[PATCH] Raspberrypi: updated the console interface.
Christian Mauderer list at c-mauderer.de
Fri Dec 27 22:18:29 UTC 2019
Hello,
git complained about some whitespaces when applying the patch:
git am \[PATCH\]\ Raspberrypi:\ updated\ the\ console\ interface..eml
Applying: Raspberrypi: updated the console interface.
/home/christian/rtems/rtems-bbb/.git/modules/rtems/rebase-apply/patch:96: trailing
whitespace.
/home/christian/rtems/rtems-bbb/.git/modules/rtems/rebase-apply/patch:304:
trailing whitespace.
const rtems_termios_device_handler fbcons_fns =
/home/christian/rtems/rtems-bbb/.git/modules/rtems/rebase-apply/patch:481:
bool fbcons_probe(
/home/christian/rtems/rtems-bbb/.git/modules/rtems/rebase-apply/patch:515:
 * @name Current Serial Device
warning: 4 lines add whitespace errors.
When compiling I get some warnings like
/home/christian/rtems/rtems-bbb/build/..//libs/rtems/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/arm/raspberrypi/console/console-config.c:
In function 'output_char':
/home/christian/rtems/rtems-bbb/build/..//libs/rtems/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/arm/raspberrypi/console/console-config.c:64:3:
warning: enumeration value 'AUX_UART' not handled in switch [-Wswitch]
   switch(SERIAL){
and
/home/christian/rtems/rtems-bbb/build/..//libs/rtems/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/arm/raspberrypi/console/fbcons.c:174:17:
warning: initialization from incompatible pointer type
[-Wincompatible-pointer-types]
   .first_open = fbcons_open,
Please fix these. I'm not entirely sure about the first warning. That
might has been there before. If possible it would be nice if you could
fix it anyway. In that case maybe in an extra commit.
At least the PL011 works on a Pi2 on real hardware too. I haven't tested
the framebuffer yet. I'm still trying to find out how to select it
before or after the patch.
Please see my notes in the patch below regarding some points.
Best regards
Christian
On 27/12/2019 12:08, G S Niteesh wrote:
> The patch updates the older console interface used by the BSP,
> to newer one. It also replaces the custom usart(PL011) driver
> with arm-pl011. The fb functions signatures where also changed
> to accommodate with interface update.
>  bsps/arm/raspberrypi/console/console-config.c |  67 +++++----
>  bsps/arm/raspberrypi/console/console_select.c |  65 +-------
>  bsps/arm/raspberrypi/console/fbcons.c         |  50 +++---
>  bsps/arm/raspberrypi/console/usart.c          | 142 ------------------
>  bsps/arm/raspberrypi/include/bsp/fbcons.h     |  19 ++-
>  .../arm/raspberrypi/include/bsp/raspberrypi.h |  52 ++-----
>  bsps/arm/raspberrypi/include/bsp/usart.h      |   5 +-
>  c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |   5 +-
>  8 files changed, 105 insertions(+), 300 deletions(-)
> diff --git a/bsps/arm/raspberrypi/console/console-config.c b/bsps/arm/raspberrypi/console/console-config.c
> index d2186c918b..1f6dec384a 100644
> --- a/bsps/arm/raspberrypi/console/console-config.c
> +++ b/bsps/arm/raspberrypi/console/console-config.c
> @@ -22,45 +22,54 @@
>  #include <libchip/serial.h>
> -#include <bspopts.h>
> -#include <bsp/irq.h>
> +#include <bsp.h>
>  #include <bsp/usart.h>
>  #include <bsp/raspberrypi.h>
> +#include <bsp/arm-pl011.h>
>  #include <bsp/fbcons.h>
> +#include <bsp/console-termios.h>
> +#include <bspopts.h>
> -console_tbl Console_Configuration_Ports [] = {
> -      .sDeviceName = "/dev/ttyS0",
> -      .deviceType = SERIAL_CUSTOM,
> -      .pDeviceFns = &bcm2835_usart_fns,
> -      .deviceProbe = NULL,
> -      .pDeviceFlow = NULL,
> -      .ulCtrlPort1 = BCM2835_UART0_BASE,
> -      .ulCtrlPort2 = 0,
> -      .ulClock = USART0_DEFAULT_BAUD,
> -      .ulIntVector = BCM2835_IRQ_ID_UART
> -      .sDeviceName ="/dev/fbcons",
> -      .pDeviceFns = &fbcons_fns,
> -      .deviceProbe = fbcons_probe,
> +arm_pl011_context pl011_context = {
> +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
> +  .regs = (volatile pl011 *) BCM2835_PL011_BASE,
> +  .initial_baud = PL011_DEFAULT_BAUD
> -#define PORT_COUNT \
> -  (sizeof(Console_Configuration_Ports) \
> -    / sizeof(Console_Configuration_Ports [0]))
> +rpi_fb_context fb_context = {
> +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
> -unsigned long Console_Configuration_Count = PORT_COUNT;
> +const console_device console_device_table[] = {
> +    .device_file = "/dev/ttyS0",
> +    .probe = console_device_probe_default,
> +    .handler = &arm_pl011_fns,
> +    .context = &pl011_context.base
> +    .device_file = "/dev/fbcons",
> +    // Should be changed to fbcons_probe (but it still use old interface)
What do you mean with that comment?
