTEMS
>>> already
>>> >     >                 has the driver for it
>>> >     >                 bsps/shared/dev/serial/ns16550.c. But
>>> >     >                 >         I am not
>>> >     >                 >         >             sure how
>>> >     >                 >         >             >         compatible they
>>> >     >                 >         >             >         > are? Should
>>> a new
>>> >     >                 driver be
>>> >     >                 >         implemented from
>>> >     >                 >         >             scratch or use
>>> >     >                 >         >             >         ns16550 if
>>> >     >                 >         >             >         > possible?
>>> >     >                 >         >             >         In general it's
>>> >     better
>>> >     >                 to re-use
>>> >     >                 >         existing code.
>>> >     >                 >         >             That has multiple
>>> >     >                 >         >             >         advantages:
>>> >     >                 >         >             >         - It reduces
>>> the
>>> >     >                 maintenance effort.
>>> >     >                 >         Fewer code
>>> >     >                 >         >             means fewer work.
>>> >     >                 >         >             >         - If you have
>>> >     multiple
>>> >     >                 driver for the
>>> >     >                 >         same or
>>> >     >                 >         >             similar hardware
>>> >     >                 >         >             >         it can
>>> >     >                 >         >             >         happen that a
>>> bug is
>>> >     >                 fixed in one but
>>> >     >                 >         not the other.
>>> >     >                 >         >             >         - It's simpler
>>> >     to find
>>> >     >                 a hardware to
>>> >     >                 >         test changes.
>>> >     >                 >         >             >         - The driver
>>> becomes
>>> >     >                 more universal with
>>> >     >                 >         every new
>>> >     >                 >         >             supported
>>> >     >                 >         >             >         hardware.
>>> >     >                 >         >             >         That increases
>>> the
>>> >     >                 chance that it fits
>>> >     >                 >         the next
>>> >     >                 >         >             new hardware.
>>> >     >                 >         >             >         I'm sure there
>>> are
>>> >     >                 some more if you ask
>>> >     >                 >         someone else.
>>> >     >                 >         >             >     I do understand the
>>> >     >                 issues, I just spent
>>> >     >                 >         some time
>>> >     >                 >         >             reading the
>>> >     >                 >         >             >     driver code.
>>> >     >                 >         >             >     I think we could
>>> most
>>> >     >                 probably use it. I
>>> >     >                 >         will take a
>>> >     >                 >         >             closer look and
>>> >     >                 >         >             >     will update.
>>> >     >                 >         >             Great.
>>> >     >                 >         >             >         > Also, the
>>> core
>>> >     clock
>>> >     >                 on which the
>>> >     >                 >         PL011 is based
>>> >     >                 >         >             on is changed
>>> >     >                 >         >             >         in rpi3.
>>> >     >                 >         >             >         > Rpi1 and 2
>>> use
>>> >     >                 250Mhz as the default
>>> >     >                 >         clock but
>>> >     >                 >         >             it was changed
>>> >     >                 >         >             >         to 400Mhz
>>> >     >                 >         >             >         > in Rpi3 and
>>> newer
>>> >     >                 >         >             >         Again: Would be
>>> >     great
>>> >     >                 if that could be
>>> >     >                 >         adapted
>>> >     >                 >         >             based on FDT or by
>>> >     >                 >         >             >         reading the
>>> right
>>> >     >                 registers.
>>> >     >                 >         >             >         > Few
>>> differences
>>> >     >                 between PL011 and Mini
>>> >     >                 >         uart
>>> >     >                 >         >             >         > The mini
>>> UART has
>>> >     >                 smaller FIFOs.
>>> >     >                 >         Combined with
>>> >     >                 >         >             the lack of
>>> >     >                 >         >             >         flow control,
>>> >     >                 >         >             >         > this makes
>>> it more
>>> >     >                 prone to losing
>>> >     >                 >         characters at
>>> >     >                 >         >             higher baud
>>> >     >                 >         >             >         rates. It
>>> >     >                 >         >             >         > is also
>>> generally
>>> >     >                 less capable than
>>> >     >                 >         the PL011,
>>> >     >                 >         >             mainly due to
>>> >     >                 >         >             >         its baud
>>> >     >                 >         >             >         > rate link to
>>> >     the VPU
>>> >     >                 clock speed.
>>> >     >                 >         >             >         That shouldn't
>>> >     really
>>> >     >                 be a problem for
>>> >     >                 >         the system
>>> >     >                 >         >             console.
>>> >     >                 >         >             >         > The
>>> particular
>>> >     >                 deficiencies of the
>>> >     >                 >         mini UART
>>> >     >                 >         >             compared to the
>>> >     >                 >         >             >         PL011 are :
>>> >     >                 >         >             >         > No break
>>> detection
>>> >     >                 >         >             >         > No framing
>>> errors
>>> >     >                 detection
>>> >     >                 >         >             >         > No parity bit
>>> >     >                 >         >             >         > No receive
>>> timeout
>>> >     >                 interrupt
>>> >     >                 >         >             >         > No DCD, DSR,
>>> >     DTR or
>>> >     >                 RI signals
>>> >     >                  _______________________________________________
>>> >     >                 >         >             >     devel mailing list
>>> >     >                 >         >             >     devel at rtems.org
>>> >     <mailto:devel at rtems.org>
>>> >     >                 <mailto:devel at rtems.org <mailto:devel at rtems.org
>>> >     <mailto:devel at rtems.org <mailto:devel at rtems.org>
>>> >     >                  http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191227/c9f7c146/attachment-0001.html>