> +    .probe = fbcons_probe,
> +    .handler = &fbcons_fns,
> +    .context = &fb_context.base
> +const size_t console_device_count = RTEMS_ARRAY_SIZE(console_device_table);
>  static void output_char(char c)
> -  const console_fns *con =
> -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
> -  con->deviceWritePolled((int) Console_Port_Minor, c);
> +  switch(SERIAL){
> +    case FB:
> +      fbcons_write_polled(&fb_context.base, c);
> +      break;
> +    case PL011:
> +      arm_pl011_write_polled(&pl011_context.base, c);
> +      break;
I don't like that selection method.
1. I'm not happy with that naming. It's a variable so please write it in
lower case. Same is true for the type CURRENT_SERIAL. It should be a
lower case name.
2. There is no default case.
3. This adds lot's of overhead. It means that for every character a
switch case has to be evaluated. BSP_output_char is a pointer so you can
just change it's value to point to one of two functions.
>  BSP_output_char_function_type BSP_output_char = output_char;
> diff --git a/bsps/arm/raspberrypi/console/console_select.c b/bsps/arm/raspberrypi/console/console_select.c
> index bd246ca868..a7bd844bb0 100644
> --- a/bsps/arm/raspberrypi/console/console_select.c
> +++ b/bsps/arm/raspberrypi/console/console_select.c
> @@ -15,7 +15,7 @@
>   *  http://www.rtems.org/license/LICENSE
> +#include <bsp/raspberrypi.h>
>  #include <bsp.h>
>  #include <bsp/fatal.h>
>  #include <rtems/libio.h>
> @@ -24,59 +24,12 @@
>  #include <assert.h>
>  #include <termios.h>
> -#include <rtems/termiostypes.h>
>  #include "../../shared/dev/serial/legacy-console.h"
>  #include <bsp/rpi-fb.h>
>  rtems_device_minor_number BSPPrintkPort = 0;
> - * Method to return true if the device associated with the
> - * minor number probs available.
> -static bool bsp_Is_Available( rtems_device_minor_number minor )
> -  console_tbl *cptr = Console_Port_Tbl[ minor ];
> -   * First perform the configuration dependent probe, then the
> -   * device dependent probe
> -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
> -       cptr->pDeviceFns->deviceProbe( minor ) ) {
> -    return true;
> -  return false;
> - * Method to return the first available device.
> -static rtems_device_minor_number bsp_First_Available_Device( void )
> -  rtems_device_minor_number minor;
> -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
> -      return minor;
> -   *  Error No devices were found.  We will want to bail here.
> -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> +CURRENT_SERIAL SERIAL = PL011;>
>  void bsp_console_select( void )
> @@ -90,25 +43,13 @@ void bsp_console_select( void )
>    const char *opt;
> -  Console_Port_Minor = BSP_CONSOLE_UART0;
> -  BSPPrintkPort = BSP_CONSOLE_UART0;
>    opt = rpi_cmdline_get_arg( "--console=" );
>    if ( opt ) {
>      if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
>        if ( rpi_video_is_initialized() > 0 ) {
> -        Console_Port_Minor = BSP_CONSOLE_FB;
> -        BSPPrintkPort = BSP_CONSOLE_FB;
> +        SERIAL = FB;
> -   * If the device that was selected isn't available then
> -   * let the user know and select the first available device.
> -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
> -    Console_Port_Minor = bsp_First_Available_Device();
> diff --git a/bsps/arm/raspberrypi/console/fbcons.c b/bsps/arm/raspberrypi/console/fbcons.c
> index 3669ba458d..99f2ab1aff 100644
> --- a/bsps/arm/raspberrypi/console/fbcons.c
> +++ b/bsps/arm/raspberrypi/console/fbcons.c
> @@ -18,6 +18,7 @@
>  #include <rtems.h>
> +#include <rtems/termiostypes.h>
>  #include <stdlib.h>
> @@ -46,9 +47,10 @@ static void fbcons_init( int minor )
>   *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
>  static int fbcons_open(
> -  int   major,
> -  int   minor,
> -  void *arg
> +  struct rtems_termios_tty *tty,
> +  rtems_termios_device_context *base,
> +  struct termios *term,
> +  rtems_libio_open_close_args_t *args
>    return RTEMS_SUCCESSFUL;
> @@ -60,9 +62,9 @@ static int fbcons_open(
>   *  This function shuts down the requested port.
>  static int fbcons_close(
> -  int   major,
> -  int   minor,
> -  void *arg
>    return ( RTEMS_SUCCESSFUL );
> @@ -73,8 +75,8 @@ static int fbcons_close(
>   *  This routine polls out the requested character.
> -static void fbcons_write_polled(
> -  int  minor,
> +void fbcons_write_polled(
>    char c
> @@ -91,7 +93,7 @@ static void fbcons_write_polled(
>  static ssize_t fbcons_write_support_polled(
> -  int         minor,
>    const char *buf,
>    size_t      len
> @@ -102,7 +104,7 @@ static ssize_t fbcons_write_support_polled(
>     * poll each byte in the string out of the port.
>    while ( nwrite < len ) {
> -    fbcons_write_polled( minor, *buf++ );
> +    fbcons_write_polled( base, *buf++ );
>      nwrite++;
> @@ -117,7 +119,9 @@ static ssize_t fbcons_write_support_polled(
>   *  Console Termios polling input entry point.
> -static int fbcons_inbyte_nonblocking_polled( int minor )
> +int fbcons_inbyte_nonblocking_polled(
>    // if( rtems_kbpoll() ) {
>    //   int c = getch();
> @@ -134,14 +138,16 @@ static int fbcons_inbyte_nonblocking_polled( int minor )
>   *  port settings.
>  static int fbcons_set_attributes(
> -  int                   minor,
>    const struct termios *t
>    return 0;
> -bool fbcons_probe( int minor )
> +bool fbcons_probe(
>    // rtems_status_code status;
>    static bool firstTime = true;
> @@ -163,15 +169,11 @@ bool fbcons_probe( int minor )
>    return ret;
> -const console_fns fbcons_fns =
> +const rtems_termios_device_handler fbcons_fns =
> -  .deviceProbe = libchip_serial_default_probe,     /* deviceProbe */
> -  .deviceFirstOpen = fbcons_open,                 /* deviceFirstOpen */
> -  .deviceLastClose = fbcons_close,                /* deviceLastClose */
> -  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
> -  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite */
> -  .deviceInitialize = fbcons_init,                /* deviceInitialize */
> -  .deviceWritePolled = fbcons_write_polled,       /* deviceWritePolled */
> -  .deviceSetAttributes = fbcons_set_attributes,   /* deviceSetAttributes */
> -  .deviceOutputUsesInterrupts = FALSE,           /* deviceOutputUsesInterrupts*/
> +  .first_open = fbcons_open,
> +  .last_close = fbcons_close,
> +  .poll_read = fbcons_inbyte_nonblocking_polled,
> +  .write = fbcons_write_support_polled,
> +  .mode = TERMIOS_POLLED
> \ No newline at end of file
> diff --git a/bsps/arm/raspberrypi/console/usart.c b/bsps/arm/raspberrypi/console/usart.c
> index 25fb523621..471d0c553f 100644
> --- a/bsps/arm/raspberrypi/console/usart.c
> +++ b/bsps/arm/raspberrypi/console/usart.c
> @@ -23,145 +23,3 @@
>  #include <rtems/bspIo.h>
> -static void usart_delay(uint32_t n)
> - volatile uint32_t i = 0;
> - for(i = 0; i < n; i++)
> -#if 0
> - *  These will be useful when the driver supports interrupt driven IO.
> -static rtems_vector_number usart_get_irq_number(const console_tbl *ct)
> -  return ct->ulIntVector;
> -static uint32_t usart_get_baud(const console_tbl *ct)
> -  return ct->ulClock;
> -#endif
> -static void usart_set_baud(int minor, int baud)
> -  * Nothing for now
> - return;
> -static void usart_initialize(int minor)
> -  unsigned int gpio_reg;
> -  ** Program GPIO pins for UART 0
> -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
> -  gpio_reg &= ~(7<<12);    /* gpio14 */
> -  gpio_reg |=  (4<<12);    /* alt0   */
> -  gpio_reg &= ~(7<<15);    /* gpio15 */
> -  gpio_reg |=  (4<<15);    /* alt0   */
> -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
> -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
> -  usart_delay(150);
> -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
> -  usart_delay(150);
> -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> -  ** Init the PL011 UART
> -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
> -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
> -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
> -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
> -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
> -  usart_set_baud(minor, 115000);
> -static int usart_first_open(int major, int minor, void *arg)
> -  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *) arg;
> -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *) oc->iop->data1;
> -  const console_tbl *ct = Console_Port_Tbl [minor];
> -  console_data *cd = &Console_Port_Data [minor];
> -  cd->termios_data = tty;
> -  rtems_termios_set_initial_baud(tty, ct->ulClock);
> -  return 0;
> -static int usart_last_close(int major, int minor, void *arg)
> -  return 0;
> -static int usart_read_polled(int minor)
> -  if (minor == 0) {
> -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) == 0) {
> -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
> -    } else {
> -      return -1;
> -  } else {
> -    printk("Unknown console minor number: %d\n", minor);
> -    return -1;
> -static void usart_write_polled(int minor, char c)
> -   while (1) {
> -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
> -       break;
> -   BCM2835_REG(BCM2835_UART0_DR) = c;
> -static ssize_t usart_write_support_polled(
> -  int minor,
> -  const char *s,
> -  size_t n
> -  ssize_t i = 0;
> -  for (i = 0; i < n; ++i) {
> -    usart_write_polled(minor, s [i]);
> -  return n;
> -static int usart_set_attributes(int minor, const struct termios *term)
> -  return -1;
> -const console_fns bcm2835_usart_fns = {
> -  .deviceFirstOpen = usart_first_open,
> -  .deviceLastClose = usart_last_close,
> -  .deviceRead = usart_read_polled,
> -  .deviceWrite = usart_write_support_polled,
> -  .deviceInitialize = usart_initialize,
> -  .deviceWritePolled = usart_write_polled,
> -  .deviceSetAttributes = usart_set_attributes,
> -  .deviceOutputUsesInterrupts = false
> diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> index d0e126699a..85b16fafe9 100644
> --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> @@ -33,12 +33,27 @@ extern "C" {
>  #define FB_CONSOLE 0x50492835
> -bool fbcons_probe( int minor );
> +bool fbcons_probe(
> +  char c
> +typedef struct {
> +    rtems_termios_device_context base;
> +} rpi_fb_context ;
>   * Driver function table
> -extern const console_fns fbcons_fns;
> +extern const rtems_termios_device_handler fbcons_fns;
>  #ifdef __cplusplus
> diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> index 40c80cf408..4e5c84c741 100644
> --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> @@ -60,6 +60,22 @@
>  #define RPI_PERIPHERAL_SIZE         0x01000000
> + * @name Current Serial Device
> +typedef enum {
> +  PL011 = 0,
> +  AUX_UART,
> +  FB
> +}CURRENT_SERIAL;
> +extern CURRENT_SERIAL SERIAL;
>   * @name Internal ARM Timer Registers
> @@ -184,42 +200,6 @@
> - * @name UART 0 (PL011) Registers
> -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
> -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
> -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
> -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
> -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
> -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
> -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
> -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
> -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
> -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
> -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
> -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
> -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
> -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
> -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
> -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
> -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
> -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
> -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
> -#define BCM2835_UART0_MIS_RX    0x10
> -#define BCM2835_UART0_MIS_TX    0x20
> -#define BCM2835_UART0_IMSC_RX   0x10
> -#define BCM2835_UART0_IMSC_TX   0x20
> -#define BCM2835_UART0_FR_RXFE   0x10
> -#define BCM2835_UART0_FR_TXFF   0x20
> -#define BCM2835_UART0_ICR_RX    0x10
> -#define BCM2835_UART0_ICR_TX    0x20
> diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h b/bsps/arm/raspberrypi/include/bsp/usart.h
> index d3e710c5e9..abbf53626c 100644
> --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> @@ -32,9 +32,8 @@
>  extern "C" {
>  #endif /* __cplusplus */
> -#define USART0_DEFAULT_BAUD 115000
> -extern const console_fns bcm2835_usart_fns;
> +#define PL011_DEFAULT_BAUD 115000
> +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>  #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> index 11a22f89e3..ce91527f92 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> @@ -63,14 +63,15 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>  # Console
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/usart.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/fb.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/outch.c
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios-init.c
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>  # Mailbox
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
